Old Nov 28, 2005, 07:05 PM
Peace
tioli's Avatar
Kona, Hawaii
Joined Aug 2005
Hirobo Sceadu 30 Tail Boom Question
Hi all,
I built a Hirobo Evo Sceadu 30 from a kit. My question is: The tail rotor and stabilizer blade is canted at a slight angle to the left (When viewed from the rear, the top of the vertical stabilizer is canted to the left as is the the tail rotor assembly). Is this normal?
The tail boom is keyed so it can't be mis-aligned. I also removed the tail boom and swapped ends with the same result.
d
tioli is offline Find More Posts by tioli
Old Nov 29, 2005, 04:21 AM
Joined Nov 2005
No this is not normal.
Do not attept o fly this thing.
You need to loosen the 4 bolts on the frame that holds the boom secure. Then twist the boom until it is parallel to your main shaft (vertical fin) then re-tighten the 4 bolts on the frame . Dont forget to check the tention of the belt at the same time.
Eddie.Heli is offline Find More Posts by Eddie.Heli
Old Nov 29, 2005, 10:42 AM
Long Island
Joined Nov 2003
I agree. This is not normal. I have the Evo .50 which is almost identical to the .30. Even though the boom is keyed there is play in it. You may have to loosen the bolts on the frame and rear gear box to get enough play to make it even.
techguy is offline Find More Posts by techguy
Old Nov 29, 2005, 12:24 PM
Peace
tioli's Avatar
Kona, Hawaii
Joined Aug 2005
Thank you guys.
d
Old Nov 29, 2005, 10:38 PM
Peace
tioli's Avatar
Kona, Hawaii
Joined Aug 2005
Found out from Hirobo on RunRyder, that there was a batch of defectively cut tail booms sent out...I'll dremel the keyhole and make 'er fit. Hirobo is sending out a replacement boom, i'll save it for the crash kit.
d
F/S hirobo sceadu 30 w/ upgrades and a bunch of new parts 475 shipped nitrodude71 Aircraft - Fuel - Helis (FS/W) 2 Mar 17, 2005 06:12 PM
Hirobo Sceadu .30 RCAviator23 Fuel Heli Talk 4 Jan 05, 2005 09:11 PM
Yippee! Hirobo Sceadu 30/50 $225 shipped SKYBOSS Aircraft - Electric - Helis (FS/W) 0 Sep 08, 2003 08:32 PM
