Old Mar 23, 2015, 09:32 AM
amitghodke's Avatar
Singapore, Singapore
Joined May 2013
Originally Posted by xcski View Post
I use the Xoar 14X7 and 13X6.5 with the Valuehobby 920 kv motor and they both work great on 3S and, with throttle management, 4S. 4S at full throttle can draw 80 amps with 14X7, so that has to be managed.
Originally Posted by Lusby View Post
14x7 should work well, probably give a thrust to weight ratio of close to 2. Make sure you use an ESC that can tolerate 50+ amps Vox are waaay better than APC. Gemfan slowfly wood 14x4.5 (also sold by hobbyking) would be very good for pure 3D on that setup too.
Thanks guys, i Have the aerostar 45A Esc from HK , i was hoping to use.
amitghodke is offline Find More Posts by amitghodke
Old Mar 23, 2015, 10:22 AM
RC Keeps Me Sane
DanBo3D's Avatar
United States, NJ, Carlstadt
Joined Sep 2005
Originally Posted by swampflyer View Post
i dont quite follow you here..
im gonna order a new one myself to replace one i had last year.. had the elevator yank out on me once or twice on that plane... i used TOO MUCH ca and had some of the core melt on me.
Yes it is a fine line but even Feda recommends regular CA and less is more.
Just a drop or two on both ends top and bottom applied with a fine Z end nozzle.
But I still pin them as I do put the plane thru torture moves, 300+ flights and no problems whatsoever.
DanBo3D is online now Find More Posts by DanBo3D
Old Mar 26, 2015, 04:22 PM
Kevin_JaxFl's Avatar
United States, FL, Jacksonville
Joined Jan 2013
I did manage to get the Aileron back together and the wings look pretty good. Used gorilla glue and epoxy for the big pieces, CA'd the hinges back together. For added insurance I bought 3M hinge tape and am adding that to the hinges tonight. While I am at it I will get the rudder and elevator surfaces with the tape. Should be close to good as new. Will see Sunday depending on the weather and if HK gets my servos to me or not.
Before and after pictures below..
Keep em flying,
Kevin
Kevin_JaxFl is online now Find More Posts by Kevin_JaxFl
Old Mar 27, 2015, 09:39 AM
United States, FL, Keystone Heights
Joined Dec 2012
got one on order.
i cant find the sunnysky motor in stock...
any links or different motor recs?
swampflyer is offline Find More Posts by swampflyer
Old Mar 27, 2015, 10:48 AM
Joined Dec 2012
went with the value hobby motor and the 65amp mantis esc.
cant wait to have one back.
went with the blue.
Old Mar 27, 2015, 11:43 AM
RC Keeps Me Sane
DanBo3D's Avatar
Joined Sep 2005
got one on order.
http://www.buddyrc.com/sunnysky-x2820-800kv.html
Build Log Skywing, Winner's Model, Hokusei, 3DHS 48"-55" EPP Build & Repair Tips groovejet 3D Foamies 429 Mar 06, 2015 04:57 PM
New Product SkyWing 39-in EPP Edge-540 feda 3D Foamies 120 Jan 22, 2014 06:01 PM
Discussion SkyWing 48-in Extra 300L Under Development feda 3D Foamies 229 Nov 04, 2012 01:55 AM
Sold 3DHS 48" Orange Edge 540 LPU in CT newheliguy81 Aircraft - Electric - Airplanes (FS/W) 2 Aug 19, 2012 07:57 AM
