Closed Thread
Old Jul 30, 2009, 10:16 AM
Windsor, Canada, near Detroit
Joined Jul 2007
pack in e meter
pack in e meter
i own a first generation e meter. It comes with nicads installed, but i wonder if i can replace them with a lipo instead. Has anyone tried? The original pack is going to die eventually, so i would like to be prepared.
Previously, when i have tried getting any info from the manufacturer, have got no answers.
Phil
phil alvirez is offline Find More Posts by phil alvirez
Old Jul 30, 2009, 01:10 PM
aka: A.Roger Wilfong
gnofliwr's Avatar
Novi, Michigan, United States
Joined Jan 2001
I have an E2. I assume the battery and charge circuitry in the E1 are similar.
The E2 has a 6v, 5 cell NiMh pack and the charger is built in - supply 12v and it does the rest. I suspect that the charger is a simple C/10 charger since the power switch appears to be a hard switch (that is, it disconnects the battery instead of simply turning off a transistor) which would mean that the processor is not involved in the charging, but even if it is, it is programmed for a Nickle chemistry battery.
Switching to a Lithium battery, the charging circuitry would not work properly. The pack would eventually over-charge and might reduce the e'meter to a lump slag. So you'd need to modify the e'meter to use an external battery pack so that you could charge it not using the built-in charger.
Also, the battery capacity left display appears to work off of the terminal voltage of the pack. Switching to a 7.2 volt, 2 cell Lithium pack will display too high and the pack will likely be over discharged long before the display indicates the battery is low.
WRT nickle batteries, they are incredibly durable compared to LiPo. I have Rx packs that are 10-20 years old that still work fine. I don't fly them any more on general principles, but they are still doing yeoman service in servo simulators and various test equipment. I'd classify the e'meter as being in this same, non-critical equipment category.
As far as availability, nickle cells are likely to be around for at least the next 10-20 years.
- Roger
gnofliwr is online now Find More Posts by gnofliwr
Old Aug 01, 2009, 10:03 AM
Joined Jul 2007
Thanks for the information Roger
Phil
Closed Thread
Yippee! $6.00 Li-Ion Pack Flies $55 BL Esc & Outrunner Deal in E-starter for 10 Minutes hall woo Batteries and Chargers 11 Feb 23, 2005 07:09 PM
getting my brother started in E-flight JCV Parkflyers 7 Jan 06, 2002 07:27 PM
Overlander 1300 pack in Zagi? Ben C Foamies (Kits) 12 Sep 27, 2001 12:22 PM
Anybody put a GWS Pico Pack in a Speed 400 Plane? mrebman Parkflyers 5 Jul 08, 2001 10:32 PM
Anybody put a Pico Pack in a Sky Scooter? mrebman Foamies (Kits) 0 Jul 06, 2001 10:12 PM
