Old Sep 03, 2015, 01:26 AM
crasher47 is offline
Find More Posts by crasher47
Joined Mar 2013
600 blades on Trex 550 Pro DFC
What difference would one see from running 600mm blades on a Trex 550 Pro DFC set up for 550mm blades. The tail boom is a 600 item. Present pinion is 16 tooth. Would going to 14 be helpful with the larger blades?
crasher47 is offline Find More Posts by crasher47
Old Sep 29, 2015, 12:09 PM
Dennis Everett is offline
Find More Posts by Dennis Everett
Dennis Everett's Avatar
United States, CA, Ontario
Joined Mar 2002
Run the numbers through a headspeed calc. program,or if using a castle speed control and see if you get the desired head speed you are after.
Dennis Everett is offline Find More Posts by Dennis Everett
Old Sep 29, 2015, 12:37 PM
Flying Pitcher is offline
Find More Posts by Flying Pitcher
Inertial Hydraulics Engineer
Joined Apr 2013
you may be fine running partial throttle...
probably more lift...?
Flying Pitcher is offline Find More Posts by Flying Pitcher
Old Sep 29, 2015, 12:42 PM
JetPlaneFlyer is offline
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
It should work ok providing you have enough clearance between main and tail blades. One thing to watch though is if you run lower headspeed that also reduces tail rotor RPM and as the tail rotor needs to deal with greater reaction torque then you might have problems with tail blowout if flying more aggressively.
JetPlaneFlyer is offline Find More Posts by JetPlaneFlyer
Old Sep 29, 2015, 03:26 PM
Joined Apr 2013
he has 600 boom, so I guess he's safe there
I'm tempted to go back to the 520's on mine after running the raddix 554's for a while. Seems to bog quite a bit, although i've currently got around 2400 gov'd on a 12T pinion. I think I'm gonna need some better packs, as the Zippy's really aren't liking me for it...
Maybe i should just crank the headspeed down a little, lol. I seem to not get very good tail authority below around 2100 though.
last post on helifreak. http://www.helifreak.com/showthread.php?p=4628139
JPF may be right about the tail.
Old Sep 29, 2015, 06:27 PM
Atomic Skull is offline
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
Basically it'll be a light 6S 600. The frame design on the 550 V1/V2/V3/Pro and the old 600E are very similar. In the prototype 550 V1 they were even more similar, it used the 600E bottom plate, battery tray and plastic mainshaft bearing blocks (the 600E/ESP bearing blocks have more widely spaced screws and a locating tab)
Atomic Skull is offline Find More Posts by Atomic Skull
Old Oct 01, 2015, 06:14 AM
Aberdeen
Joined Mar 2006
Not necessarily because there are other factors such as the length of the frame between the mainshaft and the boom and the height of the head.
But having said that, in this case almost for sure it would be ok. Even so it's always a good idea to double check by manipulating the blades to their closest point and making sure they clear.
Old Oct 01, 2015, 10:46 AM
Joined Mar 2013
Ill take some frame measurements and decide. The issue of tail rotor speed has crossed my mind.
Old Oct 02, 2015, 01:53 AM
Aberdeen
Joined Mar 2006
You might also check if you have room for 95mm tail blades. That's what the 600 pro uses to cope with the increased torque.
Old Oct 08, 2015, 06:11 PM
Joined Mar 2013
The heli kit came with 95's. So did my 550L Dominator.
Discussion Trex 600 / 550 Pro DFC - Discussion, videos, pictures, etc. FlyingPhilUK Large Electric Helis 385 Today 04:25 AM
Sold Align Trex 550 600 Flybarless Rotor Head FB DFC fluxcapacitor121 Aircraft - Electric - Helis (FS/W) 2 May 12, 2015 01:33 PM
Sold NEW Align Trex 600 DFC Electric Airframe Scorpion 510 KV Blades Complete fluxcapacitor121 Aircraft - Electric - Helis (FS/W) 1 May 01, 2015 11:16 PM
Sold New Align Trex 600 DFC Electric Airframe Scorpion 510 KV Blades Complete fluxcapacitor121 Aircraft - Electric - Helis (FS/W) 5 May 01, 2015 05:42 PM
For Sale Wanted Trex 500 pro dfc or 550 dfc complete airframe NC Hillbilly Aircraft - Electric - Helis (FS/W) 0 Feb 17, 2014 04:11 PM
