Old Jan 14, 2015, 11:03 PM
I74
I74's Avatar
United States, IA, Cedar Rapids
Joined Jan 2013
Hi Tom... Thanx for the reply.. My motor mount for my pod design is adjustable , and I think since it will be flown off a runway, my first thoughts are to set the thrust angle about neutral , or maybe a half degree up.. I will see how it powers down the runway for balance and lift, and go from there.. I wonder if some of the set ups I have seen here, that are angled way back, are having troubles because of to much air getting over the tail, and not enough under it. ?? .. Ian
I74 is offline Find More Posts by I74
Old Jan 15, 2015, 06:50 AM
United States, CT, Waterford
Joined Jul 2012
Hi Ian- sounds interesting. Let us know what you learn. The paved runway will help get airspeed fast. You may want to add a small nose skid to take some of the shark sniffin abuse.
Regarding your question- I think it's a few things...
A pusher engine is probally less efficient and the inexpensive setups have marginal output power. Also, most of us come to this with expectations of 3d-like power plane liftoff- which ain't gonna happen.
I've had the best continual success, on a grass field, with a 30' bunge assist. It simple and gets her in the air fast.
TomTerrific is offline Find More Posts by TomTerrific
Old Jan 16, 2015, 12:19 AM
I74
I74's Avatar
Joined Jan 2013
Tom,, I think a balance of thrust and lift , in the right places is key...Ian
Old Jan 16, 2015, 12:29 AM
I74
I74's Avatar
Joined Jan 2013
Also Tom,, In your pic,, your prop blades look smaller, for a higher KV motor?, Am I correct??.. My set up is configured for a 1200 kv motor, with a thrust to weight ratio of around .8 - 1.. I'am definitely putting some road rash protection under the front also , and it will have wing tip skids.............. Your plane plane looks pretty cool.
Old Jan 17, 2015, 10:03 AM
Joined Jul 2012
Hi Ian-
I'm on my third motor now. The stock didn't last long. I'm currently using an NTM 3548-1100kv rated for 640w@4S. The prop is a 10.5x6. It motor cost $25 or so. Also, a great $3 espritmodel(fr top model) fiberglass piece keeps the prop aligned. My bungee hook will take some of the fuse abuse (if I try a liftoff without the bungee).
Good Luck!
Old Feb 03, 2015, 10:13 PM
United States, CO, Denver
Joined Mar 2013
Which control horns are you guys using with this plane? the ones that came with it are crap. looking for some other ones to purchase.
jwrendenver is offline Find More Posts by jwrendenver
Old Feb 08, 2015, 09:17 PM
Joined Feb 2015
THAT WAS TRULY BEAUTIFUL. Sounds to me like you're one sharp cookie. Just joined this group, and You are truly a STUNNER. Are you familiar with the Zanonia designed and built by Harland Ross? My uncle by way of my dads oldest sister.
Please continue to explain wing design, as most of us aren't up to the level you appear to be.
Thanks again, Barry La Tour
Beaze is offline Find More Posts by Beaze
Old Feb 08, 2015, 10:05 PM
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
Ah...
Martin Y is online now Find More Posts by Martin Y
Old Mar 03, 2015, 03:53 PM
Poland, Greater Poland Voivodeship, Kepno
Joined Feb 2015
Hi everyone
I've got DG808s and Im looking for the right motor setup, It will be the best when I can buy it from HK, I need to put the engine to the oryginaly mount on the top of glider and use 10x6 proppeler.
Thanks for reply.
meny is offline Find More Posts by meny
Old Mar 03, 2015, 06:09 PM
Joined Jul 2012
Originally Posted by meny View Post
Hi everyone
Thanks for reply.
Hi Meny,
I use the NTM 3548-1100 with a 10x6 prop and a 4s lipo with the factory motor pod.
Here is a link for it: http://www.hobbyking.com/hobbyking/s...00kv_640w.html
Good Luck!
Tom
Old Mar 04, 2015, 06:02 AM
Joined Feb 2015
Originally Posted by TomTerrific View Post
Hi Meny,
Good Luck!
Tom
Thank's for reply. I think this motor will be fine
http://www.hobbyking.com/hobbyking/s...strSearch=3548
I can buy it in Polnad. So I think it will be good..? What you think?
Old Mar 04, 2015, 06:37 AM
Joined Jul 2012
I'm no expert- just a little concerned as it not rated as strong as the other. But, it's inexpensive so not a lot of risk.
Ideally, might be better to buy a more expensive, much stronger engine to give you more power and longer life. Anyone else wanna chime in with a better engine? 35mm diameter close to max, but could be longer than 48mm. One of the finer European manufactures?
Old Mar 04, 2015, 07:48 AM
.: Looking for Thermals :.
Ricardo RW's Avatar
Chile, Quinta Región de Valparaíso, Los Andes
Joined Jun 2002
Are you going to install that motor on a pod or in the nose?
Ricardo RW is offline Find More Posts by Ricardo RW
Old Mar 04, 2015, 08:08 AM
Joined Feb 2015
On pod.
Old Mar 04, 2015, 08:44 AM
Ricardo RW's Avatar
Joined Jun 2002
I think that motor is similar (maybe better) that the one that comes in stock (as in mine) so it will work.
Nonetheless, I'd recommend you do some math on any online e-calc program.
Regards
4 meter Duo Discus install and fly Jeff Meyers Scale Sailplanes 51 Dec 26, 2009 09:45 PM
Discussion 4 good places to fly going to waste.... 1987tc USA - District VI 3 May 21, 2007 10:33 AM
New P-82 Twin Ready To Fly Twin 4 Strokes comtech001 Aircraft - Fuel - Airplanes (FS/W) 7 Jan 14, 2005 10:37 PM
should you fly inverted 4' off the deck and hit your photographer ? Goleith Parkflyers 0 Nov 04, 2003 08:09 PM
Pics from Grand Haven MI fun fly going on now rojoyinc Electric Heli Talk 1 Apr 14, 2002 04:43 PM
