Old Oct 23, 2005, 01:19 AM
manuel v is offline
Find More Posts by manuel v
manuel v's Avatar
Mexico, BC, Mexicali
Joined Aug 2004
Full vectorial Thrust.
Some Ideas to make a full vectorial thrust pusher electric plane.
what do you think about it?.
Manuel V.
manuel v is offline Find More Posts by manuel v
Old Oct 23, 2005, 01:32 AM
riffrafff is offline
Find More Posts by riffrafff
I'm a leaf on the wind...
riffrafff's Avatar
Harrisonville, MO
Joined May 2005
I think that bottom drawing is going to spin that ball around in its socket and twist up your control rods like bread-ties.
riffrafff is offline Find More Posts by riffrafff
Old Oct 23, 2005, 01:50 AM
manuel v is offline
manuel v's Avatar
Joined Aug 2004
riffrafff.
You are right. my first option is the upper draw.
thaks for your observation.
Old Oct 23, 2005, 01:51 AM
fhhuber506771 is offline
Find More Posts by fhhuber506771
Deletedfor proving Nauga wrong
Joined Mar 2005
On the upper version... the servo that moves it in the slot should be on the hinged piece to prevent inadvertant mix effect.
The lower one reminds me a bit of an old Buick's remote operator for the side mirror. It has some potential. Its not hard to add a couple of guide pins and slots to the ball to prevent it from spinning.
fhhuber506771 is offline Find More Posts by fhhuber506771
Old Oct 23, 2005, 02:09 AM
manuel v is offline
manuel v's Avatar
Joined Aug 2004
fhhuber506771
Thank for your comments.
Another idea.
Old Oct 23, 2005, 07:51 AM
olmod is offline
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
try placing your pivots as close to the ballance points of the motor with the prop fitted,it will less strain on servos,think of a gimbal type setup like what is used on marine compass, just a suggestion thats crossed my mind on more than one occasion
olmod is offline Find More Posts by olmod
Old Oct 23, 2005, 07:52 AM
Sillyness is offline
Find More Posts by Sillyness
Sillyness's Avatar
Little Rock, AR
Joined Apr 2004
Believe it or not, there's a LOT of force on the motor mounting system, even on the little electrics. The main forces are due to gyroscopic effects while the model is pitching or rolling. If you pitch the model you'll get a gyroscopic force on the prop in the yaw axis, and vice versa. You can actually HEAR the gyroscopic effects when you do a wall, snap, etc... Try holding a motor that is mounted to a false firewall... run it up and move it around.
These forces are strong and will undoubtadly overcome most small servos... you'll need a lot of holding power to keep the motor where you want it.
Good luck,
Jason
Sillyness is offline Find More Posts by Sillyness
Old Oct 23, 2005, 10:14 AM
olmod is offline
olmod's Avatar
Joined Apr 2004
Agreed on that ,they would need to be high torque for sure
Old Oct 23, 2005, 04:16 PM
manuel v is offline
manuel v's Avatar
Joined Aug 2004
Thanks for the pointers. Jason.
Olmond. I put a figure 4. with same idea +,- . what do you think?
Old Oct 23, 2005, 05:03 PM
olmod is offline
olmod's Avatar
Joined Apr 2004
The main reason i stopped thinking about such a system was what happens with power off to the motor
Old Dec 09, 2012, 12:27 PM
manuel v is offline
manuel v's Avatar
Joined Aug 2004
Nice item from HK.
http://www.hobbyking.com/hobbyking/s...Outrunner.html
Old Jul 03, 2015, 09:31 PM
manuel v is offline
manuel v's Avatar
Joined Aug 2004
Cuando uno tiene una idea, no debe uno abandonarla, hay que estudiarla hasta el final. esto propuesto en este foro es tan comun que es increible que haya tenido detractores.
No cabe duda, para avanzar, hay que romper paradigmas.
