Old Feb 03, 2016, 09:42 AM
begg is offline
Find More Posts by begg
Joined Oct 2015
Is it Turnigy or Me, please help.
I just bought latest Turnigy Accucell 6 charger and a Zop Power Lipo 11.1V 20C 1000 mAh battery. When I test it with an ordinary batter tester, it gives correct reading of each cell, 3.83,3.83, 3.85, and when I connect it to Turnigy charger, it gives weired reading, have a look at the picture.
The battery has JST connector. I have made an adopter of JST to XT60, through which I connect the battery to the charger.
Am I doing something wrong or the charger is bad or it needs to be caliberated.
begg is offline Find More Posts by begg
Old Feb 03, 2016, 09:45 AM
DrewC is offline
Find More Posts by DrewC
Comic Art Collector
DrewC's Avatar
United States, NY, Eastchester
Joined Jul 2013
Can you post a picture of how you're connecting the battery and charger?
DrewC is offline Find More Posts by DrewC
Old Feb 03, 2016, 11:31 AM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Close up of the balance connector hookup at the charger and between battery and balance connector if an adaptor cable is used.
hoppy is offline Find More Posts by hoppy
Old Feb 03, 2016, 11:32 AM
begg is offline
Joined Oct 2015
Hi, thanks. The first photo was when I connected the battery to the charger for the first time. Now I have connected it 2nd time, now there is a difference. Previously the 2nd row was showing 00 all the way. Now this time it is different See the 2nd photo. Now see the 3rd photo, which is exactly the same the first time I connected the charger. There is 10 to 15 min of difference in taking these photos
Old Feb 03, 2016, 11:37 AM
begg is offline
Joined Oct 2015
Hi, in continuation of my previous letter, when I want to check battery resistance, it says "No battery found".
Old Feb 03, 2016, 11:42 AM
DrewC is offline
Comic Art Collector
DrewC's Avatar
Joined Jul 2013
Is the balance plug in properly? It looks like it's half out?
Old Feb 03, 2016, 11:44 AM
begg is offline
Joined Oct 2015
There you go.
Old Feb 03, 2016, 11:46 AM
begg is offline
Joined Oct 2015
Yes it is fully in.
Old Feb 03, 2016, 11:51 AM
begg is offline
Joined Oct 2015
Yes it is properly pluged in have a look at the photo
Old Feb 03, 2016, 11:52 AM
DrewC is offline
Comic Art Collector
DrewC's Avatar
Joined Jul 2013
I just noticed in your initial post that your charge set-up is for (2) cells, it should be (3). Not sure if that's causing the issue?
Old Feb 03, 2016, 01:11 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
We want to see the connector plugged into the charger. Turn charger so that the connector side is pointing at camera.
Old Feb 03, 2016, 01:47 PM
begg is offline
Joined Oct 2015
There you go.
Old Feb 03, 2016, 02:58 PM
DrewC is offline
Comic Art Collector
DrewC's Avatar
Joined Jul 2013
That image still shows the charger set for a 2S battery, you have a 3S battery. Try correcting the settings and see what happens.
Old Feb 03, 2016, 03:19 PM
begg is offline
Joined Oct 2015
I have tried both 3S and 2S, I got the same result.
Old Feb 03, 2016, 03:33 PM
DrewC is offline
Comic Art Collector
DrewC's Avatar
Joined Jul 2013
What function are you using when getting those readings? Does the Accucell 6 have a monitor function, or are you getting those readings while set up for a balance charge?
Help! pleas help roylif Off-road Cars 1 Jun 25, 2015 10:33 PM
Discussion xuav-SKUA+PIXHAWK-Pleas help swar Beginner Training Area (Aircraft-Electric) 0 Jun 24, 2015 08:20 PM
Discussion xuav-SKUA+PIXHAWK-Pleas help swar Electric Plane Talk 0 Jun 24, 2015 08:14 PM
Help! Mcpx brushless conversion PLEAS HELP ME Newbie77 Beginner Training Area (Heli-Electric) 3 Nov 19, 2013 06:35 AM
Discussion Pleas Help me with walkera 36 WK-0701 Tx kaushiksad Simulators 1 Dec 03, 2007 07:26 PM
