Old Apr 03, 2013, 05:56 PM
Phil.T-tailer
Phil.Taylor's Avatar
Devon, UK
Joined Jun 2003
The Mad-stab Mad-AMT MadStab design resource thread
Starting a thread here to collect together links to all the ideas that inventive folks on here have come up with for Mad-stab / Mad-AMT - mechanics, linkages, pulleys, cams, chain drives etc.
I'll start with Dawson's oval pulley:
http://www.rcgroups.com/forums/showthread.php?t=1693398
Please add any other links that you know of - so we can build a "design resource"
here for future easy reference
and heres a big "thank you" to all the inventors / experimenters / evolutionists that have got us this far
(and yes, I need this so I can build oval pulleys etc. for the Kulbutin refurb !)
Phil.
Phil.Taylor is offline Find More Posts by Phil.Taylor
Old Apr 03, 2013, 06:01 PM
Phil.T-tailer
Devon, UK
Joined Jun 2003
Shane's funky hybrid pushrod/pulley system on the Fluid:
http://www.rcgroups.com/forums/showp...&postcount=141
http://www.rcgroups.com/forums/showp...&postcount=168
Old Apr 03, 2013, 06:04 PM
Phil.T-tailer
Devon, UK
Joined Jun 2003
I'll contribute my Kulbutin removable Mad-AMT design
http://www.rcgroups.com/forums/showp...21&postcount=9
http://www.rcgroups.com/forums/showp...6&postcount=30
http://www.rcgroups.com/forums/showp...4&postcount=32
Old Apr 03, 2013, 06:08 PM
Feeling FrSky
surfimp's Avatar
United States, CA, Santa Barbara
Joined Feb 2003
For the ultralight Le Fish, I am using a copy of Benoit Paysant-Le Roux's elevator layout as shown on the Madslide plan, with small changes as follows:
  • 6mm Depron (or EPP) for the elevator surfaces
  • 0.125" / 3.2mm carbon fiber tube for stabilizer spar / joiner (CSTSales.com Part Number T512)
  • K & S Tubing 5/32" (3.9mm) x 0.014" (0.35mm) wall aluminum or brass tubing for pivot bearing - perfect sleeve with above CF tube
  • Du-Bro #846 Micro Pull-Pull System with tailboom-mounted elevator servo
  • 1/32" or similar thickness plywood, fiberglass or carbon fiber plate to "box-in" the pivot bearing tube - super bomber mod that greatly increases durability of this joint.
I'm currently using a Futaba 3156MG servo for the elevator, but this is the third one in my plane in about 6 weeks - they're dying early deaths as they do not appreciate any sort of abuse whatsoever.
I recommend instead a Hitec HS-65MG, but you'll need a longer servo arm - Du-Bro #934 Micro Servo Arm XL for Hitec looks good.
I have no affiliation with any of the above companies, just find their products work for this application. Feel free to substitute as appropriate.
Steve
surfimp is offline Find More Posts by surfimp
Old Apr 03, 2013, 06:09 PM
Phil.T-tailer
Devon, UK
Joined Jun 2003
and the great-grand-daddy of them all - the original Madslide pull-pull system
http://www.jivaro-models.org/madslide/page_madslide.htm
EDIT - HaHa - Steve beat me to it - its all good
Phil.
Old Apr 03, 2013, 06:23 PM
Phil.T-tailer
Devon, UK
Joined Jun 2003
Francois Cahour's interesting offset pulley/cam design for the mid-mounted removeable Mad-AMT on his Quartz
http://www.rcpilot-online.com/fcahou...r-3D_a102.html
Old Apr 04, 2013, 05:29 PM
Phil.T-tailer
Devon, UK
Joined Jun 2003
any more contributions? - or just Steve?
Phil.
Old Apr 04, 2013, 06:15 PM
Winging it Ò>
leadfeather's Avatar
Joined May 2006
Here is another method I'm using on my BD-5. A Mad Whip. In the center of movement, the system acts like it is on low rates. When the servo moves far enough, the whip takes over and moves to very high rates to get the 90 degree tail movement...kind of a mechanical dual rates.
I'm working out 90 degrees for both up and down with this system. The nice thing about the whip is that you don't have to switch anything on the TX. Fine control in the middle of the stick then full up elevator in the last bit of stick movement.
Mad Whip on my Le Fish.
Mechanical dual rate for Mad Stab (0 min 34 sec)
leadfeather is online now Find More Posts by leadfeather
Old Apr 04, 2013, 07:55 PM
Feeling FrSky
surfimp's Avatar
Joined Feb 2003
Towards a durable, packable Madstab
I've been brainstorming this solution for a packable Madstab for some time, and plan to build a prototype as soon as I get the parts together.
It's comprised of five parts:
  • 3.9mm square CF joiner rod
  • 6mm square (4mm inner) CF capture tube with corners rounded off
  • 11/32" brass inner bearing tube (0.014" wall)
  • 3/8" brass outer bearing tube (0.014" wall)
  • Control horn or pulley bonded to capture tube
The concept is pretty simple, the 6mm square capture tube (4mm square inside) is installed in the stab halves, as well as having a section bonded to both the inner bearing tube as well as the control horn or pulley (the corners of the bearing tube will have to be rounded off to get it to sleeve into the 11/32" inner bearing tube).
That subassembly is then sleeved inside the outer 3/8" bearing tube, which is installed into the plane with ply or CF/FG plates supporting either side.
A single 3.9mm square joiner rod is used to join the stab halves together. Friction alone might be sufficient to retain the stab halves, if not, then I'd use four small neodymium magnets at the ends of the joiner rod and capture tubes to keep everything in place.
In theory, it should work. In practice... we'll just have to see!
Steve
In theory this should work pretty good... in practice, who knows!
Old Apr 05, 2013, 01:51 AM
wolfv's Avatar
Las Cruces, NM
Joined May 2007
Would this work? A 180-degree servo shaft directly on elevator fulcrum.
Here is a 180 degree servo: http://www.hobbyking.com/hobbyking/s..._12g_0_10.html
No, that won't work.
wolfv is online now Find More Posts by wolfv
Old Apr 05, 2013, 05:51 AM
Phil.T-tailer
Devon, UK
Joined Jun 2003
Steve
Good thinking & sketching there Steve - sort of a fully packable version of the Kulbutin square-drive.
When I was building the Voltij (5 years ago now!) - I got as far as raiding the K&S metals rack at the LMS - I came up with square brass tubes which fitted into each other. But then the Kulbutin turned up so I built the Voltij tail "stock"
A potential problem is slop from the square joiner being able to rotate slightly in the square tube - might not be a problem for a lightweight ultrabat. Bigger square or rectangle (!) drive would have less slop. Build one & try it out?
Phil.
Old Apr 05, 2013, 08:24 AM
Feeling FrSky
surfimp's Avatar
Joined Feb 2003
Yes, I am concerned about the slop you mention although I do have some ideas around how to address it. But to you point, yes again, I intend to use one of these in the near future on a build
Steve
Old Apr 05, 2013, 08:41 AM
Feeling FrSky
surfimp's Avatar
Joined Feb 2003
As far as I know, this idea originally came from Vincent "Prop-er" with his Twincam setup used on the Slopium prototype he built about a year ago.
Here is his video demonstrating its workings:
DSCN6138.MOV (0 min 48 sec)
And on the tail of the plane - check the sweet taileron action!
Madcam system (0 min 57 sec)
And the beautiful Slopium itself:
Steve
Old Apr 05, 2013, 08:46 AM
Feeling FrSky
surfimp's Avatar
Joined Feb 2003
Another cool design idea which uses the concept of spring tension - similar in general principle to Dan "Leadfeather"'s solution but totally different in implementation - is the 2PES - 2 Point Exponential System - by Stéphane "pgts" Combet:
2PES - 2 Point Exponential System - for madstab. (2 min 9 sec)
Stéphane is the creator of the RC-SlopeS as well as the designer of The Poisson, a Depron ultrabat inspired in part by Le Fish. He is currently in progress on a very cool all-wood ultrabatic plane called the Snowflak, which will put the 2PES system into practical application.
SNOWFLAK - I would like to mix a snowflake with a Lunak as RC-glider... (2 min 10 sec)
Steve
Old Apr 05, 2013, 11:51 AM
FSD
Definite Flight Risk
FSD's Avatar
Joined Apr 2008
Great thread...well needed.
-Paige
FSD is offline Find More Posts by FSD
Discussion Kulbutin crazy AMT rebuild & update - MadStuff ! - removable Mad-Stab design Phil.Taylor Slope 47 Jun 15, 2013 05:56 PM
Help! Design of wings, elevators and vertical stabs Dirty Dee The Builders Workshop 20 Mar 19, 2013 11:36 PM
Discussion New simple design Gimbal auto stab. antiguogrumete Multirotor Talk 1 Feb 23, 2013 11:38 AM
Discussion Mad Stab pulley system revisited: Oval Pulley dawsonh Slope 28 Jul 19, 2012 12:09 PM
Discussion thread emphasis via image/emoticons for communication enhancement resource thread!!!! Accu157 Life, The Universe, and Politics 4 Aug 01, 2006 02:16 AM
