Old Sep 22, 2015, 02:38 PM
Deano N is online now
Find More Posts by Deano N
Deano N's Avatar
NW UK
Joined Mar 2009
Spinner on an edf
What's the purpose of the spinner on an edf where the rotor is already held by an alternative fitting ?
I've done some searching on the subject, even researching the purpose of spinners on real turbofans, but I can't find any detail for edfs as far as efficiency/purpose is concerned.
There's people who say that you mustn't run without a spinner, but give no reason and there's a few people saying they run without and can see or feel no difference or problems.
Deano N is online now Find More Posts by Deano N
Old Sep 22, 2015, 03:11 PM
bandetlol is offline
Find More Posts by bandetlol
United States, TX, Irving
Joined Mar 2015
Aerodynamics?
Air is moving through the duct at like 100mph, there will be wind resistance that will kill your edf's efficiency.
bandetlol is offline Find More Posts by bandetlol
Old Sep 22, 2015, 03:46 PM
turbonut is offline
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
I would say reduce not kill...many people fly with out them
Old Sep 22, 2015, 03:47 PM
St. Martin is offline
Find More Posts by St. Martin
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
Oliver at WeMoTec says there is no difference. But...I like them for dynamic balancing. Rotors may be balanced, but not all motors. Clocking the spinner gives that final smoothness. It can make quite a difference in the sound and volume of the fan vs not having one. And the more power(watts) that are being consumed, the more noticable.
Fuzz
St. Martin is offline Find More Posts by St. Martin
Old Sep 22, 2015, 04:41 PM
Deano N's Avatar
NW UK
Joined Mar 2009
Interesting replies so far.
I must admit to struggling to see how much difference a spinner would make, since the air is still flowing down the duct and hitting the face of the fan disc.
I can see that maybe some air that otherwise would hit the flat face of the hub area and perhaps slow down and become turbulent would be directed more smoothly into the fan but I wonder just how much difference it makes and it seems from at least one reply, in practice it makes no difference so long as the rotor is properly balanced.
I can also now see the balancing issue from a positive aspect. I was only considering the balancing as a negative, since I was just seeing it as another component to not only balance but add another fastener and a little more weight.
It's probably quite obvious that I'm quite new to edfs and I've spent quite a bit of time researching and getting my current fan balanced. Certainly I've found that trying to balance a 90mm cs12 with a loose fitting, off centre adapter is a nightmare .
Old Sep 22, 2015, 05:07 PM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
You find lot of opinions here! Some good some not so.. But nothing better then testing for yourself! For me I try to keep the spinner. Even if most could never notice the difference in flight. But I also try to get every little bit i can..The only time not having a spinner is good is if you cant get it ballanced or it has flaws and can fail .But that is just my 2 cents
Old Sep 22, 2015, 07:34 PM
4stripes is offline
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
I also try to make the spinner work but in some cases the plastic versions can crack if tightened just once too tight. If you see any stress (crack) in a plastic spinner, you are better off without it.
As for a loose fitting adapter, the only solution is to make it solid! If that means glue it on, so be it. Once it stops moving then you can balance it.
4stripes is offline Find More Posts by 4stripes
Old Sep 22, 2015, 07:48 PM
Big gov never Works
St. Martin's Avatar
Joined Jul 2002
According to Oliver, the airflow does not hit the face of the hub, with no spinner. Pressure builds in front of the hub and flows around it. Almost the same thing happens at the rear of the motor, except in low pressure. I have noticed no measurable difference in performance. If there is, you would have to have a laboratory in flow dynamics to measure it.
As an example, recent aluminum spinners that are included with WeMoTec fans, have faulty spinners. They are out of round. They will not "clock". So I have had to use the old Pro aluminum spinners, or the even older plastic version. But the new EVO rotors work just fine, sans spinner.
On the use of the plastic spinners. It is true they will crack and virtually explode, if the retaining screw is over tightened or allowed to. I have used them with no problems up to 800W. But, with an ESC that allows soft start-up. Instant start will tighten the screw to the point of causing the spinner to fail.
Also, A very small dab (use a pin to apply)of red thread sealer on the threads, clock the spinner, and let sit over night. This will not allow the spinner screw to self tighten, and still be removable. Besides, soft start sounds much more realistic. Real jets do not have a rev-up like a small block chevy...
Fuzz
Old Sep 23, 2015, 02:28 AM
Deano N's Avatar
NW UK
Joined Mar 2009
Fuzz
That's good info. Thanks.
I've just balanced up my spinner and it's no wonder it put the balance out so much when I initially fitted it because it's certainly taken quite a lump of epoxy inside.
Old Sep 23, 2015, 03:56 AM
jofro is offline
Find More Posts by jofro
Joined Jan 2010
In small, higher rpm EDF units like 70mm it actually create more trouble than good IMO, unless you can balance it to an absolute perfection which is well out for an average modeller.
On other hand, there is such a tornado of air inside the air intakes that using spinner or no spinner it will make a very little or no difference in performance.
I just did some test runs of the 70mm fan today I'm going to fit in my new build and no matter how much I played with the spinner the fan was running much smoother with out it, tho aesthetically it looks better with it.
jofro is offline Find More Posts by jofro
Old Sep 23, 2015, 10:08 AM
tom bacsanyi is offline
Find More Posts by tom bacsanyi
tom bacsanyi's Avatar
farmington hills mi.
Joined Sep 2006
Been down that road before
This has been investigated by myself and others and have found a loss of from 3 to 5% on a typical edf with no spinner. It is a little more loss than I would be willing to give up. The inlet lip is a much bigger deal.
tom bacsanyi is offline Find More Posts by tom bacsanyi
Old Sep 23, 2015, 01:36 PM
Big gov never Works
St. Martin's Avatar
Joined Jul 2002
I have never had to use any kind of ballast inside a spinner, other than a 1/8-3/16"sq piece of masking tape. Some times motors, esp slotted designs, are just not well balanced. Kontronics and Hackers are a dream to set-up.
If I cannot dynamically balance a motor/rotor by just clocking, I add a square of tape and try it. If it still is no good...I move the tape 45deg.(this is inside the spinner BTW) If better I move the tape an 1/8th turn in the same direction, till it is good. Sometimes I have to enlarge the square of tape. But rarely.
If your rotor is already balanced, and you balance the spinner, too.. you will not be accomplishing the goal. The goal is to dynamically balance the rotor/motor/adapter/spinner in unison, not individually. But starting off with the greatest mass at the further out circumference, already balanced, is a good start(rotor).
On another note: I have balance fans outside the airframe(as I usually do) and installed it in the airframe to sound and feel horrible. It was the ducting. The bad ducting in a certain design afforded poor flow to one side of the fan. Causing an aerodynamic inbalance. I scratched my head on that one for quite a while. It turned out to be the ducting had too high an angle mid way through the duct. New ducting cured the problem.
This is a big reason why some designs have a pleasant sound than others, if the fan is set-up correctly.
Fuzz
BTW, if that is a WeMo EVO, the spinner is at fault. They are bad. I hope Oliver corrects this problem. The problem is also with the 80/90mm Evo
s
Discussion Any thoughts on an EDF Slow Stick? IWC Electric Ducted Fan Jet Talk 5 Aug 28, 2014 12:05 PM
Sold UMX Beast with an EDF on the bottom. BNF edge_pilot Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Jan 23, 2014 05:50 PM
Discussion I wanna strap an EDF on an 80" High wing Cabledawg1 Electric Ducted Fan Jet Talk 20 May 04, 2012 04:04 PM
Discussion Can you over draw an inrunner on an EDF? crashtested Electric Motor Design and Construction 18 Oct 22, 2011 01:28 PM
Spinner on an Endo power system? mad mike Electric Plane Talk 2 Sep 29, 2003 08:15 PM
