Old Apr 15, 2016, 08:51 PM
ThTx is offline
Find More Posts by ThTx
ThTx's Avatar
United States, TX, Seagoville
Joined Jul 2014
Question
Not Sure I Want To, But.......
I am not sure that I want to yet, but if I decide to convert a 3.4 meter, 3000 gram plane to electric, what motor/folding prop would anyone suggest? Not looking for 15 seconds to 200 meters. Just fly and float.
ThTx is offline Find More Posts by ThTx
Old Apr 15, 2016, 10:29 PM
scirocco is online now
Find More Posts by scirocco
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
Do you have a battery voltage in mind? As you'll likely want about 450W +, 3s or 4s can do the job at reasonable current.
What motor constraints are there? For example can a 35mm outrunner fit in the nose with enough clearance for the wires, or is the nose so skinny you're limited to a geared 28mm inrunner.
As a canned example, a Turnigy SK3 3858-840 glider drive with a 14x8 60A ESC and 3s 3300 would use about 530W and give all the performance you'd need
scirocco is online now Find More Posts by scirocco
Old Apr 16, 2016, 02:21 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
+1 for the above, had such combo in a 2200 grams 3m BoT and was too powerful.
renatoa is offline Find More Posts by renatoa
Old Apr 16, 2016, 07:57 AM
ThTx is offline
ThTx's Avatar
Joined Jul 2014
Thanks. That is the information I was looking for. The nose is actually quite roomy as it is a Minimoa I am thinking about converting. I haven't decided for sure, yet. But where I fly, it is basically electric or use a high-start. I know of several possible ridges, but all are on private land or covered by high voltage lines. The SK3 sounds like the perfect thing as I am planning on either 3s or 4s power.
Old Apr 16, 2016, 03:29 PM
renatoa is offline
Joined Sep 2007
Please, don't electrify a Minimoa !
A prop in that nose will destroy the look of the plane...
Old Apr 16, 2016, 04:26 PM
ThTx is offline
ThTx's Avatar
Joined Jul 2014
You are most probably correct. It is a hard decision. As I said, I haven't decided, yet. The plane is bought, but not delivered. I should have it by the end of next week or first part of the week after. It is my first scale glider, so I am very hesitant about modifying it. If I can get any time aloft at all with a high start, I will probably leave it as is.
Old Apr 17, 2016, 05:21 AM
renatoa is offline
Joined Sep 2007
I would rather think to a retractable pylon instead nose prop... you have plenty of space in that fat fuselage...
http://www.icare-rc.com/self_launch_systems.htm
Old Apr 17, 2016, 04:06 PM
ThTx is offline
ThTx's Avatar
Joined Jul 2014
Renatoa, that is nice. But cost prohibitive. I could get a custom spinner made to match the original nose shape for a lot less. Anyway, I am going to fly it from a high-start for a while first. And I have others to finish and fly with motors. I am not going to do anything for a while. Just wanted to know what people thought were good options for the weight and span.
Old Apr 25, 2016, 08:48 PM
ThTx is offline
ThTx's Avatar
Joined Jul 2014
Picked up the Minimoa today. Just took ten hours of driving to get there and back! Houston traffic has to be the worst in Texas! Oh, well I am back home and the plane is safely stashed for now. I need o get it fitted out and balanced. Then take it for some hand tossing at the flying field to try to get it trimmed. Pretty heavy plane for us old guys to be hand tossing, though.
Old Apr 26, 2016, 08:53 AM
Fly Wheel is offline
Find More Posts by Fly Wheel
Ochroma Pyramidale Tekton
Fly Wheel's Avatar
Blackstock, South Carolina
Joined Sep 2007
Originally Posted by ThTx View Post
<Snip!>Pretty heavy plane for us old guys to be hand tossing, though.
Hi-Start (or Up-Start if space is limited)?
Fly Wheel is offline Find More Posts by Fly Wheel
Old Apr 26, 2016, 09:35 AM
Mark Wales is offline
Find More Posts by Mark Wales
Glider Guider
Mark Wales's Avatar
United States, NC, Cape Carteret
Joined Feb 2002
I just refurbished a 3m, 2376 gram plane and it flies great and lands like a dream with crow. It doesn't rocket into space, but has no problem getting up at all.
http://www.rcgroups.com/forums/showthread.php?t=2650727
Mark Wales is offline Find More Posts by Mark Wales
Discussion Don't need one ... not sure I'd want one ... but I'm sure someone will logan5 Life, The Universe, and Politics 6 Feb 29, 2016 08:35 PM
Discussion Wanting Something but not sure what. horacer7 Parkflyers 0 Jul 05, 2010 07:06 PM
Discussion I want to buy a T-REX 600, but not sure what do i need. mixgreens Electric Heli Talk 20 Mar 13, 2008 10:47 PM
