Old Feb 19, 2015, 11:47 PM
captain MoMo is offline
Find More Posts by captain MoMo
Mach One
captain MoMo's Avatar
Joined Apr 2011
Supreme Hobbies A330
This is the discussion thread specific to the new Supreme Hobbies A330.
captain MoMo is offline Find More Posts by captain MoMo
Old Feb 19, 2015, 11:49 PM
Cocg is offline
Find More Posts by Cocg
Fly and let Fly!
Cocg's Avatar
United States, CO, Grand Junction
Joined May 2010
More subscriptions... Luvin' it..
Cocg is offline Find More Posts by Cocg
Old Feb 21, 2015, 12:28 PM
Uusitalo is offline
Find More Posts by Uusitalo
"The Uzitalo nine millimeter"
Uusitalo's Avatar
☭Finland☭
Joined Nov 2009
This model looks very, very good. Can't wait to see the unboxing.
Uusitalo is offline Find More Posts by Uusitalo
Old Feb 21, 2015, 12:36 PM
Cocg is offline
Fly and let Fly!
Cocg's Avatar
Joined May 2010
... In my living room..!!
Old Feb 21, 2015, 12:40 PM
CWNG06301 is offline
Find More Posts by CWNG06301
CWNG06301's Avatar
Hong Kong
Joined May 2005
Some A330 photos share
CWNG06301 is offline Find More Posts by CWNG06301
Old Mar 02, 2015, 05:44 PM
merlinfan is offline
Find More Posts by merlinfan
Throttle Bender
merlinfan's Avatar
Joined Jun 2008
Hi Phillip, will the A330 retracts be available from you?
merlinfan is offline Find More Posts by merlinfan
Old Mar 02, 2015, 10:50 PM
CWNG06301's Avatar
Hong Kong
Joined May 2005
The retract of A330 and A340 is use very common servoless retract, it is medium size like most other model planes.
The belly retract of A340 is use the mini retract same as A320,
Old Mar 02, 2015, 11:49 PM
Mach One
Joined Apr 2011
Are these planes now available?
Old Mar 03, 2015, 04:28 AM
CWNG06301's Avatar
Hong Kong
Joined May 2005
Actually it was arrived before holiday of Chinese new year, but some problem found!!!! The factory still not reached to solve the problem, so it is hold to sell until the problem fix.
The problem is they use yellow color glue, as result is a visibale yellow line between left and right fuselage halve can be seen, this problem found in both of A330 and A340.
A340 found one 1 to 4 servo wire missing, A330 found a bottom cover missing!!!!!
Old Mar 03, 2015, 05:27 AM
Mach One
Joined Apr 2011
Wow - these are bad quality issues and you are doing the right thing holding off otherwise it will be your problem to deal with! I am surprised that they have not reached out to you to fix this issue? How would they fix the yellow glue? Which is most likely an epoxy that has turned more yellow? Would they paint it ? That would be hard to do! They may have to sell this first batch at a discount and fix the problem with the next batch. People can paint the fuselage if decals are provided.
Thanks for your honest response !
Regards
Old Mar 03, 2015, 06:44 AM
4stripes is offline
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
Can someone post some specifications for this model please? Size, battery, weight, fans, motors, ESCs....
4stripes is offline Find More Posts by 4stripes
Old Mar 03, 2015, 08:05 AM
CWNG06301's Avatar
Hong Kong
Joined May 2005
Regards
The holiday in China is going on, so I can contact them next week.
They know about the issue of yellow line, they said they can fix it, I will go and see how to do. It is lucky, they only delivered part of my order, I still have some still not delivered to me before the holiday.
After I go to meet them, I would discussing how to do, may be discount or wait next or accept their method if it is acceptabl.
The decal seems not a big problem, I can get the decal form them easy, do you think peoples would repaint it? if yes, they need to remove the attached decal, then repaint, afterward, apply the replacement.
Old Mar 03, 2015, 08:07 AM
CWNG06301's Avatar
Hong Kong
Joined May 2005
Wing Span : 1446 mm (56.93 inches)
Length: 1830 mm (72.05 inches)
Weight : 2300g (81.12 OZ)
Battery required: 14.8V 4S lipo
Power System: 2 x 50 mm ducted fan with outrunner 4200kv motor
Servos: 9 x metal gear 9 g servos and 4 x 9g plastic gear slow motion servos for flap
Old Mar 03, 2015, 08:48 AM
Mach One
Joined Apr 2011
I think some people will like it even better if these planes are offered at a discount provided they paint it when they get it. I personally have no issues with that. You can take a vote here and decide. Thanks again!
Old Mar 09, 2015, 01:54 AM
Smokin_Joes is offline
Find More Posts by Smokin_Joes
What tree??.......Doh!!
Smokin_Joes's Avatar
USA, WA, Seattle
Joined Aug 2007
Received the Supreme-Hobbies A330 on Saturday!
Here are some pics of the unboxing:
I'll update with more pics of the actual plane as I get it built. Hope to get it airborne later this week, most likely this coming weekend....
Box measures 40.25" x 18.5" x 9.25" or 1022mm x 470mm x 235mm
Wings on top
Everything else (lots of fuselage) packed nicely inside the foam box.
Although it uses the same 50mm edf's as in their A320, the engine nacelles are different than the CFM style that come on their A320.
Top and bottom main wing details.
ESC bay. I presume for A340, you'd have two esc's here.
Cheers for now~
Neil
Smokin_Joes is offline Find More Posts by Smokin_Joes
Last edited by Smokin_Joes; Mar 09, 2015 at 10:12 AM. Reason: grammer- I must of already been asleep....
Discussion Supreme-Hobbies 1100 mm A320 PNP whatala Foamy EDFs 626 Jan 24, 2016 09:42 PM
Discussion Supreme Hobbies A340 captain MoMo Foamy EDFs 46 Aug 22, 2015 11:41 PM
New Product 90mm 13-blade Supreme Hobbies mopetista Electric Ducted Fan Jet Talk 22 Nov 15, 2014 08:55 PM
