Old Mar 27, 2015, 12:15 PM
Joined Jan 2009
Sbach 900mm epp hobby king set up
Was wondering what you guys use for a motor and lipo. I used the suggested electronics and it needs about 50 grams of nose weight... I am using a turnigy 3s 1000 and this motor
. http://www.hobbyking.com/hobbyking/s...dProduct=28502
Thanks in advance
blackened260 is offline Find More Posts by blackened260
Old Mar 27, 2015, 12:58 PM
poppopfox's Avatar
United States, PA, Reading
Joined Jan 2010
Power setup
I have the EPP Hummer which is similar size and weight. I use a 74 g. motor from Headsup. http://www.headsuphobby.com/Emax-BL2...otor-D-211.htm I use their 1500 mah 30C LiPo's as well. http://www.headsuphobby.com/111v-150...tery-F-120.htm With a 10x5 APC, I'm getting a good 9 minutes per flight and ample 3D power. The heavier motor also allows placing the battery right over the cg. Hope this helps.
poppopfox is offline Find More Posts by poppopfox
Cool TechOne Sbach 342 EPP 900mm sold by Hobby King, Nitroplanes and others groovejet 3D Foamies 97 Mar 23, 2015 12:41 AM
Sold Hobby King 50cc Sbach edgetorker Aircraft - Fuel - Airplanes (FS/W) 6 Dec 22, 2014 09:16 AM
Help! Hobby King Sbach 342 1400mm and FMS Sbach 342 Yami28 3D Foamies 2 Apr 13, 2014 06:05 PM
Discussion sbach 342 900mm EPP camilorosso 3D Foamies 0 Mar 23, 2014 09:07 PM
Discussion Hobby King power set up! crazy1pilot Electric Motor Design and Construction 6 Apr 20, 2011 06:06 AM
