Old Dec 12, 2014, 10:34 PM
Fly hard with a vengeance.
RPM314's Avatar
United States, NY, Brooklyn
Joined Apr 2012
Question
DX6i Range Check
Hi, all. Just a quick question because I could not find this information anywhere, not to save my life.
Does anybody know the attenuation factor for range check mode on the DX6i, or any other spektrum radio so I can get a ballpark estimate?
They say 90 feet is a good range check distance but there is no indication of how much full tx power distance you can expect from that. If I have an amplified rx in my plane and I can range check to say 150 feet, I have no clue how far away I can actually fly.
RPM314 is offline Find More Posts by RPM314
Old Dec 12, 2014, 10:41 PM
Y=C+I+G
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
not for Dx6i but for 2.4GHz in general: http://www.rcgroups.com/forums/showthread.php?t=1177191
cmdl is online now Find More Posts by cmdl
Old Dec 12, 2014, 11:25 PM
Clive66's Avatar
United States, CA, Fontana
Joined May 2011
If it passes the recommended low power range test on the ground, with a full range RX, the plane should be able to fly out of sight before loosing reception.
If you are planning to do FPV at long distances, then you should do some research on that.
Clive66 is online now Find More Posts by Clive66
Old Dec 13, 2014, 08:20 AM
United States, MI, Monroe
Joined Jun 2009
The manual says 30 paces, aprox 90 feet, always has worked for me.
Tony K is offline Find More Posts by Tony K
Old Dec 13, 2014, 10:14 AM
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
You won't find a published figure of how far you can fly. There are far to many variable for a manufacture to say its guaranteed to be in control at (insert distance here).
If it passes the standard 30 pace range check you will be able to fly it beyond LoS assuming your RX is genuine and installed properly.
If your going beyond LoS as in fpv, you shouldn't use 2.4 or make dang sure your RTH is functioning properly.
In a clean environment I would guess at least 1 mile though.
1320fastback is online now Find More Posts by 1320fastback
Old Dec 13, 2014, 02:53 PM
Sure, I can fly after sunset!?
United States, MI, Novi
Joined Jan 2011
Another example
http://www.rcgroups.com/forums/showthread.php?t=1103017
mybad is offline Find More Posts by mybad
Old Dec 13, 2014, 09:04 PM
tacx's Avatar
United States, MI, Romeo
Joined Apr 2009
normal range check at 90 feet means you can fly 5679 ft away
are we good now?
tacx is offline Find More Posts by tacx
Old Dec 14, 2014, 10:21 AM
Joined Jun 2009
I've flown my planes till they were small specks in the sky and never had any problems. Any farther and I would not have been able to bring them back. I wouldn't worry about this distance out. You will loose sight of them before you loose control. I believe that of the micros as well. Being smaller, harder to see at distance. Kept a micro mustang directly above my head to test one day and it was unbelievable how high I got.
Old Dec 14, 2014, 01:51 PM
RPM314's Avatar
Joined Apr 2012
are we good now?
Yes, excellent. So then range check cuts the range by a factor of ~60, that's just the information I was looking for.
I am planning to do FPV around my local field, just wanted to know how far my radio range will be in comparison to the FPV video range. Very important to know which is longer.
Discussion UMX Radian Range check with DX6i alterb Micro Ready-to-Fly 1 Feb 22, 2015 02:12 PM
Discussion DX6I Range check problem leeflyer Fuel Plane Talk 7 Jul 08, 2014 08:31 AM
Discussion DX6i / AR6200 Failed Range Check dazzago Radios 5 Jul 12, 2011 12:10 AM
Help! Spektrum dx6i range check problem whakahere Radios 8 Aug 23, 2010 01:19 PM
Discussion Spectrum Dx6i - Ground Range Check. Please share your results! Homer_Simpson Radios 3 Jun 02, 2009 04:19 PM
