Old Jun 17, 2014, 05:18 PM
Joined Feb 2006
I just bought the jetcat p20 that was listed here, wanted to know if someone has a
HET F-20 tigershark here that can give me the measurements in the back where the 70mm edf unit goes. I want to see if I can put the p20 turbine inside of it. HERE is the link to the JETcat P20 specs. I can point the kero plug toward the rudder area. THIS would be super cool jet as a turbine. I use to have one and use to handlaunch it.
IF it does not pan out with the F-100 I want to try it into this. SO if there are guys out there that own this please tell me the measurements i want to see if i can get this in there.
http://www.jetcatusa.com/p20se.html
sherlockshah is online now Find More Posts by sherlockshah
Old Jun 17, 2014, 10:37 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
my full composite F-20 that i make is 47" long and the tail pipe is @2.100" on the ID. how much does the power system weigh?
AIR SALLY is online now Find More Posts by AIR SALLY
Old Jun 17, 2014, 10:47 PM
Joined Feb 2006
the engine weight is 13oz
i will have it thursday, 20oz of fuel should be plenty for a nice 7min flight.
Old Jun 18, 2014, 11:13 AM
wannabe Jet guy
CRCJA's Avatar
Green Valley, AZ
Joined Aug 2004
Yeah, I guess I should say it now, You want to the 90MM F-20 for that instead of the 70MM F-20
Ralph
CRCJA is offline Find More Posts by CRCJA
Old Jun 18, 2014, 12:55 PM
Joined Oct 2009
I would stay away from the Het F20 unless you want a ball of smoldering splinters. It's made for a very light EDF setup. Mine broke apart in mid-air when I put a larger lipo in.
The air sally version is probably the minimum you will need.
nighthawk0077 is offline Find More Posts by nighthawk0077
Old Jun 19, 2014, 07:00 AM
Dr Honda's Avatar
Pittsburgh Allegheny, Pennsylvania, United States
Joined May 2004
Ralph
Yep...
Generally, you want a 90mm airframe over a 70mm... just so you have enough wing area to support the weight of the engine, and fuel.
Dr Honda is offline Find More Posts by Dr Honda
Old Jun 19, 2014, 12:55 PM
turbonut's Avatar
upland CA
Joined Dec 2004
The P20 will fit in any 70mm airframe with more room to spare then a edf set up. You just need to be able to get fuel in near the CG which is the hard part
turbonut is online now Find More Posts by turbonut
Old Jun 19, 2014, 07:52 PM
Joined Feb 2006
okay so i put into fly fly F-100 here is some pics
I just have to figure out where to put the tank. I wanted to put where the battery goes but I need part of the tank behind the cg so will have to figure something out. I just did a simple cuts that will be covered with the tail cone and will cut and sand down the tiny wood sticking out after the hysol dries. I flew it with 6s 4400mah 12 blade 1500kv motor it was good but very short flight.
Old Jun 19, 2014, 08:32 PM
Joined Feb 2006
video
fly fly f-100 hand launch on 6s powerful but went turbine (4 min 4 sec)
Old Jun 19, 2014, 11:43 PM
A-4 nut!!
skyhawk's Avatar
Vancouver B.C.
Joined Apr 2002
I see your engineering skills have not improved much. Kinda like your flying skills.
skyhawk is offline Find More Posts by skyhawk
Old Jun 19, 2014, 11:48 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
yeah that motor is going to push right through the foam ...some glass work in there would have helped.
Old Jun 20, 2014, 12:45 AM
Joined Feb 2006
its not done.
its going to be better will post pics.
Old Jun 20, 2014, 11:11 AM
United States, CA, Mission Viejo
Joined Jan 2005
Air Head is online now Find More Posts by Air Head
Old Jun 20, 2014, 11:12 AM
Joined Jan 2005
sorry not meant to post...just reading about another one of your gas builds in the electric threads
Old Jun 23, 2014, 11:54 PM
Joined Feb 2006
here is the video of the hand launch
FlyFly F-100 Hand Launch with a P-20 Mini Turbine (12 min 27 sec)
Discussion If you know someone who can't use their legs dll932 Life, The Universe, and Politics 3 May 16, 2014 01:30 PM
Discussion someone just bought my F-22 in the wheeling swap here in IL Please read sherlockshah Electric Ducted Fan Jet Talk 2 Jan 18, 2014 12:25 AM
Cool Jetcat P20 Turbine Glider Flight with Greg Leigh ChuckTseeker Fuel Jet Talk 1 Oct 16, 2013 01:25 AM
Discussion I just bought this Ultimate AMR and was wondering if I made the right deal? Tada Trader Talk 14 Nov 05, 2009 07:59 AM
Discussion who know hondaboy9tach or someone with that user name here? kogibankole Trader Talk 5 Nov 12, 2006 10:45 AM
