Old Feb 24, 2015, 08:17 AM
SeByDocKy is online now
Find More Posts by SeByDocKy
SeByDocKy's Avatar
France, PACA, La Valette-du-Var
Joined Dec 2012
Mini-Review
EACHINE FPV200 kit (under construction)
INTRODUCTION
BG recently announced a very cheap bundle FPV200 dedicaced to any DIY FPV plateform and including
i) a 700TVL light camera (NTSC/PAL available)
ii) a 32CH 200mW 5.8G nano-VTX
Everything is sold actually for 23 USD. This mini-review will show prelimary results of this bundle and what we can expect from this cheap combo.
BOX CONTENT
+ 1 x 700 TVL camera (10.8g)
+ 1 x 32CH 200mW 5.8G VTX (6.5g with RP-SMA connector)
+ 1 x 5.8G dipole antenna
+ 1 x Power cable
+ 1 x Instruction manual (English)
OVERVIEW
All the system scales approximatively 32g (with default antenna and cable)
Video transmitter
front side
The VTX provided a regularized +5V output filtering out also motor inférences.
back side
A unique button permit to cycle between channels and bands. 2 diodes indicate the current selected band and channel respectively.
To change a band, you need to press more than 2s on this button. The VTX used a RP-SMA connector.
weigth standalone
with the dipole antenna
Camera
front side
back side
No real indication in the specification about the light sensitivity. I found it excellent and comparable to some 0.01Lux camera I own to give you an indication
A 10.8g camera standalone
The lens mount is a M12
Distance between screw holes
UNBOXING
EACHINE FPV200: 700TVL cam + 200mW 5.8G 32CH combo (Courtesy Banggood) (11 min 7 sec)
POWER MEASUREMENTS
EACHINE FPV200 emitted power measures (Courtesy Banggood) (6 min 34 sec)
CONCLUSIONS
I was impressed by the quality of this bundle especially by the camera offering a good light sensitivy and a clear and precize everything under 23 USD !!!!. You can't really by wrong with this bundle. The VTX is warming a lot from 3S powering and IMHO can be seriously damaged if not correctly cooled correctly at least by a correct air flow. Emitted power are relatively constant for all channels (< than 5% of deviation). I would prefer to have a normal JST plug instead of this method to use a 3S lipo only via the balancer plug.
PROS
+ Clean, clear and precize transmitted video
+ Good camera with a large FOV, 700 TVL and good light sensitivity (around 0.01lux IMHO)
+ Light bundle (under 32g everything included)
+ Tiny 32CH 200 mW 5.8G VTX without interférences (like some TX5823)
+ Unbeatable price
CONS
- Can be powered only with a 3S balancer plug
- VTX warming a lot in 3S configuration and above
- No OSD to tune the camera settings
This FPV bundle have been courtesy provided by Banggood in order to make a fair and not biased review. I would like to thanks them for this attitude.
You can find it actually for 23 USD at
http://www.banggood.com/Eachine-700TVL-13-Cmos-FPV-110-Degree-Camera-w32CH-Transmission-p-965760.html
SeByDocKy is online now Find More Posts by SeByDocKy
Old Feb 24, 2015, 08:18 AM
SeByDocKy's Avatar
Joined Dec 2012
Reserved for photos, videos and mods
Old Feb 24, 2015, 10:25 AM
trase is offline
Find More Posts by trase
Joined Aug 2012
Thank you for the review. Seems like a nice kit.
Would it be possible to power it with a 2S battery?
I'm thinking if it would be possible to use on a V666. Have you tried if the V666 monitor can pick up the transmission without any modifications?
trase is offline Find More Posts by trase
Old Feb 24, 2015, 10:45 AM
SeByDocKy's Avatar
Joined Dec 2012
If you mod the power connector yes.
Old Feb 25, 2015, 04:50 PM
n-2-stuff is offline
Find More Posts by n-2-stuff
Scott
n-2-stuff's Avatar
Clovis,Ca.
Joined Sep 2006
Thanks for the review. Does it stay on the last channel used?
n-2-stuff is offline Find More Posts by n-2-stuff
Old Feb 26, 2015, 12:49 AM
SeByDocKy's Avatar
Joined Dec 2012
Yes
Old Feb 26, 2015, 11:50 AM
Scott
n-2-stuff's Avatar
Clovis,Ca.
Joined Sep 2006
Thanks.
Old Feb 27, 2015, 01:02 AM
MrCaCkO is offline
Find More Posts by MrCaCkO
Joined Feb 2015
Could somebody be that kind and tell me what else do i need to buy for this FPV kit does the "thing" thats intended to I know that i need a monitor too
MrCaCkO is offline Find More Posts by MrCaCkO
Old Feb 27, 2015, 05:29 AM
SeByDocKy's Avatar
Joined Dec 2012
Probably some CL antennas would be a better choice (tackle better multipaths situation)
http://www.banggood.com/5_8G-3-Leaves-Omnidirectional-Gain-Antenna-p-73560.html
Choose probably (90 degrees connector) a L-type RP-SMA for this VTX bundle
.... For your groundstation VRX... either an FPV monitors or goggles .... but prefer 32CH models and even better including a diversity system
and CL antenna
http://www.banggood.com/5_8G-4-Leaves-Omnidirectional-Gain-Antenna-p-73559.html
More in W-type ...
Old Feb 27, 2015, 10:49 PM
rockflys is online now
Find More Posts by rockflys
United States, TX, Spring
Joined Feb 2014
Im considering purchasing this system with this receiver.http://www.banggood.com/Aomway-RX004...-p-953562.html in a H8C quad. Would the 3 leaf clover antennae set you recommend work on the receiver as well? Also, can I use the 4 leaf antennae on the reciever and a 3 leaf on the transmitter. Thanks for your advice, SeByDocky.
rockflys is online now Find More Posts by rockflys
Old Feb 28, 2015, 02:54 AM
SeByDocKy's Avatar
Joined Dec 2012
Usually it's 4 leaf for the RX, 3 for the TX ...but it's 4 for both .. it won't make a big difference IMHO
Old Feb 28, 2015, 08:07 AM
Joined Feb 2014
Glad for the information I didn't think it would make a difference but I did notice that the transmitter uses a RP-SMA antennae and the receiver uses a SMA antennae . I'm not sure what the difference is other than the nomenclature. I ordered the 3 leaf you suggested for the transmitter and the 4 leaf you suggested for the Aomway receiver.
Old Feb 28, 2015, 12:52 PM
SeByDocKy's Avatar
Joined Dec 2012
The aomway receiver uses a SMA connector AFAIK ...be aware
Old Feb 28, 2015, 01:39 PM
Joined Feb 2014
What does AFAIK mean? I ordered a male SMA connector antennae (4 leaf) that you referred to in your recommended ground station antennae post. http://www.banggood.com/5_8G-4-Leave...a-p-73559.html
Old Feb 28, 2015, 02:01 PM
SeByDocKy's Avatar
Joined Dec 2012
AFAIK = As FAr I Know ....
So if you ordered the SMA version for the receiver, it's perfect
Mini-Review WLtoys V393, aka the V262 brushless (under construction) SeByDocKy Mini Multirotors 82 May 01, 2015 01:41 AM
Mini-Review UDI U941A "4-in-1" microquadcopter (under construction) SeByDocKy Mini Multirotors 7 Apr 16, 2015 05:11 AM
Build Log Jim Bourke his Extra 330LX under construction mcnowhere Electric Plane Talk 0 Nov 04, 2014 08:42 PM
