Old Sep 21, 2015, 10:50 AM
Scottychop is offline
Find More Posts by Scottychop
Newb
Scottychop's Avatar
United States, WA, Seattle
Joined Dec 2014
Y6
Thanks for the links, however they don't provide any info on what the pinout might be for Y6. There is plenty of info for OTHER multiwii boards, not the flip1.5.
On the RTF wiki Paul describes using some of the receiver pins for certain motor layouts, not just the regular motor pins. I have not gotten that far into Arduino /Multiwii to know how to reassign or even find orginal layouts.
Scottychop is offline Find More Posts by Scottychop
Old Sep 21, 2015, 01:07 PM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Pins will be the same for all Atmega328 based MultiWii controller. The easier is still to go to www.multiwii.com and scroll down to the Y6. The left column is for Atmega328 and the right Mega boards. We also made new one's in our Electronics & Wiring guide but not the Y6.
Dialfonzo is offline Find More Posts by Dialfonzo
Old Sep 21, 2015, 01:27 PM
Newb
Scottychop's Avatar
Joined Dec 2014
Thanks!
I hadn't seen that. D5 and D6 are what I have been using for my receiver. Would I have to go with an S-ppm receiver then? I am using a lemon DSM2 right now.
I was hoping to use the A0-2 pins and keep my lemon.
Old Sep 21, 2015, 01:49 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Thanks!
[]http://www.multiwii.com/wp-content/uploads/2011/01/Y6_328.jpg[/IMG]
[]http://www.readytoflyquads.com/media/wysiwyg/2012-10-26_16-20-17_small.jpg[/IMG]
If you look in your "config.h" you will find the following that you can define:
Code:
    /**************************    Hexa Motor 5 & 6 Pins    *******************************/
      /* PIN A0 and A1 instead of PIN D5 & D6 for 6 motors config and promini config
         This mod allow the use of a standard receiver on a pro mini
         (no need to use a PPM sum receiver) */
      //#define A0_A1_PIN_HEX
D5 = A0 and D6 = A1
Old Sep 21, 2015, 03:01 PM
Newb
Scottychop's Avatar
Joined Dec 2014
Perfect! The help is much appreciated.
Old Jan 05, 2016, 09:16 PM
adannm is offline
Find More Posts by adannm
Joined Aug 2015
Hello all
i have fried an INPUT pin(pitch) on my flip1.5 and was wondering if and how to remap the pitch input to a different pin say my open aux 2 channel.
any help appreciated
thanks
adannm is offline Find More Posts by adannm
Old Jan 05, 2016, 09:38 PM
waltr is online now
Find More Posts by waltr
Team AlienWarpSquad
United States, PA, Doylestown
Joined Jan 2014
Originally Posted by adannm View Post
Hello all
thanks
It may be possible to re-map the pitch to an AUX.
I know how to do this with a serial PPM RX but not with a PWM RX.
Look at and study the RX.CPP file. This is where the input pins for the RX are defined and used. You should also go to the MultiWii Forum to search for a way to move an RX channel to a different pin.
Finally, it may be just easier to buy a new Flip 1.5 MWC. These are pretty cheap (15USD) and get a spare.
waltr is online now Find More Posts by waltr
Old Jan 05, 2016, 10:04 PM
boaterguy is offline
Find More Posts by boaterguy
Thermite + ice = Big boom.
boaterguy's Avatar
Canada, ON, Ottawa
Joined Apr 2009
May be as simple as changing :
static uint8_t rcChannel[RC_CHANS] = {ROLLPIN, PITCHPIN, YAWPIN, THROTTLEPIN, AUX1PIN,AUX2PIN,AUX3PIN,AUX4PIN};
to
static uint8_t rcChannel[RC_CHANS] = {ROLLPIN, AUX2PIN, YAWPIN, THROTTLEPIN, AUX1PIN,PITCHPIN,AUX3PIN,AUX4PIN};
But I haven't tested and I don't know enough about the multiwii code to guarantee it.
boaterguy is offline Find More Posts by boaterguy
Old Jan 06, 2016, 08:51 AM
waltr is online now
Team AlienWarpSquad
Joined Jan 2014
boaterguy,
I was looking for something like that in the source code but didn't find it.
Which MW version and which file is this in?
Old Jan 06, 2016, 09:11 AM
boaterguy's Avatar
Canada, ON, Ottawa
Joined Apr 2009
Originally Posted by waltr View Post
boaterguy,
Versions 2.3 and 2.4 are similar, in RX.cpp, right near the top.
There's a comment for //standard channel order, that is likely where it should go since you're using parallel PWM.
Old Jan 06, 2016, 10:48 PM
adannm is offline
Joined Aug 2015
to
thanks allot i will try it out
Old Jan 06, 2016, 11:22 PM
adannm is offline
Joined Aug 2015
IT worked thanks
Old Jan 07, 2016, 08:41 AM
waltr is online now
Team AlienWarpSquad
Joined Jan 2014
IT worked thanks
Great.
boaterguy nailed it.
