Old Nov 04, 2014, 10:54 PM
Joined Nov 2012
2M ACC One Design Newport RI
Had a great day of testing with four 2m ACC One Designs today in Newport, RI.
A few pics, Gopro from onboard "Prada" to follow soon.
][/URL]
][/URL]
][/URL
[/URL]
[/URL]
John Fries is offline Find More Posts by John Fries
Old Nov 05, 2014, 04:01 AM
Joined May 2008
This is a humble reminder that there is always somebody out there with a better boat!
Absolutely superb chaps, great boats, great location to sail them
tim_uk is online now Find More Posts by tim_uk
Old Nov 05, 2014, 07:49 AM
USA
Joined Mar 2009
Awesome looking boats... I'll bet they fly in a breeze..
Where are you sourcing the masts from?
How tall are they?
Do they have a groove in them for a bolt rope?
Brian
sailfish is offline Find More Posts by sailfish
Old Nov 05, 2014, 08:20 AM
RC Newbie with lots of ideas
Chile, Santiago Metropolitan Region, Stgo
Joined Dec 2012
I have another questions: What is the sail material used?
tarmstro is online now Find More Posts by tarmstro
Old Nov 05, 2014, 08:21 AM
Joined Nov 2012
Thanks guys, they are a blast to sail for sure.
We make the masts in house, they are 12mm X 28mm with internal boltrope groove.
All carbon section weight 8 ounces at 93 inches with gooesenck and vang attachments molded in.
Old Nov 05, 2014, 08:49 AM
Joined Nov 2012
There's a bunch of different material you see there, mainly samples form fabric companies I work with. http://www.friessaildesign.com/
The clear sails are just raw film, the kevlar jibs material came form Challenge Sailcloth, the Black fabric form Contender. White main on "Prada' is leftover '92 Cuben Fiber from A3.
Still trying to find the "right" cloth fr these boats. the load is pretty high so we need something pretty low stretch but not to heavy.
Old Nov 05, 2014, 08:51 AM
United States, FL, Cocoa Beach
Joined Jan 2010
Very nice, John! Have you tried the Dimension Polyant ODL material? It may be too heavy at 2.2 oz but works well on my big tri.
DLord is offline Find More Posts by DLord
Old Nov 05, 2014, 08:59 AM
Joined Nov 2012
The yellow jib above is very similar to the ODL at 2 ounces. Fine for the "b" sails we use but a bit to heavy for the "a" set. Still searching for just the right thing.,
May take a trip up to Dimension soon and see what else the might have, it's only 45 minutes from my house.
Old Nov 05, 2014, 10:20 AM
Dick L.'s Avatar
Minnesota, USA
Joined Aug 2002
Hi John
Do you recall what weight the Cuben is? I'm just getting ready to try some .74 oz stuff for one of my RG65 boats. It is very light, but not sure what top end wind strength for it might be.
Thanks in advance for your response, nice looking boats.
Dick
Dick L. is offline Find More Posts by Dick L.
Old Nov 05, 2014, 11:08 AM
Joined Nov 2012
The Cuben we have here is around .8 oz +/- and is a little different than what you'd get from them now. It uses mylar film that is .25 mil/.25mil and spread tow spectra in the warp with a tiny fill yarn. Newer Cuben is made by using sheets of spectra/dyneema vs yarn and often times uses tedlar for film.
The cuben you're looking at using should never fail in that application, I have seen some severe shrinkage issues with it in the lighter weights.
Old Nov 05, 2014, 02:10 PM
Dick L.'s Avatar
Minnesota, USA
Joined Aug 2002
Thanks John - I will proceed to use it for my "A" sails, but will see how they work out, and also take a look at some of the heavier weight stuff.
When you say "shrinkage" - does that also include the opposite as in "stretch"?
Old Nov 05, 2014, 03:01 PM
Joined Nov 2012
it won't stretch the issue you may have will be shrinkage. I used tons of Cuben over the years for full size sailmaking. The best application for it was always larger boats in heavier weights with lots of bias plys, this helped stop a lot of the shrinkage.
For example I did quite a few sails for Playstation/Cheyenne in Cuben, they were 11-12 ounce fabric.
Old Nov 05, 2014, 03:41 PM
USA
Joined Mar 2009
Thank you for the information.
You have a PM
Old Nov 05, 2014, 04:07 PM
Joined Nov 2012
replied
Old Nov 05, 2014, 07:46 PM
United States, WA, Port Townsend
Joined Feb 2006
John, those boats look like SAILBOTs except remote control instead of programmed control.
lhurt is offline Find More Posts by lhurt
Discussion And Another 2m AC One Design! John Fries Sailboats 18 Mar 06, 2014 09:23 AM
Discussion Another 2M AC One Design hits the water John Fries Sailboats 12 Jan 29, 2014 06:06 PM
Discussion 2M ACC One Design Foil Molds John Fries Sailboats 0 Jun 21, 2013 03:59 PM
Gallery Yes, they do even have jockeys on the front lawn.... Newport, RI sweatyfingers Aerial Photography 2 Jun 07, 2010 12:58 PM
Gallery A place to put my Newport, RI AP stuff tuppertn Aerial Photography 13 Oct 18, 2007 02:48 PM
