WMPF OV10 Bronco - RCGroups.com Review
The all new West Michigan Park Flyers OV10 Bronco made it's debut at the Horizon Indoor, and it's official release at EFest 2016. Here's the review of this well-built twin foam-flyer.
Fly it Scale or Hover Runway Center
Product:OV10 Bronco
Kit Price:$85.50 (painted), $65.50 (unpainted)
Material:EPP foam, carbon fiber, lite ply
Wingspan:36"
Length:33"
Weight w/o battery:10.9oz (310g)
Suggested battery:3s 1000mAh
Motors used:SunnySky 2204s-16 2300kv
Props:6x3
ESC's used:Magic 12a
Servos used:3 Hextronik 9g
PDF build manual:CLICK HERE
Available from:West Michigan Park Flyers
West Michigan Park Flyers is well known in the 3D flying community; they make durable EPP and Depron foam aircraft that fly well, look great, and can stand up to the abuse dished out by hardcore pilots and rookies learning to fly 3D alike. I personally own an MX2 EPP profile, and I've beat on it for years without any major issues. So when I heard that WMPF was coming out with my favorite aircraft ever, the OV10 Bronco, I new I has to get one and get it fast!
The all new OV10 Bronco made it's debut at the Horizon Indoor event in 2015, and was launched and selling at EFest 2016 earlier this month. It's an EPP foam, twin-motor hybrid design, meaning it has a full center-fuselage and profile wings, elevator, and booms. I received my fully-built WMPF OV10 from Greg at EFest 2016, added my receiver and a 1000mAh 3 cell LiPo, and did a little creative mixing to shoot the flight review inside the University of Illinois Armory. That's because the Bronco has no rudder - it uses differential thrust from the motors for yaw authority. With the correct mixing, it's very effective in turning the Bronco in a scale manner, or flicking the lightweight airframe around for some 3D maneuvers. Let's take a look at this awesome foam twin.
Video Flight Review
Western Michigan Park Flyers OV10 Bronco - RCGroups Review (5 min 39 sec)
Fit and Finish - What's Included
The OV10 Bronco is currently available as a kit only, but if you're lucky enough to attend any of the indoor fly-ins in the Midwest, you can usually pick up an assembled or ready-to-fly version at the WMPF booth if they're there. I spoke with Greg earlier, and he said he's currently taking orders for the PNP version, to be delivered at the Toledo Weak Signals Expo this year. The Bronco will be up on the WMPF website very soon, but to order one now, you'll need to call or email West Michigan Park Flyers through their website.
The PNP version I received was ready to fly, minus my receiver and battery. Since I brought my Futaba 10CAP with me to EFest, I used a Futaba 617FS receiver; we'll go over mixing later. The PNP Bronco included a pair of SunnySky 2204s-16 2300kv motors, 12-amp Magic ESC's, 6x3 counter-rotating props, and three Hextronik 9-gram servos. The Bronco was assembled with FOAM-TAC, and was extremely sturdy.
Carbon spars are used throughout to maintain it's rigidity. Three carbon tubes run through the main wing, and one across the horizontal stabilizer. There's also a carbon tube in each boom that runs from the motor mount back to the tail. Smaller carbon wires are used to brace the tail and the landing gear.
The center section of the fuselage is open and accessed from the bottom. It's spacious in there for your receiver and battery, but quite tight to fit your hands inside to hook up the servo and esc leads to the receiver. I ended up using hemostats to make the connections, and then taped the receiver to the inside wall.
The only plywood used in the construction of the OV10 is for landing gear support on the mains and nose wheel, and for the motor mounts. Together, the ply pieces form a strong mounting surface that can take the stress from the gear and a pair of outrunner motors. The nose gear is a castering design that uses the differential thrust from the motors to turn the plane. It works very well as the Bronco can almost pirouette on one wheel and spin with prop thrust only.
A total of three 9-gram servos are needed for the Bronco: one for the elevator and two for the ailerons. They mount in the pre-cut servo slots with FOAM-TAC or similar welding adhesive, and attach to the control surfaces with the included control horns and pushrods.
Setup and Transmitter Mixes
The recommended center of gravity setting is 2 1/4" back from the leading edge. After a few test flights, I ended up setting mine at 2 3/4", and the Bronco flew very well. These EPP flat profile planes from WMPF have a wide CG range before they get too squirrely with an aft CG, and the Bronco is no exception.
Since there's no rudder on the Bronco, a few mixes must be performed at the transmitter to allow for differential thrust. It's not necessary for flight, but the differential thrust opens up a world of possibilities for 3D flying, and adds to the scale flight experience as well. It's also necessary for ground steering, so I highly recommend setting up differential thrust coupled to the rudder stick.
There are three goals with regards to mixing on the Futaba transmitter. The first is to mix the throttle channel going to motor number one, to whatever channel you have motor number two plugged into. In my case, I plugged the left motor into the standard channel three, and the right motor into channel number six. A mix is setup with channel three being the master channel, and channel six being the slave channel. So any time the throttle stick is moved, it's also done on channel six as well. We now have both motors spinning with throttle. Now lets program in some differential thrust.
The next mix is to program the rudder channel to the right-side motor. When we move the rudder to the left, it will spin up the right motor. When the rudder stick is moved right, it will slow down or stop the right motor, depending on throttle setting. A mix is setup with channel four being the master channel and channel six being the slave channel. We now need to do a similar mix for the left motor.
Our final mix is to program the rudder channel to the left motor, the same as the previous mix. A mix is setup with channel four being the master channel and channel three being the slave channel.
Flight Performance
From the very first flight of the West Michigan Park Flyers OV10 Bronco, I knew I had made a great decision to review this twin. It's docile, forgiving, and tracks straight and true at low and medium power settings. Go full throttle and the twin 2300kv motors accelerate the Bronco instantly; there's plenty of power on tap for any maneuver you can think of.
My favorite aspect of the Bronco, and one that get's attention on the flight line, is the differential thrust. With the throttle off, moving the rudder to the right will spin the left motor and make the plane yaw right. Moving the rudder left will spin the right motor and make the plane yaw left. With throttle advanced in flight or while taxiing, rudder movements will speed up and slow down the opposite motors to make yaw turns that feel just like standard rudder input. You can use your transmitter to adjust expo and endpoints on the rudder that will affect the motor's thrust output, just as you would on a standard rudder channel. Stall turns and hammerhead turns are a lot of fun because you can throw full rudder and the thrust will rocket the OV10 back around very quickly.
3D aerobatics are easy with the OV10, it behaves much like the other 3D planes in the WMPF fleet, only this one has two motors. Hovering is easy to do, but the Bronco wants to fall backwards due to the tail being up and out of the prop wash. Holding and varying the down elevator will usually keep it pointing straight up, and very little throttle is needed to hold a hover. Knife edge flight is also possible with the differential thrust, although feels a little strange as you're using thrust to hold the knife edge and not rudder deflection. It feels weird initially, but quickly becomes second nature after a few passes. Alpha flight is another area that seems all to easy with the Bronco. The counter-rotating props hold the airframe level without any adverse roll effects or wing rocking. Just slow the throttle, pull back hard on the elevator and add back in a little throttle to high-alpha the OV10 around easily.
Takeoffs are graceful and don't require much power to rotate. Landings, however, do require some power because the OV10 doesn't glide very well. With power off, it will sink fast, so keep a little throttle in as you flare to land, and hold back elevator to roll out on the mains in epic style.
Video Flight Review
WMPF OV10 PDF Build Manual
CLICK HERE for the build manual in PDF form
The quality and performance that's a staple of the WMPF lineup is evident in the OV10 Bronco. It's light, durable, powerful, yet surprisingly stable whether you're flying circuits or 3D. With most Spektrum transmitters, you can quickly program in differential thrust, and with a few programming mixes, it can also be accomplished with most Futaba transmitters as I explained in the review. I would highly recommend picking one up and experiencing first-hand the quality and performance that is the West Michigan Park Flyers OV10 Bronco.
Thanks to Greg and Barb for the Bronco, and thanks to CJ Kurella for flying during the video shoot.
Old Feb 22, 2016, 12:34 PM
Rampage is offline
Find More Posts by Rampage
DFS#000178
Rampage's Avatar
United States, CA, Twentynine Palms
Joined Aug 2005
I need it.
It's not on their website yet, though. Can it be ordered yet? If so, from where?
Rampage is offline Find More Posts by Rampage
Old Feb 22, 2016, 12:53 PM
Matt Gunn is offline
Find More Posts by Matt Gunn
RCGroups Editor
Matt Gunn's Avatar
United States, OH, Parma
Joined Jul 2009
Originally Posted by Rampage View Post
I need it.
From the review:
The OV10 Bronco is currently available as a kit only, but if you're lucky enough to attend any of the indoor fly-ins in the Midwest, you can usually pick up an assembled or ready-to-fly version at the WMPF booth if they're there. I spoke with Greg earlier, and he said he's currently taking orders for the PNP version, to be delivered at the Toledo Weak Signals Expo this year. The Bronco will be up on the WMPF website very soon, but to order one now, you'll need to call or email Western Michigan Park Flyers through their website.
Greg told me it should be on the website later tonight, but you can call or email to order one until then:
WMPF contact page
Matt Gunn is offline Find More Posts by Matt Gunn
Administrator
Old Feb 22, 2016, 12:56 PM
Vintauri is offline
Find More Posts by Vintauri
MN WATTS Master
Vintauri's Avatar
United States, MN, Mankato
Joined Jul 2003
Looking good! Loved seeing it fly at E-Fest!
Vintauri is offline Find More Posts by Vintauri
Old Feb 22, 2016, 01:10 PM
Rampage is offline
DFS#000178
Rampage's Avatar
Joined Aug 2005
Originally Posted by Matt Gunn View Post
From the review:
WMPF contact page
Thanks! I'll be pulling the trigger as soon as it shows up on the site.
I remember seeing this in your original photos a few weeks ago. I thought it was scratch built and those pictures actually got me looking for a flat foamy twin. Then, this!
Jazzed about this.
Old Feb 22, 2016, 02:09 PM
MK is offline
MK
Find More Posts by MK
MK
NJ
Joined Feb 2001
Would a 3S 1300 work? I have tons of those lying around.
MK is offline Find More Posts by MK
Old Feb 22, 2016, 02:12 PM
Rampage is offline
DFS#000178
Rampage's Avatar
Joined Aug 2005
That'd be awesome. I've got at least 6 of them from my 250 quad.
Also got like 6 3S 500s and a couple 2S 1300s.
Old Feb 22, 2016, 02:43 PM
RCGroups Editor
Matt Gunn's Avatar
Joined Jul 2009
Yep! The Bronco recommended pack is a 3s 1000 up to 1300.
Administrator
Old Feb 22, 2016, 02:44 PM
kobe_cantin is offline
Find More Posts by kobe_cantin
kobe_cantin's Avatar
United States, FL, Delray Beach
Joined Feb 2015
Amazing plane, I've flown hardcore 3d and is a AWESOME flier!!! rock solid in harriers and very fun to hover
kobe_cantin is offline Find More Posts by kobe_cantin
Old Feb 22, 2016, 04:18 PM
MK is offline
MK
MK
NJ
Joined Feb 2001
Sweeeeet!
Old Feb 22, 2016, 07:09 PM
KeithK is offline
Find More Posts by KeithK
What Canary?
KeithK's Avatar
Huntsville, AL USA
Joined Jul 2000
Nice article, but are both videos supposed to be the same? Was hoping to see what wild moves differential thrust can do in the air!
KeithK is offline Find More Posts by KeithK
Old Feb 23, 2016, 12:09 AM
Rampage is offline
DFS#000178
Rampage's Avatar
Joined Aug 2005
It's up on the website.
Motors aren't, though.
Hobbyking has these motors. I'm guessing they'll work? Only $8 each.
Old Feb 23, 2016, 04:43 AM
georgy is online now
Find More Posts by georgy
Allways the hard way!
georgy's Avatar
South Africa, GP, Germiston
Joined Jan 2012
I love this design concept!!
Simplicity of a profile (which i prefer) but added the box-fuss to hide the batt.
If you look quickly, you hardly even notice the profile booms..
Me likey!
georgy is online now Find More Posts by georgy
Old Feb 23, 2016, 09:21 AM
volcomsnows2k is offline
Find More Posts by volcomsnows2k
Spicy Torque Roll!
volcomsnows2k's Avatar
USA, CA, Pasadena
Joined Dec 2006
Way cool! I will be ordering one for my dad! He was a OV-10 pilot and he loves his OV-10! Now he can have a park fly OV-10 in addition to his gassers! Sweet!
volcomsnows2k is offline Find More Posts by volcomsnows2k
Old Feb 24, 2016, 06:05 PM
rcrich is offline
Find More Posts by rcrich
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
Great looking twin !
Nice job wmpf!!!
rcrich is offline Find More Posts by rcrich
Review Spektrum VA1100 Ultra Micro FPV Camera and VTX - RCGroups.com Review Matt Gunn FPV Talk 376 Jul 12, 2016 10:05 AM
Sold OV10 Bronco kit partially built rcrmel Aircraft - General - Miscellaneous (FS/W) 0 Dec 30, 2015 07:53 PM
Review Eagle Tree Vector - Installation Setup and Test Flight - RCGroups.com Review Matt Gunn FPV Talk 6 Feb 26, 2015 12:10 AM
Sold K&A models OV10 bronco twin 48chebbie Aircraft - Electric - Airplanes (FS/W) 6 Dec 22, 2013 10:41 PM
