Old Jun 19, 2015, 06:34 PM
mack5 is offline
Find More Posts by mack5
Joined Jun 2004
f3x setup chart help
hi
how do you read one of the different f3x setup charts on many of the manufactures websites?
1, what is setup, a, b , c / start
2. how do these throws apply to the lower section wing, flap, elevator, rudder / a, b , c throws?
I am new to this information.
thanks
mack5 is offline Find More Posts by mack5
Old Jun 20, 2015, 02:44 PM
satinet is offline
Find More Posts by satinet
F3B
satinet's Avatar
Warwickshire, England
Joined Sep 2006
They are refering to the F3b tasks. F3b has 3 quit different tasks and the launch.
Start refers to the launch setting (off an f3b winch)
"A" setting is for the duration task (flying 10 minutes)
"B" setting is for the distance task (laps over 150m course in 4 minutes)
"C" is for the speed task (fastest time over 4 laps of 150m course).
In f3b you have different flight modes for the different tasks. So in duration you are flying a lot slower than in speed so you will have different settings for say aileron differential. hence the different settings.
The settings are usually measured in mm and have an up and down value for each control surface.
If you are setting up an f3b model for slope flying the "B" task settings would be the best place to start. The "b" settings would also be the most normal/cruise type setting for general flying.
satinet is offline Find More Posts by satinet
Old Jun 20, 2015, 06:32 PM
mack5 is offline
Joined Jun 2004
thanks
hi
big thanks to you
Old Jun 20, 2015, 11:44 PM
Avaldes is offline
Find More Posts by Avaldes
Avaldes's Avatar
United States, CA, San Luis Obispo
Joined Aug 2006
Also, normal sign convention is that trailing edge down is a positive (+) deflection.
Avaldes is offline Find More Posts by Avaldes
Help! F3X WC pilot needs your help webbsolution Multi Task F3X 0 Apr 26, 2015 11:10 PM
Discussion Need some help identifying some F3X Planes Dale Thompson Multi Task F3X 29 Feb 24, 2015 06:30 PM
For Sale Prop charts to help you select the right Prop & Threads unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 0 Sep 27, 2013 03:45 PM
For Sale Prop charts to help you select the right Prop & Threads unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 2 Sep 24, 2013 07:19 PM
Discussion Ideal setup for F3X with Hyp. Gs3032-8 milost High Performance 0 Jan 10, 2012 08:00 AM
