Old Feb 14, 2015, 08:23 PM
Joined Dec 2003
Removing epoxied servo
Help,
Just epoxied a servo in tail of a gp siren, appears there is some kinda short in the wire as it stops working when wire wiggled.
Aarrgghhh
Suggestions on how to remve this servo ?
lennyk is offline Find More Posts by lennyk
Old Feb 14, 2015, 11:01 PM
Carbon fiber is our friend
Steve C's Avatar
United States, CA, Lodi
Joined Feb 2001
I took a piece of 90 degree angle and sharpened the end of it so I could wiggle it under servos like this. Sometimes you can just flex it enough to pop it off though. try that first. Just push a thumb in on the other side of the fin and maybe you'll get lucky.
Steve C is offline Find More Posts by Steve C
Old Feb 14, 2015, 11:40 PM
United States, CA, Redondo Beach
Joined Oct 2013
I've used a cutting wheel and made several cuts into servo and pick it bit by bit with needle nose pliers..assuming you can't pry out....the little 90 degree pry bar method sounds good...
hubcapsteve is online now Find More Posts by hubcapsteve
Old Feb 15, 2015, 05:04 AM
Joined Dec 2004
Check the wires in the servoplug first. May not be the problem here, but I have seen instances there the little 'prongs' in the contacts did not quite go through the plastic insulation of the wire.
If the plug is ok, the 90 degree angle sound slike a good idea. I've also used big pliers and just grabbed the servo, then rotating it a wiggling it to each side. After some 'suitable' force is applied they usually pop out easily enough.
Gerben
Gerben is offline Find More Posts by Gerben
Old Feb 15, 2015, 06:07 PM
Joined Dec 2003
Got it out with a sharpened piece of angle, good thing i have lots of scraps from welding.
One of the motor wires was not properly soldered in the servo.
Old Feb 18, 2015, 01:10 PM
arcticflyer's Avatar
Canada, SK, Prince Albert
Joined Jan 2006
Use servo frames...then you won't have to bite your nails the next time it happens
arcticflyer is offline Find More Posts by arcticflyer
Old Feb 19, 2015, 09:50 PM
United States, CA, Stockton
Joined Jul 2002
I'd just use pliers and yank the sucker out., you might destroy ur servo in the process.
Labrother is offline Find More Posts by Labrother
Discussion Five minute epoxy & silk span removal problem on Goldberg Jungmann LG wing mount kenh3497 Balsa Builders 10 Jan 02, 2015 01:27 PM
Help! Removing Epoxy chrispkaiser Electric Plane Talk 9 May 16, 2014 09:29 AM
Discussion How to remove epoxied servos from composite wings cbr998 Slope 14 Aug 09, 2012 02:03 PM
Help! How to remove wing servo which is epoxied? John Kim The Builders Workshop 15 Mar 07, 2012 07:40 PM
Help! Removing epoxied servos from Kevlar pod cfw Hand Launch 6 Jul 17, 2008 11:58 PM
