Old Feb 24, 2015, 05:07 AM
DiAbLo3D is offline
Find More Posts by DiAbLo3D
DiAbLo3D's Avatar
France, Alsace, Altkirch
Joined May 2005
Cool
260mm wingspan micro aerobatic plane
Hello all !
After the "big Bandit F3P" (http://www.rcgroups.com/forums/showthread.php?t=2304194) I present the "micro Bandit" under construction.
260mm wingspan
291mm lenght
Electronic I use :
Props : MCF3222 (microinvent)
Motor : 2g Hextronik brushless (winding modified)
Esc : MBC3 (microinvent)
RX : Deltang RX31
Lipo : Turnigy nano-tech 60mah
Servo : home made
Final weight estimed : 8~9g
To be continued...
Regards,
Mickael
DiAbLo3D is offline Find More Posts by DiAbLo3D
Old Feb 24, 2015, 05:30 AM
epilot is offline
Find More Posts by epilot
Remote island inhabitant
epilot's Avatar
Faroe Islands, Sandoy, Sandur
Joined Nov 2000
Wow, that looks amazing. Will you be adding any carbon rods to reinforce the structure?
When will servo kits be available?
epilot is offline Find More Posts by epilot
Old Feb 24, 2015, 09:23 AM
ror is offline
ror
Find More Posts by ror
ror
France, Languedoc-Roussillon, Thuir
Joined Aug 2009
He has to get his exam before !! Félicitation Diablo, tu envahis le marché américain !!
ror is offline Find More Posts by ror
Old Feb 24, 2015, 04:10 PM
I R Irv is offline
Find More Posts by I R Irv
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
Amazing is right, so are those servos.
If you put another hole at the other end of that pivoting arm it looks like a great aileron servo.
You should check this Thread for your 2gram motor.
http://www.rcgroups.com/forums/showt...=895413&page=3
I R Irv is offline Find More Posts by I R Irv
Old Feb 24, 2015, 04:35 PM
scousethief is offline
Find More Posts by scousethief
United Kingdom, England, Redcar
Joined Jan 2006
Nice , plane and nice little servos.
scousethief is offline Find More Posts by scousethief
Old Feb 24, 2015, 06:30 PM
scharlach is offline
Find More Posts by scharlach
Joined Jan 2005
nano servos
Looks like you got the servo weight down to 0.67 grams which is great. I like
your use of hall sensor/ small magnet for servo positioning. What motor are
you using dia & length.
You might take a look at the motor (3.2mm dia) and threaded shaft used
on Mini Vapor servo mechanics this should allow you to reduce weight
even more. The mini servo mechanics including motor are still available
on ebay. Let us know if you can supply the mini boards you have designed.
scharlach is offline Find More Posts by scharlach
Old Feb 24, 2015, 09:58 PM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
Excellent work on your skeletonized foam airframe (and in your other thread). You are doing amazing work on "skeletonized" linear servos. And, I like your method of converting the action to move a large bell crank for the ailerons.
Any further detail on the servos would be much appreciated. Are you injection molding those housings yourself? And, I assume those are custom boards to control them. Do you have an incredible workshop, or are you subbing out the pieces and assembling them yourself? Any plans to sell them, or kits for them?
Again, just amazing work.
Are you happy with the Micro Invent controller? When I did my AirBender a few years back I used a MI controller with a Gasparin motor. I was not happy with the way it behaved. When throttling back it would cut off at about 30% to 40% throttle, which was pretty abrupt. It was a very light but I didn't think the motor control was as smooth as it could be. I suppose it is possible they have improved their controller since then.
http://www.rcgroups.com/forums/showthread.php?t=1189227
On my current project I'm using the YGE controller. It is heavier. But, I've found them to be very efficient, and have very smooth control. It's possible to throttle back to virtually zero throttle and still get very smooth control.
http://www.rcgroups.com/forums/showthread.php?t=2306529
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Feb 25, 2015, 03:42 PM
DiAbLo3D is offline
DiAbLo3D's Avatar
Joined May 2005
Yes 0,5mm carbone rod or 0,3mm (I do not know yet) for reinforced the wings.
The servo has two hole on pivoting arm.
He is a pivoting servo
Thanks for the links.
For interested person, this is my test result with 2g brushless :
My config test :
Props : MCF3222
ESC : MBC3
Lipo : Turnigy nano tech 60mah 45C
1) 14T 0,2 : 2,2A ~17,5g (original engine)
2) 30T 0,1 : 0,8A ~9g
3) 20T 0,1 : 1A ~10g
4) 17T 0,1 : 1A ~10g
5) 17T 0,2 : 1,6A ~15g
I have not mesured the RPM...
I have retained solution "5"
I made 0,5g prototype, but not very reliable.
Current servo are reliable, (I think...not tested in endurance for the moment...) good wear resistance because it use balls bearings...brass piece...(I have made a few prototype before find a good mechanical solution !!)
Yes, I use hall sensor (allegro A1393) with small didel magnet (Ø1,2x0,8).
I use the motor and gear of mini vapor servo mechanic (PKZU1236)
I got the worm gear and brass piece on a 1,1g servo (HK).
I would like to clarify : I'm not the designer of electronics ; It's "uGlider" on RCgroups forum. I just designed the mechanics. Originally the servo are designed for micro glider. I juste worked with "uGlider" for adapted the micro servo for my utilisation. (thank you to him !!!)
Gordon
The structure of the servo is mix between 0,5 and 0,3mm carbone plate.
All piece is cutting with CNC by a french workshop. (frcraft)
No kit available. But I have possibility, if you are interested, post a .zip file with all file for build the servo. (If I have the time ...)
It's my first Micro Invent controller, for the moment I just try in static test, he looks very well.
I have choice the Micro Ivent controller because is very light and very small !
I like your "Airbender" very beautiful, very good work !
I will read the post quietly.
PS1 : I joined a few pictures "en vrac" first prototype...under construction...etc...
PS2 : Video of my servo's visible on my YouTube channel https://www.youtube.com/channel/UC2R...MkesmnEig3rqJg
PS3 : Sorry for my verry bad english
Old Feb 26, 2015, 03:22 AM
DiAbLo3D is offline
DiAbLo3D's Avatar
Joined May 2005
Electronic installation in progress....
I have no rush carbon 0.5mm in stock...
He'll have to wait to continue this weekend
Old Feb 26, 2015, 03:59 PM
maulionc is offline
Find More Posts by maulionc
Joined Oct 2002
Hello
What is the size of your servo?
Charles
maulionc is offline Find More Posts by maulionc
Old Feb 27, 2015, 02:16 AM
DiAbLo3D is offline
DiAbLo3D's Avatar
Joined May 2005
For Charles
Old Feb 28, 2015, 05:09 PM
DiAbLo3D is offline
DiAbLo3D's Avatar
Joined May 2005
Ready to fly !
Weight : 8,2g
Wing loading : 4,4g/dm²
Old Feb 28, 2015, 05:33 PM
ror is offline
ror
ror
Joined Aug 2009
splendide ! Là tu les as mouchés les ricains !! Tu l'as testé ?
Old Feb 28, 2015, 06:13 PM
Boston, Mass
Joined May 2001
That came out excellent in every way. You have set the bar for micro F3P planes. Your workmanship is very good. Looking forward to hearing how it flies, and maybe a video if you can.
Gordon
Old Mar 01, 2015, 05:45 AM
epilot is offline
epilot's Avatar
Joined Nov 2000
Good luck with the maiden flight.
If you find you need more power, then a geared 6mm motor will give you more thrust at lower amps. The weight is app. that same as BL motor + BL ESC. The 6mm motor and gearbox from AEO RC is 2.3grams.
Sold Graupner Taxi 2400 Big 95" wingspan Tow Tug, Aerobat, FUN!! LaxLife Aircraft - Electric - Airplanes (FS/W) 1 Jan 23, 2015 02:56 PM
Discussion Idea - what if micro aces did scale profile aerobatic and 3 planes desmo 3D Foamies 0 Oct 08, 2014 09:16 AM
Cool Video - F3J aerobatics vs. Touch & go with a 6m wingspan mustang_jmz Slope 9 Oct 18, 2013 07:25 AM
Discussion Suggestions for new foamie aerobatic plane around 50" (wingspan) APD Foamies (Kits) 2 Sep 03, 2013 04:14 PM
Wanted NIB Aerobatic or 3D plane with 58"-72" wingspan scharck Aircraft - Electric - Airplanes (FS/W) 6 Mar 24, 2011 08:18 PM
