Old Jul 10, 2014, 06:51 PM
United States, OR, Tualatin
Joined Apr 2005
Build Log
RJM Systems Quicksilver wood fuse
This is a "retro" build of a wood fuse Quicksilver from laser cut sides, 1/64th doublers, and lite ply formers.
TomFlyer is offline Find More Posts by TomFlyer
Old Jul 10, 2014, 09:43 PM
Joined Apr 2005
Next steps: Add the 1/4 triangle stock to the edges of the sides, flush with the top / bottom of the fuse. I used gap fill CA as it give a few seconds of working time and enough time so you do not get your fingers stuck to the wood. I started and stopped the triangle stock at the changes in side wall thickness. The formers need a little sanding to fit and to remove the laser cutting flash.
Old Jul 10, 2014, 10:52 PM
slopemeno's Avatar
Joined Jan 2003
I sense a Quicksilver resurgence...I have two (one wood, on FG), plus a short kit, plus a set of plans.
slopemeno is offline Find More Posts by slopemeno
Latest blog entry: Goat Rock Threads
Old Jul 11, 2014, 01:00 AM
Joined Apr 2005
And a new set of RG14 cores
Old Jul 11, 2014, 01:20 AM
Joined Apr 2005
The triangle stock needs to run past the end of the angled back of the fuse so it can be sanded at the correct angle.
Old Jul 11, 2014, 01:24 AM
slopemeno's Avatar
Joined Jan 2003
Got 'em!
Old Jul 11, 2014, 11:54 AM
Joined Apr 2005
Nose former added on a simple home made "jig" . This is the time to get the fuse symmetrical.
Old Jul 12, 2014, 02:38 AM
Joined Apr 2005
progress
Nothing fancy here.
Old Jul 13, 2014, 03:24 PM
Joined Apr 2005
Quicksilver tail group
While the fuse side reinforcements are drying, I started on the fin and stabilizer. Both are 1/8 inch thick Balsa with a 1/8 x 1/8 basswood LE.
Old Jul 13, 2014, 03:32 PM
Joined Apr 2005
More Fuse work
The order of balsa from National Balsa came with 1/8" light ply to protect the balsa sheets that I ordered. It did the job as the box had signs of being beat up but the balsa in side was fine. Anyway, the light ply is perfect for the bottom of the fuse from in front of the wing to the nose. This replaces the recommended 1/64 ply covered with 1/8" balsa. BUT the light ply is not as flexible as the balsa, so I utilized some old build method to bend the light-ply. I soaked it in Ammonia but in a sandwich bag to avoid the fumes. The Ammonia penetrates but then evaporates faster than water, which can also be used.
Old Jul 13, 2014, 07:19 PM
Joined Apr 2005
Elevator modification
Stock split elevator needs a torque rod to function. Since I am making the tail group removable for travel, the fin and stab and elevator will be all one unit. The continuous elevator needs to have the center section filled in. I did this with a piece of 1/8" balsa to match the two sides. I glued a strip of 1`/64 ply to one side full length and then sanded the balsa down to the 1/64 ply at the back edge.
Old Jul 14, 2014, 08:45 AM
Joined Apr 2005
Fuse almost done
Glued on the light ply with 5 minute epoxy and the 1/8" sheeting with gap filling CA. A new trick for me: When applying the gap filling CA to one surface, do it in a zigzag line and then use the side of the CA application neck to spread out the CA so you have 100% coverage.
Old Jul 20, 2014, 05:58 PM
Joined Apr 2005
Nose Block
For the nose block I used a piece of Doug Fir 2x4 that had been sitting around in my shop for a year or two, so it was dried out.
Old Jul 23, 2014, 12:54 AM
Joined Apr 2005
Now the question becomes, how do I finish a balsa fuse
1. Sandable Primer epoxy paint, then a final coat?
2. Cover the balsa with an iron on covering? (seam )
3. Cover the balsa with clear laminating film and paint that? (seams )
4, Cover with SolorTex iron on and paint that ? (seams )
5. Fiberglass sleeve and epoxy and use shrink tube for a smooth finish
Since I want the fin and stabilizer to be removable, maybe a combination of #1 with a removable fiberglass sleeve made over the last 6 to 8 inches of the fuse for the tail feathers to attach to? That should work?
Sold short kit..from rjm systems .$35 .........san diego warhawk crazy Aircraft - Sailplanes (FS/W) 3 Jul 28, 2013 02:22 PM
Discussion new Detonator from RJM Systems aka RCbobcat55 rcbobcat55 Slope 0 Feb 26, 2013 08:58 PM
New Product MSR slope ship from RJM Systems rcbobcat55 Slope 5 Oct 11, 2012 11:48 PM
New Product New MSR slope ship from RJM Systems rcbobcat55 Slope 3 Oct 02, 2012 12:54 PM
For Sale New 2M Dyne-O-Mite from RJM SYSTEMS rcbobcat55 Aircraft - Sailplanes (FS/W) 3 Apr 19, 2012 07:16 PM
