Old Mar 09, 2014, 01:42 PM
petya's Avatar
Brasil
Joined Apr 2006
Question Gyro Gain
Dear:
I have a Guardian 2D/3D forgot in my stuff for some time . Now i decided to use it. My main question at this point is as follows:
Using the Stabilize 2D function, must i use an automatic reduction in the gain of the gyro as the sticks move away from the center ?
I have two radios, a JR 10X and a DX8 and both has this resource , to reduce gain of Gyro with stick deflection .
I think this function can help fly the plane without the stabilization system "Fight" against you.
Any advice will be welcome!
Sorry my poor english , i'm from Brazil .
Best Regards!
Eduardo
petya is offline Find More Posts by petya
Old Mar 09, 2014, 02:13 PM
petya's Avatar
Brasil
Joined Apr 2006
Another question occurred to me .... on a plane with conventional landing gear taking off the system in 2d will not understand that the plane is out of level flight and try to lift the tail ?
Old Mar 10, 2014, 08:11 AM
JohnET's Avatar
United States, NC, Charlotte
Joined Apr 2013
Eduardo,
You can enable "Center Stick Stabilization" if you would like less stabilization in 2d mode as you move the stick away from center.
You should have the tail lifted so that the plane is level when you reset level flight. Don't reset level flight with a tail dragger with its tail on the ground.
Regards, John
JohnET is offline Find More Posts by JohnET
Site Sponsor
Old Mar 10, 2014, 08:49 AM
petya's Avatar
Brasil
Joined Apr 2006
John :
Thanks for your reply.
I think according to my bad english, I could not spend my question correctly.
I will try again ....
1 - A plane with conventional landing gear, adjusted for level flight will try to keep this behaviour . I understood that .
In the moment the plane is running for takeoff will not have a forced raised tail (by elevator action) too early ? Losing drivability with the tail wheel ?
2 - The radios (DX8 an JR10X) have the function of reducing the gain as the stick moves away from the center ....
This feature IN THE RADIO would help fly the plane without fighting with the system in 2D mode ? Or hinder the performance of the stabilizer ?
Again , sorry my poor english !!
THANKS !!
Old Mar 23, 2014, 09:44 AM
petya's Avatar
Brasil
Joined Apr 2006
HELP friends !!
Old Mar 24, 2014, 07:47 AM
JohnET's Avatar
Joined Apr 2013
Petya,
If the tail starts to lift, then there should be enough air moving over the control surfaces to have yaw control without the wheel being on the ground.
Sorry but I am not familiar enough with your radio and that function to give you any advice on that. You may have to test it yourself to see how it performs.
Regards, John
Site Sponsor
Old Mar 24, 2014, 08:54 AM
petya's Avatar
Brasil
Joined Apr 2006
Thanks !
Old Apr 07, 2014, 02:18 PM
petya's Avatar
Brasil
Joined Apr 2006
Setup for 2 elevators servos
Dear John :
Is it possible to use the the stabilizer on a plane with 2 servos in elevator , 2 servos in ailerons and 1 in rudder ??
If yes , how to setup ??
THANKS !!
Old Apr 08, 2014, 07:38 AM
petya's Avatar
Brasil
Joined Apr 2006
UP ! Help friends!!
Old Apr 08, 2014, 07:50 AM
JohnET's Avatar
Joined Apr 2013
Petya,,
In order to use dual elevators you will need to use a Y connector on the Guardians elevator output and use programmable servos, a reverser or mechanical means to sync the servos. Keep in mind that there is a 5 amp current limit on the Guardian so if you are close to that limit with the servos, you will need to apply additional power to the output side of the Guardian. This procedure is outlined in the manual.
Regards, John
Site Sponsor
Old Apr 08, 2014, 07:58 AM
petya's Avatar
Brasil
Joined Apr 2006
Thanks a lot John !!
Old Apr 08, 2014, 10:09 AM
USA, MO, Florissant
Joined Nov 2010
Just FYI, read this: http://www.rcgroups.com/forums/showp...postcount=8764
Make sure those servos are really stable when connected in pairs.
Wintr is offline Find More Posts by Wintr
Old Apr 08, 2014, 10:52 AM
petya's Avatar
Brasil
Joined Apr 2006
THANKS i will !!
Old Jun 20, 2014, 03:30 PM
petya's Avatar
Brasil
Joined Apr 2006
Dear John :
Installed Guardian in a Carl Goldberg Chipmunk for testing.
Liked the Self Leveling, is working well.
But the takeoff roll, operating in 3D mode, it takes too long to correct the deviation of rudder. The rudder gain is high .
Another issue, when I put the airplane inverted flight in 3d mode and loose the commands it does not hold the attitude.
I feel there is low response to yaw deviations despite being high gain .
Any tip or advice ??
Old Jun 29, 2014, 06:25 PM
petya's Avatar
Brasil
Joined Apr 2006
John ....
Any tip or advice about my issues ??
THANKS !!
Help! Gyro gain setting on Walkera 2801 Pro getsuyoubi Electric Heli Talk 0 Dec 27, 2013 09:46 PM
Alert Naza M pre 1st flight questions (no, not gains) jwk72 Multirotor Electronics 2 Oct 22, 2013 02:38 AM
telebee gyro gain on remote vs gain on gyro on trex djdaveq Mini Helis 2 Jul 10, 2005 11:29 PM
Gyro Gain Question - TRex tomi Mini Helis 17 May 06, 2005 01:50 PM
Increasing PG03 gyro gain + mixer question autoair Micro Helis 4 Nov 28, 2004 05:39 PM
