Old May 21, 2015, 03:07 PM
L Austin France is offline
Find More Posts by L Austin France
France, Brittany
Joined May 2013
Originally Posted by JohnRB View Post
Option 1 is to remove an SMD resistor (R24) and rotate it so that only one side of the resistor is soldered to the pad farthest from the edge of the board (resistor will now be covering the silk screen for R24) and then solder a wire for the GEAR pin to the free end of the resistor as shown by the red line in the first photo.
Option 2 is to completely remove R24 and discard, then add a discrete 10K resistor between the GEAR pin and the pad (farthest from the board edge) where R24 was soldered as shown in the second photo.
The attached JPG is a capture from the document referenced in the link if you need a better photo or more detail.
John
Thanks John.
I've just opened up the unit & blimey, aint it small! I can see the R24 thing you mention but only with a 10x loupe but can't see how it's soldered to the pcb. I've got a tiny soldering iron but not sure If I will be able to see what I'm doing to unsolder it. I can see that if I unsolder one connection & lift it a bit the rest is easy. Is there enough space below it to cut the connection? Any tips how to achieve this mod ?
Vic
L Austin France is offline Find More Posts by L Austin France
Old May 21, 2015, 03:43 PM
JohnRB is online now
Find More Posts by JohnRB
United States, NC, Raleigh
Joined Oct 2011
Yes, the parts are tiny. The small black resistor has small silver colored ends which are soldered to the board by a reflow process in an oven. The easiest way to remove these is with 2 small soldering irons so you can heat both ends at the same time,
Once removed you will see the two tinned pads on the printed circuit board where the resistor was soldered.
Removing the resistor disconnects channel 6 from the AUX (on/off) input to the stabilizer.
You can then solder a small 10K resistor to the pad closest to the R24 silk screen text and the signal pin for channel 5 (Gear).
It is probably best to do this work under a magnification lamp.
Good Luck,
John
Originally Posted by L Austin France View Post
Thanks John.
Vic
JohnRB is online now Find More Posts by JohnRB
Discussion 3 axis stabilizer by HK Early Electric Plane Talk 17 Nov 18, 2012 02:11 PM
New Product OrangeRX 3-Axis Flight Stabilizer 14g (advertised) nemoskull Scratchbuilt Indoor and Micro Models 7 Sep 21, 2012 09:50 PM
Discussion Eagle A3 Aeroplane Fixed-wing Micro Flight Controller Board W/ MEMS 3-axis gyro eyeinsky1 Aerial Photography 3 Jun 06, 2012 03:38 PM
Sold CPD-4 Co-Pilot 2 axis flight stabilization system ecampos FPV Equipment (FS/W) 6 Oct 26, 2011 01:34 PM
Discussion ******* 3 axis gyro stabilized video gimbal powerblimp Aerial Photography 10 Feb 23, 2006 06:00 AM
