Old Sep 20, 2015, 01:55 PM
CornChip is offline
Find More Posts by CornChip
New to Gyros
Ontario Canada
Joined Jan 2005
Tower Hobbies Uproar 40 Conversion
Returning to modeling after 9 years away. I've flown my first electric RTF recently, a Hobby King Skipper with success proving I still can fly. So, for the rest of the year I'll be away from the water and will be pulling a kit out of storage to build. That kit is an Uproar 40 ARF. I have so many un built kits, that conversion seems the way to go.
So naturally posting in this forum, I am looking for motor/battery recommendations with prop size being the biggest factor, an 11 inch diameter and keeping this as a sport flyer with a good watts/pound ratio (approximately 4 pounds). I've seen the motors that claim 32 or 46 glow, but find the labeling misleading. From there the specs get confusing.
CornChip is offline Find More Posts by CornChip
Old Sep 20, 2015, 03:17 PM
3dFlyingMaster is offline
Find More Posts by 3dFlyingMaster
Where did that tree come from?
United States, FL, Sebastian
Joined Dec 2014
There was just a conversion of this plane. I will find the link.
Chris
3dFlyingMaster is offline Find More Posts by 3dFlyingMaster
Old Sep 20, 2015, 03:18 PM
Joined Dec 2014
http://www.rcgroups.com/forums/showthread.php?t=2363305
Old Sep 20, 2015, 03:19 PM
CornChip is offline
New to Gyros
Ontario Canada
Joined Jan 2005
Thanks.....I'll have a look.
In the mean time.....my choices so far at Hobby King.
Turnigy Aerodrive SK3 - 3542-1000kv Brushless Outrunner Motor
TURNIGY Plush 60amp Speed Controller
Turnigy 5000mAh 4S 25C Lipo Pack
APC-E Propeller 11x5.5
Old Sep 20, 2015, 03:29 PM
Joined Dec 2014
Hobbyking has been very good to me. Very minimal failures for dirt cheap, and I fly hard.
Chris
Old Sep 20, 2015, 05:06 PM
CornChip is offline
New to Gyros
Ontario Canada
Joined Jan 2005
Good or bad, things got ordered today. I ended up finding another forum post about a similar setup. When I get these items from HK and setup, I'll check back with results. Some place I have a Watts Up and a RPM checker.
Buddy code link....
http://www.rcgroups.com/forums/showp...postcount=7738
Old Sep 25, 2015, 05:41 AM
Tucci is offline
Find More Posts by Tucci
Learn to build with wood.
Tucci's Avatar
United States, NC, Newport
Joined Sep 2012
Might be a little too much prop on 4 cells, but the watt meter will tell you for sure.
Tucci is offline Find More Posts by Tucci
Old Sep 25, 2015, 04:36 PM
Joined Dec 2014
Change to Uproar 40 conversion?
Old Sep 27, 2015, 03:44 PM
CornChip is offline
New to Gyros
Ontario Canada
Joined Jan 2005
Tucci...
I tried one of those e-motor calculators and it figured the prop combo might be too much also. I believe 11x55.5e is the smallest 11 inch prop 'pitch wise' you can get. Would a 10x5e or less pitch be the correct way to go? How does cell count effect prop sizing?
3dFlyingmaster...
Didn't understand your question.
Old Sep 27, 2015, 08:20 PM
Joined Dec 2014
Tucci...
3dFlyingmaster...
The title was originally Kaos 40 conversion, now its Uproar 40 conversion.
Change your mind?
Chris
Old Sep 27, 2015, 08:30 PM
CornChip is offline
New to Gyros
Ontario Canada
Joined Jan 2005
Nope.... always an Uproar. But changing my mind, maybe. I'm a little concerned I may have undersized my motor. My motor might have to run faster with a smaller prop, and is unlikely to be very efficient. This is all a geuss at this point for me. Why can't it be like getting a .46 FX?
Old Sep 30, 2015, 06:53 AM
SnidelyWhiplash is offline
Find More Posts by SnidelyWhiplash
United States, PA, Farrell
Joined Sep 2014
I would do this...
G32 motor from valuehobby. 12x6 prop. 60 to 80 amp opto esc, 4S 3300 to 3700 mah 40c pack. Plenty of pull with this motor. Have one in a great planes escapade mx.
You can even go with a 13x6 prop. Heck, motor is only 30 bux.
Snidely...
SnidelyWhiplash is offline Find More Posts by SnidelyWhiplash
Old Oct 20, 2015, 09:04 PM
6meter is offline
Find More Posts by 6meter
United States, TX, Austin
Joined Jan 2014
Turnigy 3542
I am using the Turnigy 3542 with a 10 X 6 APC and 4S packs. It produces 580 watts and stays cool under heavy throttle use. I have several hundred flights on it, and it still performs perfectly. I tried the 11 X 5.5. It worked OK, but, the 10X6 is more efficient and provides better speed.
6meter is offline Find More Posts by 6meter
Old Oct 20, 2015, 10:28 PM
RexGalore is offline
Find More Posts by RexGalore
Out Standing In The Field
RexGalore's Avatar
United States, CT, Middletown
Joined Feb 2014
I've always liked shoulder wing planes and the looks of the Uproar & thought about converting one, but I've got too many projects waiting already! Here's a thread on Wattflyer that has some good info (I thought):
http://www.wattflyer.com/forums/showthread.php?t=67985
RexGalore is offline Find More Posts by RexGalore
Old Oct 23, 2015, 08:50 PM
Tucci is offline
Tucci's Avatar
Joined Sep 2012
Tucci...
3dFlyingmaster...
Hope you're still following your own thread.In my experience those e-motor calculators are unreliable, or at least very inconsistent. To answer your question, when you go up in cell count, you typically need to drop the prop diameter and/or pitch to keep the amp draw in check. Personally I would start with the 10x5 and see where you're at with the amp draw. I think that you'll be surprised with the performance of that motor and prop combo on 3s, let alone 4s.
But don't be afraid to experiment!!! I fly several combos that were "deemed false and cancelled" by the calculators, and are also drawing more amps than is recommended by the manufacturers. For a long time, with no reliability issues or any indication of imminent failure. (excessive heat, etc...)
Give it some time. When you get a little experience with these things, you'll start to learn what will work and what is just silly to try.
Sold Tower Hobbies Uproar .40 ARF CrashesALot Aircraft - Fuel - Airplanes (FS/W) 0 Aug 14, 2015 09:28 PM
Sold ***cheap*** Tower Hobbies Uproar 40 Arf glowfuel Aircraft - Fuel - Airplanes (FS/W) 0 Sep 23, 2006 09:40 AM
For Sale Tower Hobbies Uproar 40 -ARF (RTF) MailOrderGuy Aircraft - Fuel - Airplanes (FS/W) 0 May 25, 2006 10:33 PM
Tower Hobbies Uproar 40 ARF! AMCross Product Announcements 0 Sep 28, 2004 08:56 AM
