Old May 24, 2013, 10:43 PM
DennisRB is offline
Find More Posts by DennisRB
Sand it round!
DennisRB's Avatar
Brisbane Australia
High power very high RPM motor for supercharger.
Hey guys.
I am having a discussion about replacing the turbine section of a turbo charger with a high power high RPM motor for use on a car. I immediately thought of you guys.
The turbo will need to spin at over 50,000rpm, preferably much higher than this and will require several KW. Prob at least 5kw.
Are there any motors around that will satisfy these demands?
You may have seen scam electric superchargers which use a 0.005KW computer fan. Obviously this project actually strives to produce real boost pressure.
Thanks Dennis.
DennisRB is offline Find More Posts by DennisRB
Old May 24, 2013, 11:27 PM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
Don't bother. It's been thrown around quite a few times here. By the time you've got an electric motor driving a rotor fast enough to compress a useful quantity of air, you're putting such a strain on the car's electrical system that any benefits are far outweighed by the turbocharger's own energy consumption.
Think about it: You said yourself that you'll need maybe a 5kW motor (More? Less? Who knows?). If you ran it off the car's native electrical system, you'd be approaching the CCA rating of many auto batteries CONTINUOUSLY, simply trying to power your turbocharger. 5000W is more than 6.5 horsepower that has to get from the engine into the alternator and then through the electrical system into the compressor blades...
Piece is offline Find More Posts by Piece
Old May 25, 2013, 01:33 AM
BillzillaAus is offline
Find More Posts by BillzillaAus
My cat moderates better
BillzillaAus's Avatar
Australia, QLD, Worongary
Joined Apr 2011
FWIW, C₄H₁₀, have a read of this - http://www.efi101.com/forum/viewtopic.php?t=8197
It seems to work well enough.
BillzillaAus is offline Find More Posts by BillzillaAus
Old May 25, 2013, 02:38 AM
DennisRB is offline
Sand it round!
DennisRB's Avatar
Brisbane Australia
Thanks for the reply. That has been already been debated elsewhere and the answer is that it will work, and this idea does not break any laws of thermodynamics, as it may first appear. The extra power comes from COMBUSTION of the air with fuel, not just from decompression of the compressed air. The device would only be working at full power for maybe 2% of the time, so the alternator will have no probs keeping batteries topped up. The power to drive the device comes from the past, so it will NOT drag a 5KW load off the engine, unlike a normal supercharger which does drag the power required for compression from the crank in real time, yet it still obviously works. The alternator only needs to supply the AVERAGE power demand which will be much, much lower than the rated power of the electric motor. A dedicated lithium bank and special charging system may be required to run the motor. Another thing that you RC guys know a lot about!
I don't really want to have the debate again, see this thread. http://www.performanceforums.com/for...Electric-turbo Plus Bill has linked a version that has already been proven to work. My request of a 5000W motor at 50,000+ RPM may not be achievable. But I thought I may get some answers on what kind of motors are available. Less power will give some boost, so I await some replies on what sort of RPM and power we can get from these motors.
Cheers.
Old May 25, 2013, 05:09 AM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
The Neu 15xx series will float your boat. Used in EDF a bit, similar speeds and powers.
Odysis is offline Find More Posts by Odysis
Old May 25, 2013, 10:44 AM
carlsoti is offline
Find More Posts by carlsoti
hass-alfed and bass-ackwards
carlsoti's Avatar
United States, AZ, Chandler
Joined Jun 2008
If you want to get serious, don't ditch the car batteries for Lipo. I have yet to see a sailplane winch run reliably on Lipo batteries. The amp draw of an old-school V8 starter motor is pretty brutal, and a couple (or single LARGE) lead-acid battery should give better amp output than a comparable Lipo. Plus, there's less of a chance of a massive fire that cannot be extinguished.
On thing to consider might be running a pair of lead acid batteries in series to get 24+V to the turbo motor. Figuring out how to charge at 12V, and output 24V could get tricky, or you could get a "step-up" charging system, and avoid the issue.
You might need to look at a sensored motor, considering the loads you're talking about. A typical EDF or prop drive likely won't see the same type of dynamic loads this turbo motor might see. If you pump it all into a giant "log" style plenum, you might be able to alleviate those issues.
carlsoti is offline Find More Posts by carlsoti
Old May 25, 2013, 06:49 PM
DennisRB is offline
Sand it round!
DennisRB's Avatar
Brisbane Australia
I guess with the sailplanes they use the smallest packs they can due to weight so they would be running at very high C rates. You could go bigger in a car. But yeah, if I could stay with AGM or something it would be much cheaper.
I checked out the NEU thanks for that! 26V and 60,000rpm but only 2.25kw, and 4.5kw peak. What sort of duty cycles are these peak rating usually good for?
http://www.neumotors.com/Site/1500_series.html
Need more RPM and more power
Old May 25, 2013, 07:45 PM
carlsoti is offline
carlsoti's Avatar
Joined Jun 2008
On the note of sailplane use, I was referring to winch launch gliders, not motored planes. The winches frequently use old-school Ford Long-shaft V8 starter motors and pB batteries to run the winches. Normally, the winches run wide open for just a few seconds at a time, not too unlike what you might be doing. Lipo batteries won't take the abuse the winches deliver, not for many cycles, anyway.
As far as motors go, take a peak at what some of the guys in the "High-Performance" threads are doing. I can't remember what specific discipline it is, but some of the guys are running near 8Kw, but only for a few seconds at a time. I think mainly because the planes tend to get really small, really fast.
Old May 25, 2013, 08:01 PM
Odysis is offline
Joined May 2007
Neu's motors can take a lot more than they're spec'd for. He also builds custom motors if you're keen.
He's here on RCG as "sneu" if you want to track him down.
Old May 27, 2013, 05:25 PM
Wheazel is offline
Find More Posts by Wheazel
Tech freak
Sundsvall Midlanda, Sweden
Joined Aug 2002
It will be tricky to solve your equation as you will need a fairly large motor to cope with the heat from the power (most likely not ideal cooling conditions either)
This coupled to the very high rpm is where it gets challenging. Big motors don't want to rotate at 60k+ rpm. Somekind of gearing might be possible? Maybe something inline with how a Rotrex SC works?
I am sure it will be possible to build a well working system tho, just some stuff to overcome as it is fairly new ground.
Wheazel is offline Find More Posts by Wheazel
Old May 27, 2013, 09:53 PM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
Originally Posted by DennisRB View Post
Need more RPM
So 60,000 isn't enough. What rpm do you need?
and more power
No rating is specified for the Neu 1530, but it should be good for at least 5Kw peak. How much power do you need?
Depends on cooling and motor efficiency.
The Neu 1530-1D should get a bit over 90% efficiency from 2.2kW to 5kW at 26V, with heating losses of around 200W at 2.2kW to 450W at 5kW. Therefore, assuming that there is enough cooling for continuous operation at 2.2kW, the maximum duty cycle allowable at 5kW would be ~44%. Since you say that the device would only be working at full power for maybe 2% of the time, you should have no problem using the motor's peak power rating.
I doubt that. A typical lead-acid motor vehicle battery drops to under 10V during cranking, and has a much lower power/weight ratio than an equivalent Lipo. If the Lipos you saw running sailplane winches weren't up to it, I bet they were simply too small for the job.
One thing to consider might be running a pair of lead acid batteries in series to get 24+V to the turbo motor.
A pair of normal 12V lead acid batteries in series won't give you 24V+ at 200A (more like 20V, but then you need to draw 250A, but then the voltage drops to 9V, and then...).
You will probably need more than 24V anyway, just to get the required rpm from a 1 turn motor.
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old May 28, 2013, 01:05 PM
zeroback is offline
Find More Posts by zeroback
United States, FL, Pompano Beach
Joined Oct 2011
zeroback is offline Find More Posts by zeroback
Reply With Quote  (Disabled)
Old May 28, 2013, 04:20 PM
Joined Apr 2011
Originally Posted by zeroback View Post
Adding more air will not make the engine more powerful in fact it will stop running after going through a short period of severe detonation due to the lean condition.
Genius.
You should be an engine tuner.
Old May 28, 2013, 07:39 PM
RuralFPV is offline
Find More Posts by RuralFPV
Head full of foam
United States, NE, Omaha
Joined Jan 2013
All intake air will go through a MAF. The computer will see more air and add more fuel... automatically. The only caveate to this is that you have to watch the max flow of the injectors and be careful not to exceed what they can flow.
/dry nitrous 101
RuralFPV is offline Find More Posts by RuralFPV
Old May 29, 2013, 05:31 AM
zeroback is offline
Joined Oct 2011
Discussion 4kw+ Motor for 70mm-80mm Fans....Powered by a 39mm inrunner see Post #383 Knife Liddle Electric Ducted Fan Jet Talk 386 Dec 14, 2013 10:05 PM
Discussion motor stops at high rpm vcazan Multirotor Electronics 6 May 11, 2013 11:21 AM
Discussion Thunder Power 65C lipo with very high resistence malcolmm Batteries and Chargers 3 Jan 31, 2013 06:14 PM
Sold Hyperion Hs2206 3900 Kv High Rpm Outrunner Motor pttse Aircraft - Electric - Power Systems (FS/W) 0 Jan 22, 2013 02:18 AM
Sold Hyperion HS3026 High RPM Brushless Outrunner Motor Kv1600-HP-HS3026-1600 pttse Aircraft - Electric - Power Systems (FS/W) 1 Jan 19, 2013 12:45 AM
