Old Jul 31, 2014, 11:37 AM
Wats the worst that can happen
TheCure's Avatar
Canada, BC, Surrey
Joined Jan 2009
Is there a decent EDF fan someone can recommend that flies well (not anemic) on 6S, but will accept 8S for ballistic speeds?
Maybe a HK unit to save on my costs??
I dont mind using the stock fan also, unless there is a good reason not to. In this case I hope for a motor recommendation.
TheCure is offline Find More Posts by TheCure
Latest blog entry: My Mods to My RC Electronics
Old Jul 31, 2014, 05:13 PM
United States, FL, Altamonte Springs
Joined Jun 2012
I wouldn't go that route unless you have $$$$ lipos that can handle the amp jump from 6s onto 8s.
So many others not too in this jet - lack of space for lipos, dealing with higher wing load, lower flight times, extra cost for 8s capable ESC.
voxel is offline Find More Posts by voxel
Old Aug 01, 2014, 12:04 AM
TheCure's Avatar
Canada, BC, Surrey
Joined Jan 2009
actually I have 4s lipos which should easily handle the current draw for an 8s series configuration. I don't own any 6s packs, and my 3s packs probably won't cut the amp draw.
I was thinking of this fan:
http://www.hobbyking.com/hobbyking/s..._Unit_6s_.html
anyone know if it will fit?
Old Aug 01, 2014, 12:37 AM
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
Get the 8s version if you want to run 8s.
Any fan that is designed to handle 8s will be eniemic on 6s. If a fan is optimized for 6s, it will not last running 8s.
4stripes is offline Find More Posts by 4stripes
Latest blog entry: Some photos of the EDF fleet!
Old Aug 18, 2014, 12:20 PM
TheCure's Avatar
Canada, BC, Surrey
Joined Jan 2009
Hows about using this motor with the stock fan unit?
https://www.hobbyking.com/hobbyking/...dproduct=39831
I have 2x 4000ma 4s 45-90C nano tech packs to use
Old Oct 30, 2014, 11:51 PM
United States, CA, Orange
Joined Jan 2004
My mig-15 with servoless retract, Mercury 90mm EDF 7s 4000 Mah 65c.
HK Mig 15 with 90mm Mercury 6s (3 min 0 sec)
jasonvo is offline Find More Posts by jasonvo
Old Oct 31, 2014, 03:48 PM
TheCure's Avatar
Canada, BC, Surrey
Joined Jan 2009
Nice flight
Looks like it comes in hot!
Old Nov 01, 2014, 07:28 AM
4stripes's Avatar
Joined Jan 2009
I'm not familiar with the "stock" fan for this jet. The motor you mentioned is quite large at 40mm diameter which doesn't fit many shrouds. You would have to measure it.
Old Nov 02, 2014, 05:57 AM
Joined Jan 2004
Originally Posted by TheCure View Post
Nice flight
Thanks. It float like glider
Discussion Hobby Topgun 90mm Mig 15 maiden flights! 4stripes Foamy EDFs 20 Jun 07, 2012 09:51 PM
Discussion new:4/15/2011Fiberglas hobbyking Kits: F22 dual 70mm Kit & 90mm MIG texbird Electric Ducted Fan Jet Talk 0 Apr 15, 2011 12:27 PM
New Product ProDesign Mig-15 90mm, test fly on page 2. ProDesign Electric Ducted Fan Jet Talk 27 Sep 03, 2009 09:32 AM
Video Mig-15 90mm ProDesign Fuel Plane Talk 2 Aug 18, 2009 12:46 PM
Sold NIB Wemotec Mig 15 90mm all-composite ARF FL62 Aircraft - Electric - Jets (FS/W) 1 Mar 05, 2008 08:53 PM
