Old Jul 27, 2015, 06:45 PM
Quorneng is offline
Find More Posts by Quorneng
Joined Feb 2007
Build Log
Another go at Endurance
Some time ago I posted a build of a 48" Depron built plane that achieve a theoretical endurance of 5 hours.
Description:
Unfortunately I lost it (quite literally) by flying too high and far away - it thermalled very nicely.
Annoyed at the loss I decided to do it again.
The original design had evolved over quite a number of stages so the challenge was to see if I could do better (or at least duplicate it) but this time starting with what I had learned.
For practical transport reasons I was going to stick with the same 48" span and also the same Blue Wonder 1500kV motor as I have yet to find anything more efficient at that size.
My initial thoughts followed the same principles as before, a pod and boom pusher with a broad chord pylon mounted wing but with some detail improvements.
The proposed wing.
Description:
It would be built with one piece 2mm Depron skins with close spaced Depron ribs to ensure an accurate wing section.
No dihedral but upturned raked wing tips commonly used in moulded foam gliders.
To avoid external horns the inboard edge of each aileron would be glued directly to its servo horn.
Description:
The space available inside the wing meant 3.7g micro servo had to be used but even so the servo would be flush with the wing's underside.
Description:
The round nose aileron was carefully shrouded to keep the air gap to less than 0.5mm.
Description:
A V tail meant very little of the airframe would be in the faster moving prop wash.
With a 5.0 Ah 2s it weighed 15oz.
just need some calm weather to undertake some long enough flights to test the current draw at minimum cruise.
Quorneng is offline Find More Posts by Quorneng
Alert Go Trump, Go!!! I Do Not Want Another Politician For President! traceyl Life, The Universe, and Politics 7 Jul 21, 2015 05:59 PM
Discussion Another go at full-contact electric combat flying! Jim_Marconnet Alabama's Rocket City Renegades 8 Dec 02, 2012 07:56 AM
