Old Nov 08, 2014, 09:14 PM
RCG Hover King
Eagle2Nitro's Avatar
United States, LA, St Francisville
Joined Apr 2014
Heeeere it is.
Eagle2Nitro is offline Find More Posts by Eagle2Nitro
Latest blog entry: RCG Hover King Title
Old Nov 09, 2014, 01:20 AM
"Free" in Christ! #F3P
Free's Avatar
United States, CA, SF
Joined Jan 2012
Originally Posted by Eagle2Nitro View Post
Thanks Free!
I finished my MX2, my first EPP profile build! Will upload pics presently.
The build looks good.
I think that on these EPP kits, 50-65% expo is what you should run. Tell us how the flights go.
Free
Free is offline Find More Posts by Free
Old Nov 09, 2014, 11:17 AM
RCG Hover King
Joined Apr 2014
I maidened it this morning, and it was great! It was a little lacking of power with the Hyp 2S 240, then I tried the Hyp 330s, MUCH better. I'm running the UMX Pitts powerplant, with the UMX MiG brick and servos. What are your guys AUWs? Mine seemed a little heavy, at 77 grams. It also seemed a little lacking in rudder throw, but with any more, the rudder hits the elevator.
I am using the max possible throws, and expo:
Elev: 50%
Ail:30%
Rudd:15%
Old Nov 10, 2014, 10:09 AM
motorhead's Avatar
Kansas, USA
Joined Sep 1999
Try it without the rudder expo and maybe play with moving the CG back just a little and see if you like it.
motorhead is online now Find More Posts by motorhead
Old Nov 10, 2014, 11:43 AM
RCG Hover King
Joined Apr 2014
Thanks, I just realized that there is a TON of slop in the rudder pushrod, due to the large bend I had to make. I will post pics soon, to show what I mean.
EDIT: I took the pushrod apart before I remembered to take pics. I had a huge z-bend in the wire part of the pushrod, to bridge the vertical gap between the rudder servo, mounted on the fuse, and the rudd control horn. The z-bend kept flexing, causing the slop.
How am I supposed to route the pushrod between the rudd servo, placed on the horizontal fuse, and the rudder control horn, up high on the rudder??
Old Nov 10, 2014, 04:07 PM
RCG Hover King
Joined Apr 2014
I just looked through this thread at pics of other MX2s, and most of them have the pushrods angled up to meet the rudder control horn. I thought pushrods had to be a straight, level line from the servo arm to the horn.
Old Nov 10, 2014, 08:02 PM
motorhead's Avatar
Kansas, USA
Joined Sep 1999
Here is a good picture of the left side of my Mini Raptor showing the rudder pushrod install. The rudder horn has to be high enough to clear the elevator when it is full up. The pushrod is angled down a little but not much.
Old Nov 10, 2014, 09:56 PM
RCG Hover King
Joined Apr 2014
Thanks, I just reinstalled the pushrod, angling it up from the servo to the horn. It seemed to work fine, so I stepped outside and ran a few batteries through her. MUCH better, without all that slop.
Your MX2 is really a great plane! I had a few "encounters" with the ground, trying low-and-slow 3D, (too low-and-slow) and no damage whatsoever. These 3D EPP profiles are a lot tougher than they look!
Old Nov 11, 2014, 08:45 PM
Gunslinger6767's Avatar
Joined Nov 2014
Dude i want one ... Will the running gear fit from my parkzone
Mini t28 trojan
Gunslinger6767 is offline Find More Posts by Gunslinger6767
Old Nov 11, 2014, 09:52 PM
RCG Hover King
Joined Apr 2014
It wont have nearly enough power. These 23" kits were designed for 2S Brushless UMX guts.
Sold NEW Fancy Foam Andrew Jesky Blender BIPLANE wolfcbr2003 Aircraft - Electric - Airplanes (FS/W) 11 Mar 14, 2012 07:13 PM
Sold ... cam17 Aircraft - Electric - Airplanes (FS/W) 1 Feb 29, 2012 11:43 PM
Wanted UMX guts for micro beast TMAC4123 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 5 Feb 29, 2012 06:36 PM
Sold SOLD - Fancy Foam Vrolet V1 F3P 3D kit with servos - $45.00 Shipped and Insured. GTMAXX Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Feb 29, 2012 10:28 AM
Question Looking for build for Fancy Foam Sbach 1.3 dan n 3D Foamies 1 Jan 07, 2012 07:09 PM
