Old Mar 24, 2015, 09:57 AM
United States, CA, Mill Valley
Joined Feb 2010
Oldsamer,
thanks for the info but at this stage I just want to repair or replace the motor for an easy install. I may need to though.
BHOFM
Thanks for your guidance. I have removed the single set screw and the beel comes away about 2mm but thats all I can move. I have attached a photo.
Should I be driving the shaft out left to right or right to left?
drumbum is offline Find More Posts by drumbum
Old Mar 24, 2015, 10:04 AM
Kimbers Keeper.
Joined Nov 2014
The magnets are holding it. Just pull like hell.
BHOFM is offline Find More Posts by BHOFM
Old Mar 24, 2015, 11:07 AM
Joined Aug 2006
lol
Garyss is online now Find More Posts by Garyss
Old Mar 24, 2015, 01:21 PM
ARF Basher
oldsamer's Avatar
United States, TX, El Paso
Joined Jan 2011
[QUOTE=drumbum;31148093]Oldsamer,
Hay, Drumbum
While you have that motor out. Please weight it....
I didn't and it's not specified anywhere. Weight is an important consideration if replacing it.
And let us all know what it weights !
oldsamer is offline Find More Posts by oldsamer
Old Mar 26, 2015, 02:09 PM
Joined Feb 2010
oldsamer,
I got 89 grams for the motor. sorry it took so long,
DB
Old Mar 26, 2015, 06:44 PM
ARF Basher
oldsamer's Avatar
Joined Jan 2011
Das Grosser Plat-itus
Originally Posted by drumbum View Post
oldsamer,
DB
No problem, every body member 89g on the nose.
Yesterday I finished installing a MorganMills battery sled, took 2 days More about that If anyone else wants to do it.
I may have the heaviest Pc-6, thus the Das Grosser title. Up loading a big JPG that explains the weight gain. Test fly Saturday before the weekenders.
Old Mar 26, 2015, 07:33 PM
ST_Bob's Avatar
United States, MA, Worcester
Joined Feb 2013
I have a suggestion for all that weight and balance trouble; but it will require some creative engineering.
Move the motor back to the rear of the plastic 'cup' it's mounted in by gluing a bearing into the hole where the shaft exits now and putting an extension shaft on the motor. Then attach a new motor-mount to the rear of the plastic cup and the front of the battery tray slide. Then attach the motor there. It will require some building and/or modifying a standard prop-shaft extension (if such a thing exists) but should cure the balance problem. It might cause some trouble installing/removing the battery though.
A hobby-lathe might be something to put on your wish-list...
ST_Bob is offline Find More Posts by ST_Bob
Old Mar 28, 2015, 08:17 AM
ARF Basher
oldsamer's Avatar
Joined Jan 2011
Robot Dremal
A hobby-lathe is So 20th century. A 3D printer is on my wish-list
Stepcraft is the desktop CNC solution.
This machine can mill, carve, engrave, 3D print, work as a vinyl/craft cutter, plot and more.
http://www.rcgroups.com/forums/showt...ign=RCG%20Emma
Old Mar 28, 2015, 08:50 AM
Tallahassee, FL
Joined Sep 2009
Neither of those machines can touch a lathe for making bushings and such.
Turner2 is online now Find More Posts by Turner2
Old Mar 28, 2015, 08:53 AM
ST_Bob's Avatar
Joined Feb 2013
And when you can make a 6061-T6 prop-shaft extension on a 3-D printer the average hobbyist can afford, let me know.
Old Mar 30, 2015, 09:44 AM
rip
ripacheco's Avatar
United States, FL, Niceville
Joined Jan 2013
recommendations on differential aileron?
ripacheco is online now Find More Posts by ripacheco
Old Mar 30, 2015, 10:13 AM
Joined Sep 2007
I mixed in 20% rudder.
robbie9859901 is offline Find More Posts by robbie9859901
Old Mar 30, 2015, 09:17 PM
United States, PA, West Chester
Joined May 2012
Has anyone found replacement shafts for the stock motor? Broke mine on a botched landing and motors seem to be on back order (Tower) or discontinued (Horizon). Kind of frustrating that a $5 motor shaft can't be found.
Citationfxr is offline Find More Posts by Citationfxr
Old Mar 30, 2015, 10:10 PM
Kimbers Keeper.
Joined Nov 2014
There was a long discussion about that a few pages back. Get the measurements and
check Headsup.
Old Yesterday, 12:59 AM
Save a tree fly a foamy
United States, CA, Marshall
Joined Apr 2005
Here's what I do on a plane like this:
On the bench, give it full right and eyeball that the right aileron has deflected a noticeable amount more than the left (like 30% more).
Do the same for full left.
Good enough - go fly.
On something like Park master with big ailerons it becomes a bit more tricky to find a sweet spot, and that sweet spot is a moving target depending upon what kind of flying you do. I.E If you do a lot inverted flying you might opt for less differential.
S.Davy is offline Find More Posts by S.Davy
Gallery Pilatus PC-6 Porter wizard of odd Scale Drawings and Three Views 2 Nov 04, 2014 11:11 AM
Build Log Guillow's Pilatus Porter PC-6 Bill Smudge Scale Kit/Scratch Built 51 Jan 13, 2014 07:01 AM
Sold PC-6 Pilatus Porter 60" wingspan UV-20 Golden Knights version payne9999 Aircraft - Electric - Airplanes (FS/W) 12 Dec 15, 2013 12:15 PM
Discussion Pilatus PC-6 Porter DXF file wizard of odd Scale Drawings and Three Views 2 Nov 16, 2013 12:52 AM
Pilatus Pc-6 Turbo Porter Parkflyer kestrel2003 Parkflyers 23 Jan 02, 2004 05:19 PM
