Old Jul 18, 2014, 11:03 PM
Tony Audsley Retired Locksmith
Lockey's Avatar
Australia, WA, Perth
Joined Sep 2011
I had this on one of the surfaces ... pulled it off completely and used Foam-Tac on both surfaces ... pushed them together and wiggled them about a bit, pulled them apart for a couple of minutes and then back together ... stronger than they ever were now
As far as using foam safe CA ... I use this on a lot of my models when I use the plastic hinges with the metal pin, I grease the hinge / pin first ... push the hinge into the foam just a little and put CA on both sides of the hinge, push it in all the way and spray it with accelerator
Lockey
Lockey is offline Find More Posts by Lockey
Latest blog entry: Mig-15
Old Jul 19, 2014, 05:23 AM
Blutck's Avatar
Canada, ON, New Dundee
Joined Jul 2013
Can somone post a pic of a surface they have hinged. I have never done this. Also what type and size of hinges are you buying?
Blutck is offline Find More Posts by Blutck
Old Jul 19, 2014, 08:15 AM
DeLaReef123's Avatar
United States, CA, Orange
Joined Mar 2014
Rem, I used CA hinges as well. No issues what so ever. However I would recommend using the thin CA. The foam safe CA is to thick, unless you have foam safe thin CA which I have never seen.
Just take care with alignment. I know it's more work but four on each seemed to help me with alignment.
DeLaReef123 is offline Find More Posts by DeLaReef123
6Sally5's Avatar
United States, CA, Lincoln
Joined Jan 2011
Originally Posted by Rem Fodder View Post
After reading about failing and failed control surface hinges I decided to check my WACO out tonight and sure enough, the tears in the hinge lines are well on their way to failure. Big thanks goes out to all of you guys for bringing this up on the thread.
Put a couple of batteries through her last evening, was going to mount the Go Pro into it for this evening and decided to hold off after discovering the tears.
Has anyone tried using CA hinges for refitting this kit? I have lots of them, as well as the foam safe CA too.
I used CA on mine, REM and regular CA with kicker. No issue whatsoever.
6Sally5 is offline Find More Posts by 6Sally5
Old Jul 19, 2014, 09:22 AM
Scale or Bust (mostly bust!)
FerretMaster's Avatar
United States, AZ, Casa Grande
Joined Dec 2010
Hinges and CA
Someone asked for photos of the hinge installation.
Here are the Ailerons, Rudder and Elevator on my Dynam Albatros.
Also the hinges from HK along with the CA I use. I have not used kicker, just let them hang from the fixed surface and make sure they are hanging at 90 degrees. Let fully set and attach the control surface with Thin CA making sure it goes deep into the hole I had previously drilled.
Good luck.
Dave/FM
FerretMaster is offline Find More Posts by FerretMaster
Old Jul 19, 2014, 10:06 AM
The figure "9" Specialist
aeronca's Avatar
A Barrier Island in New Jersey, USA
Joined Oct 2003
You might want to check YouTube. There is likely a video there on "installing DuBro hinges" (although almost any pinned hinge will work well). As for size, I would think anything in the plus/minus 1/2" wide size would work well.
Aeronca
aeronca is offline Find More Posts by aeronca
Old Jul 19, 2014, 01:18 PM
friendly foamy flyin fellow
millerr74's Avatar
United States, NC, Greenville
Joined Oct 2013
if you're using pinned hinges apply vaseline on the hinge pin to prevent whatever glue type you choose to use. there is thin foam safe CA. i use it and it's no more viscous than water... kinda a PITA. ferret has also used the vaseline technique to grand success.
millerr74 is offline Find More Posts by millerr74
Latest blog entry: my birds
Old Jul 19, 2014, 01:21 PM
From the Ashes...
55TBird's Avatar
United States, AL, Athens
Joined Jun 2013
I have found the white Gorilla Glue to work well on CA hinges, when working on larger planes.
Gives me more time to align the hinges and the control surfaces, and I'm less concerned that I've got enough glue on them, since the glue expands.
55TBird is offline Find More Posts by 55TBird
Old Jul 19, 2014, 01:23 PM
millerr74's Avatar
Joined Oct 2013
here's the pin hinge technique i've documented...
Old Jul 19, 2014, 01:29 PM
Radio-active flyer
Rem Fodder's Avatar
Canada, ON, Port Hope
Joined Apr 2012
Thanks guys, appreciate your responses. Only reason I was thinking of the CA hinges is that I have them on hand for two upcoming kits builds. I always used the Dubro pinned hinges in the past for wood kits, however the workshop stock is mighty depleted. Next time I head for town will make sure I pick some up.
FM, did you have to imbibe in a lot of liquid sanity check doing that lozenge paint scheme on your Alby? Nice work.
Rem Fodder is offline Find More Posts by Rem Fodder
Old Jul 19, 2014, 02:47 PM
Joined Dec 2010
Thanks for the kind words.
Check the Dynam Alby thread http://www.rcgroups.com/forums/showthread.php?t=1921674
My build is somewhere around page 28 or so. Quite the journey but turned out great if I do say so....and I do!
Dave/FM
Last edited by FerretMaster; Jul 19, 2014 at 02:48 PM. Reason: PS: No more imbibing going on than usual!!
Old Jul 19, 2014, 02:48 PM
Joined Dec 2010
Old Jul 20, 2014, 07:23 PM
Australia, VIC, Bendigo
Joined Jan 2012
Check out my post and pix #3396 on page 227 Du-Bro hinges all round. I have used these, pin hinges and fiber/ca depending on the model and surface thickness.
agedflier is online now Find More Posts by agedflier
Old Jul 20, 2014, 08:42 PM
Joined Dec 2010
The sad part is that I knew better. The ONLY plane that I own that I had not replaced the foam hinges on was the WACO.
It did not seem that that many flights had gone under her wings, but at a minimum of 5 packs a day and five to six days flying per week it added up in a hurry. I thought that the foam would hold until I did the repaint I had planned, but two months came and went and so did the WACO. Around 200 flights. I had no idea 'till I went back and started to add it up.
I am currently building my Dynam Peaks and yes, with pin hinges before the maiden.
As soon as my finances rebuild to allow it I will be reordering another WACO. I can't see going very long without one in my flight rotation. At the front I don't hesitate to add!
Dave/FM
Old Jul 21, 2014, 06:04 AM
SeeMeDo's Avatar
Joined Feb 2013
Yes by all means lube the hinge, I didn't listen to Flying buddy on this, had to pry out eight of the prettiest robert hinges from both ailerons.
A light oil works, like 3in1 and sewing machine, too.
Jeff…….
SeeMeDo is offline Find More Posts by SeeMeDo
Sold Dumas Waco YMF-5 Biplane EP Kit 35" $50 shipped carrera0to60 Aircraft - Electric - Airplanes (FS/W) 3 Aug 23, 2012 07:21 AM
Sold Vintage PICA WACO YMF.3 1/6 scale Unbuilt Kit spitfire1999 Aircraft - Fuel - Airplanes (FS/W) 2 Jul 16, 2012 09:06 PM
Off Site Vintage PICA WACO YMF.3 NIB For Sale Come check it out! spitfire1999 Aircraft - Fuel - Airplanes (FS/W) 1 Jun 23, 2012 09:05 AM
Sold Pica 1/5 scale Waco YMF - in the bones Hemikiller Aircraft - Fuel - Airplanes (FS/W) 1 Apr 10, 2012 06:35 AM
For Sale LPU Great Planes Waco YMF-5D RTF $300 RCGill Aircraft - Fuel - Airplanes (FS/W) 9 Mar 22, 2012 12:42 AM
