Old Jan 13, 2015, 09:43 PM
Joined Jan 2012
Originally Posted by marksp View Post
I may switch to bungee after a Barracuda posts a video showing how they are tied.
Clamped with hog rings, not tied at all.
Lachlan is offline Find More Posts by Lachlan
Old Jan 13, 2015, 11:42 PM
build, fly, crash...repeat
marksp's Avatar
United States, WA, Redmond
Joined Apr 2011
Thanks Lachlan!
I'm such a Neanderthal that I have no idea what a "hog clamp" is or how it would be used to secure the bungee cord! I've tried the o-rings, #30 rubber bands and the J-3 springs and each have failed. Springs work ok, do long as you grease 100% of landings.
Hope to get the bungee solution sorted.
Cheers
marksp is offline Find More Posts by marksp
Old Jan 14, 2015, 07:45 AM
Mulit-Platform Pilot
barracudahockey's Avatar
United States, FL, Jacksonville
Joined Sep 2004
Instead of hooks these are made with rings. I had to wrap them a few times to get the tension right.
barracudahockey is offline Find More Posts by barracudahockey
Old Jan 21, 2015, 06:47 PM
Joined Jan 2012
Thanks Lachlan!
Cheers
If you're happy, and you know it, clamp your hams! (sing it with me)
Hog RINGS, not clamps. Google is indeed your friend. Send me your address and I'll mail you some bungees for the Super Cub.
Old Feb 15, 2015, 05:38 PM
tupelo's Avatar
Helsinki, Finland
Joined Feb 2008
Cotrol throws
Can anyone tell me how the control throws are measured?
For example flap throws are mid 29mm and landing 67 mm.
tupelo is offline Find More Posts by tupelo
Old Feb 16, 2015, 06:16 AM
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
Clamp a straight edge to the bottom of a wing, just outside the flap at the aileron.
Measure from the trailing edge of the flap to the straight edge at the positions indicated.
The flaps are very sensitive at high speeds...I'd suggest slowing the plane down, before deploying them. Too fast and the plane begins a loop.....as it slows down, it will return to level flight...We settled on a 10% nose down elevator trim, mixed with flaps as the master...Application of flaps is barely noticeable then.
epoxyearl is offline Find More Posts by epoxyearl
Build Log Dare Design 60" Piper Super Cub PA-18 AmpAce Scale Kit/Scratch Built 1081 Sep 24, 2012 07:06 PM
FlyRC mag PA-18 Super Cub pull out plan build Canada Goose Parkflyers 371 Jul 15, 2012 06:25 AM
New Product 16%off-Dynam Super Cub PA-18 4-Channel 2.4GHZ PNP RC Airplane@Focalprice.com Santoyo Hot Online Deals 0 Jul 09, 2012 08:34 PM
For Sale Dynam Super Cub PA-18 4-Channel RC Airplane for sale! Santoyo Aircraft - Fuel - Airplanes (FS/W) 4 Jun 02, 2012 09:07 PM
Discussion Dynam (Hobby King) Piper Super Cub PA-18 - which replacement motor? romandesign Foamies (Kits) 2 May 28, 2012 01:41 PM
