Old May 31, 2014, 03:21 AM
Paul
PaulJa's Avatar
United Kingdom, Oxon
Joined May 2014
Billings Smit rotterdam
Hi all,
I have a question about the hull. On ships I have built before I have either covered the bottom with plates and left the rest with planks visible. As this model will have a smooth hull what do you use to achieve the finish? I was thinking of fiberglass but was not sure if there was some kind of resin that is brushed on and sanded to a smooth finish. Any suggestions would be much appreciated.
PaulJa is offline Find More Posts by PaulJa
Old May 31, 2014, 03:54 AM
HeavyCruser9's Avatar
Adelaide,Australia
Joined Dec 2009
yup fibre glass resin and f/glass cloth I use the grade of cloth they use on surfboards it gives a very nice finish.
Make it RC stacks of fun towing stuff.....
Cheers Bruce
HeavyCruser9 is offline Find More Posts by HeavyCruser9
Old May 31, 2014, 05:31 AM
Paul
PaulJa's Avatar
Joined May 2014
Thanks Bruce,
That's exactly what I have invested in but was not sure. Mind you, it will be a while before a need it. I reckon a few months to plank the hull.
I have considered RC and may yet do so. Problem is I live in the middle of the countryside and I don't drive and there is no water for miles where I live. Nearest boating lake is 9 miles away. .
Paul
PS
These are just a few pictures of the kit. I won't bore you all with kit photos as I am sure other members would have posted some and I have around 50 of them. never attempted a kit like this and am looking forward to the challenge of the build. I have rigged cannons for the Victory but the fittings for that kit where no where near as extensive as for this one. Will start a build log proper either this weekend or next.
Paul
Old May 31, 2014, 07:01 AM
Jerome Morris's Avatar
Union, Maine
Joined Jul 2006
A lot to this kit!
Jerome Morris is offline Find More Posts by Jerome Morris
Old May 31, 2014, 07:09 AM
Paul
PaulJa's Avatar
Joined May 2014
Yes, should be a nice challenge.
This link will take you to my Facebook album where there are lots more photos.
https://www.facebook.com/paul.jarman...6409259&type=3
Old May 31, 2014, 11:59 AM
---o-O-o---
blutoh's Avatar
United States, NJ, Livingston
Joined Mar 2012
Nice pix!
You can create a photo album on FB if you want to keep the Smit pix separate.
How old is the Chocolate Lab?
Pete
blutoh is offline Find More Posts by blutoh
Old May 31, 2014, 12:18 PM
Paul
PaulJa's Avatar
Joined May 2014
Cassie is a Staffie/Lab mix and is coming up to 8 in September. How do I start an album here.
Paul
Old May 31, 2014, 12:29 PM
Paul
PaulJa's Avatar
Joined May 2014
Starting the keel.
Help from anyone familiar with this kit.
I have not built a wooden kit for a number of years. Kits I have built before have had pieces cut to length to the correct size.
The picture shows the parts of the keel. One part is a 5x5mm strip. The instruction book says it should be 581mm long and shows a single strip. The kit piece is 550mm. Do I need to add the extra bit from another strip or leave a small gap at each end? Also the strip that is 5x12mm is supposed to be 657.5mm long and the kit piece is well over that so do I need to cut to fit? There are two strips that cover these strips so a gap would not be seen. Any advice would be appreciated before I start cutting wood down and ruin the build.
Paul
Old May 31, 2014, 05:32 PM
---o-O-o---
blutoh's Avatar
Joined Mar 2012
Here you just keep attaching to each post. Then if you click on the link "View all Images in Thread" it will bring up an album.
Old May 31, 2014, 05:43 PM
Paul
PaulJa's Avatar
Joined May 2014
Cheers.
Old May 31, 2014, 06:22 PM
no such thing as to many boats
louie R/C NUT's Avatar
Joined May 2010
Going to make one nice boat when it's done.
louie R/C NUT is online now Find More Posts by louie R/C NUT
Old May 31, 2014, 06:47 PM
---o-O-o---
blutoh's Avatar
Joined Mar 2012
Ya' know Paul, there's still time to put some shaft logs and motor mounts in there, just in case ya' ever get the urge. I'm just sayin'.
Old May 31, 2014, 07:28 PM
Paul
PaulJa's Avatar
Joined May 2014
Yes I am considering it, Been checking out RC equipment.
Old Jun 04, 2014, 04:45 PM
Paul
PaulJa's Avatar
Joined May 2014
Billings Smit Rotterdam.
Hi all,
have started the keel and bulkheads. Beginning to get an idea of the scale of this model now.
Old Jun 04, 2014, 05:27 PM
P_J_Glor's Avatar
Valencia, CA
Joined Oct 2002
Looks like you are getting into the process with very nice results.
Pete G.
P_J_Glor is offline Find More Posts by P_J_Glor
Sold NEW unbuilt Billings Smit Rotterdam Tug Yamaha W60 Racer Boats (FS/W) 2 Dec 16, 2013 10:49 PM
Sold Billings Smit Rotterdam for sale w/fittings Yamaha W60 Racer Boats (FS/W) 0 Dec 03, 2013 09:45 PM
Question Billings Smit Rotterdam slowstartgjh Scale Boats 2 Feb 17, 2013 11:40 AM
Billing Boats Smit Rotterdam. yngwie Scale Boats 52 Dec 28, 2012 12:59 PM
Wanted Need help getting a bow thruster to suit Billing Smit Rotterdam - Getting desperate chilihead Boats (FS/W) 3 Dec 28, 2006 12:12 AM
