Old Jun 25, 2008, 05:13 AM
Eric.Payan is offline
Find More Posts by Eric.Payan
Lyon (France)
Joined Apr 2004
Looking for pics/info on the Fairchild 91.
Hello,
I currently building a Fairchild 91 sea plane. The plane is build with glass fiber for the body and a classical balsa wood structure for the wing.
I want to realize this plane with the Pan Am's color (Pan Am use this plane in Brasil in the 30th). Unfortunately, I only have side color view of the pan am's color. Did anybody have some good view of the fairchild's Pan Am color ?
Regard.
Eric.Payan is offline Find More Posts by Eric.Payan
Old Jun 29, 2008, 03:45 PM
Lyon (France)
Joined Apr 2004
To give you an idea of what I am looking for, here's what I found with google :
The construction is slowly going on, A new picture with engine pylon and rudder.
Regards
Old Jul 03, 2008, 09:12 AM
Airboatflyingshp is offline
Find More Posts by Airboatflyingshp
Airboatflyingshp's Avatar
B'ham UK
Joined Oct 2005
Eric try this google it for a french translation http://66.102.9.104/translate_c?hl=e...a-zvUjcN0CKbVA
Search Seawings as well
Airboatflyingshp is offline Find More Posts by Airboatflyingshp
Old Jul 04, 2008, 01:45 AM
bjaffee is offline
Find More Posts by bjaffee
Brett
bjaffee's Avatar
So Cal
Joined Apr 2002
Wow, I've never seen that plane before. It reminds me of a full scale Drake II (especially with all that upthrust).
I'm guessing you've already seen this, but just in case...
http://guyrevel.free.fr/Hydravions/fairchild-91.html
bjaffee is offline Find More Posts by bjaffee
Old Jul 04, 2008, 06:06 AM
B'ham UK
Joined Oct 2005
Havent seen that site before it seems incomplete but will be worth adding to the sticky .
There is a free plan to download for one of these in balsa on the flying aces site. you will have to check for it but I know its there from memory
Fairchild Model 91 "Baby Clipper" (1 min 30 sec)
Old Jul 06, 2008, 02:38 PM
Lyon (France)
Joined Apr 2004
First fly on ground with the removable wheels.
The wing span is 1,26m, the weight is 1,5kg.
The plane is easy to fly, the tower pro 2915 engine with a 4s 3000 mAh give a lot of power.
The main problem came when I try stall : the plane fall on his back and start a long dive ... really strange.
Regards.
Old Jul 16, 2008, 02:53 PM
Lyon (France)
Joined Apr 2004
Things are going on :
3 more flys, the plane is now well trim and fly well. The painting is going on :
Regards.
Old Jul 31, 2008, 09:28 AM
B'ham UK
Joined Oct 2005
Bump ..hows progress Eric?
Old Aug 28, 2008, 04:07 PM
Lyon (France)
Joined Apr 2004
Back from holidays ...
I finally manage to get some pictures of the Fairchild in Panair's colors. Most of them are copyrighted so sorry, but I can't share them.
Work on plane is (slowly) going on, I just add the wing's float and start the waterproof tests in my pool.
Regards
Old Aug 28, 2008, 06:52 PM
lake flyer is offline
Find More Posts by lake flyer
lake flyer's Avatar
Joined Nov 2005
Try this
http://images.google.ca/images?sourc...=1&sa=N&tab=wi
lake flyer is offline Find More Posts by lake flyer
Old Aug 29, 2008, 04:21 AM
Petem is offline
Find More Posts by Petem
If it flies - I want one!
Petem's Avatar
Werribee, Victoria, Australia
Joined Jul 2008
A lovely aircraft!
Eric,
Your Fairchild is looking great! I look forward to news of the first flights from water.
All the best,
Peter
Petem is offline Find More Posts by Petem
Old Aug 31, 2008, 02:13 PM
donjiskra is offline
Find More Posts by donjiskra
WAA-08 Pilot Eventually
donjiskra's Avatar
Darien,IL,USA
Joined Jul 2000
Eric,
Congratulations, great job.
Looks like you have a winner.
Best wishes for good flighjts,
Don
donjiskra is offline Find More Posts by donjiskra
Old Sep 02, 2008, 10:17 AM
B'ham UK
Joined Oct 2005
conratulations Eric a very clean ship and a less than common subject............. video some time?
Old Sep 11, 2008, 02:42 AM
Lyon (France)
Joined Apr 2004
Fairchild 91 on the water.
Some news of my plane :
The plane have flown a lot from my club's field. It now perform very well and it appears to be a little overpowered.
Yesterday evening, it was time for the tests on the water. First take off test ended really soon with a nose dive ... and a big water splash !
For the second test I pull the ruder to avoid the same problem and the plane went quickly on the step. After a short run, it takes off a few seconds later ... no more radio control ! luckily, the plane fall on the water without any damage. After a short swim (the water was not to cold ) I bring the plane back to the beach.
As soon as I open the plane, I understand the problems : during the first test some water get into the body and the receiver was swimming (or diving ) in the water !
So some work need to be done for a better water proofing of the plane before a second test.
A short video (without the crash !) :
http://www.dailymotion.com/video/x6pxsq_videoo_tech
Regards
Old Yesterday, 05:15 PM
ledzep76 is offline
Find More Posts by ledzep76
ledzep76's Avatar
United Kingdom, England, Bisley
Joined Oct 2010
Wonderful aircraft Eric. You may find that more up thrust is needed. This will stop her nosing into the water on take off. If you look at the full size it has a high angle of up thrust due to the motor being mounted so high above the c of g.
Think of something like a bixler with a pusher prop. They push down toward the c of g. You have the opposite of that as you are pulling up away from the c of g.
A truly wonderful model of a splendid subject.
Happy landings.
ledzep76 is offline Find More Posts by ledzep76
Discussion Looking for Pics/info on Gull by K Kuosma Airboatflyingshp Waterplanes 160 Jul 14, 2013 02:32 PM
Discussion Looking for pics/info on the old DAM warbirds. Brian Courtice Slope 113 Jun 17, 2013 09:11 PM
Discussion Just bought a used Windex glider, Looking for more info on it (CG...) dogon1013 Electric Sailplanes 7 Jul 17, 2008 09:29 PM
Question Looking for Build info on Dare F9 Panther Monty5 Electric Warbirds 0 May 17, 2006 08:27 AM
Im looking for some info on the MPJet Red FlinVR Foamies (Kits) 0 Jul 15, 2004 03:46 PM
