Old May 19, 2015, 06:52 PM
Kam Arrow is offline
Find More Posts by Kam Arrow
Citizen #302
USA, OR, Canby
Joined Oct 2007
1s battery checker?
Does anyone know where to get a 1s battery checker or how to easily check voltage on these small 1s batteries?
Bill
Kam Arrow is offline Find More Posts by Kam Arrow
Old May 20, 2015, 02:42 AM
ATA Flyer is offline
Find More Posts by ATA Flyer
ATA Flyer's Avatar
United States, CA, Temecula
Joined Nov 2001
Hi Kam, I have this one from hobby king https://www.hobbyking.com/hobbyking/...S%5F8S%5F.html
It says it's a 2S battery checker but if you look on the back of the case the first 2 pins indicate 1S.
It works fine and fits my needs for larger battery's as well.
I only use it for a quick check of 1S battery voltage after battery charging or for checking storage voltage but what I've noticed is that if I fly to low voltage cutoff on my 1S batterys (180 mAh and smaller) some times the unit will not measure. Not enough to power the checker I guess.
I think that's why it's advertised as a 2S checker.
I've been flying Tenergy 160 mah cells and they have been holding up fine even after flying to LVC (not recommended)
Unless the cells are getting old even after flying to LVC they usually measure 3.85ish volts which is the recommended storage voltage I believe.
Description: 2S cell checker that also works on 1S
To check the on the above mentioned battery's you will also need an adapter to connect the two
JuletKiloMike can set you up with that http://www.rcgroups.com/forums/showthread.php?t=2341896
I hope this helps
Tom
ATA Flyer is offline Find More Posts by ATA Flyer
Old May 20, 2015, 06:47 AM
Dynascrew is offline
Find More Posts by Dynascrew
Joined Aug 2012
1s battery checker
I just married a 1s female lead to a JST lead which has the proper pin spacing for my checker. There are sources on eBay for both. I use 4" 1s charging extensions on all my 1s chargers anyway and had just bought a 10 pack of JST leads, male and female. Voila.
Dynascrew is offline Find More Posts by Dynascrew
Old May 20, 2015, 12:45 PM
Citizen #302
USA, OR, Canby
Joined Oct 2007
The adapter part isn't a problem. I have 3 different cell checkers but none of them will read a 1s battery
I will look into getting the one from HK
Bill
Old May 21, 2015, 06:02 AM
Geoff Raiser is offline
Find More Posts by Geoff Raiser
United States, VA, Prince George
Joined Jul 2013
I purchased a setup from JKM RC Solutions in our classified section (micro airplanes) and am very happy with it. Works perfectly!
Geoff Raiser is offline Find More Posts by Geoff Raiser
Old May 21, 2015, 06:22 AM
Malibu LXI is offline
Find More Posts by Malibu LXI
Malibu LXI's Avatar
United States, VA, Lynchburg
Joined Jan 2012
+1 for JKM. Works great, good price, and quick shipping.
Malibu LXI is offline Find More Posts by Malibu LXI
Old May 21, 2015, 06:25 AM
Piper J3 is offline
Find More Posts by Piper J3
Full Scale Piper Cub Driver
Piper J3's Avatar
Hinckley, Ohio
Joined Nov 2008
This will read 1S voltage... http://www.ebay.com/itm/2-in1-RC-Lip...item46379fd943
Piper J3 is offline Find More Posts by Piper J3
Old May 21, 2015, 09:23 AM
Piper J3 is offline
Piper J3's Avatar
Hinckley, Ohio
Joined Nov 2008
Also this... http://www.rcgroups.com/forums/showp...87&postcount=1
Old May 21, 2015, 11:36 AM
Citizen #302
USA, OR, Canby
Joined Oct 2007
Thanks for the links guys.
If nothing else I was going to make an adapter from a balance connector I have from a retired battery and some female um connectors and check them 2 at a time.
Bill
Old May 22, 2015, 12:59 PM
cflchurch is online now
Find More Posts by cflchurch
cflchurch's Avatar
United States, PA, Plum
I bought 2 for 5.84 on ebay from a store called. Emilyandlilly, they ship from New Jersey and its free. They are just readouts and dont have the alarm attached. They work great. You will need to make an adapter for the pico style but work great for jst and the next size up from the pico style. The name of it escapes me right now.
cflchurch is online now Find More Posts by cflchurch
Sold 1S-8S Alarm / Battery Checker -- buy 2 get 1 FREE! JulietKiloMike Aircraft - Electric - Batteries & Chargers (FS/W) 5 Mar 26, 2015 05:58 PM
For Sale 1S-8S Low Voltage Alarm / Battery Checker - FREE US Shipping JulietKiloMike Aircraft - Electric - Batteries & Chargers (FS/W) 2 Mar 21, 2015 12:34 PM
For Sale 1S-6S High Accuracy Voltmeter / Battery Checker JulietKiloMike Aircraft - Electric - Batteries & Chargers (FS/W) 2 Mar 18, 2015 09:41 PM
For Sale 1S-8S Low Voltage Alarm / Battery Checker JulietKiloMike Aircraft - Electric - Batteries & Chargers (FS/W) 11 Mar 12, 2015 08:18 PM
Discussion Li-Po Battery Checker Not Working for 1S Battery? boba7523 Multirotor Talk 15 May 09, 2014 01:43 PM
