Old Jul 16, 2016, 12:54 PM
rhardy60 is offline
Find More Posts by rhardy60
rhardy60's Avatar
United States, MI, Zeeland
Joined Jan 2014
Question
Pro Boat Voracity stuffing tube liner ?
The Teflon liner change loose and was rubbing against the cobbler has any one had this problem ? Just grease the shaft only had two run on it . Hears a picture of the damage . Can i just cut off the bad end and still use it ?
rhardy60 is offline Find More Posts by rhardy60
Old Jul 16, 2016, 03:54 PM
ApexpredatorGT is offline
Find More Posts by ApexpredatorGT
ApexpredatorGT's Avatar
United States, FL, Fort Lauderdale
Joined Nov 2014
Did you grease it before running it the first time?
ApexpredatorGT is offline Find More Posts by ApexpredatorGT
Old Jul 16, 2016, 04:31 PM
rhardy60 is offline
rhardy60's Avatar
Joined Jan 2014
Yes , I always wipe it down and grease it after two runs .
Old Jul 16, 2016, 04:42 PM
Joined Nov 2014
I meant did you grease the shaft prior to the maiden run? I.e. took it out of the box and greased it?
I always grease after every day of running, letting the shaft sit for a few days in the tube let's it corrode.
Old Jul 16, 2016, 05:06 PM
rhardy60 is offline
rhardy60's Avatar
Joined Jan 2014
I did the same as you did . Greased it even before it seen water and after the run same day . Also tighten all bolt's and nut's
before it seen water . I also have the Impulse 31 V1 and never had this problem ?
Old Jul 16, 2016, 05:10 PM
Joined Nov 2014
Hmm not sure what to tell you bud. Stuffing tube liners are a debated topic.
I guess you should order a new one which comes with the shaft or maybe sourcing one from OSE. You can probably cut the damaged portion off and use it for now until you receive the new one.
Old Jul 16, 2016, 05:25 PM
rhardy60 is offline
rhardy60's Avatar
Joined Jan 2014
Just ordered new flex shaft and liner and cut down liner for now . Thanks for your help .
Old Jul 16, 2016, 06:00 PM
Joined Nov 2014
No problem, glad I could help
Since you need the liner it's okay but I actually had a few of the stock flex shafts break, losing the props and all. I purchased the OSE shaft which costs the same as the stock one, wayyyy better. Never had a problem after that. Next time you're in the market for a shaft definitely consider the OSE one.
News Pro Boat Voracity -E Matt Gunn Racing Boats - Electric 125 Jul 24, 2016 06:01 PM
Discussion Pro Boat Voracity Type E. Speed test rhardy60 Racing Boats - Electric 22 Jun 15, 2016 06:15 PM
Discussion Any thoughts from the Pro Boat Voracity or Aquacraft Revolt owners!!!! jongurley Dock Talk 1 Mar 16, 2016 11:04 AM
Discussion Pro boat voracity...Lets hear about it!!! xxxleafybugxxx1 Racing Boats - Electric 9 Aug 28, 2015 10:33 AM
Discussion PT boat rudder and stuffing tube mrbcruzn Scale Boats 31 Feb 08, 2015 10:31 PM
