Old Oct 07, 2014, 12:56 PM
Joined Sep 2014
433mhz beacon transmitter Desensitizing 2.4ghz Spektrum DX6i receiver
I made the coolest tiny beacon transmitter for under $1. It has a range of 2 miles to help me find my lost airplane. Unfortunately I can't fly more than 100m away, because the receiver is desensitized. It's only 10mw output. Luckily I noticed this during range testing before I took off. No matter where I place the new transmitter. I can put the antenna right behind the Prop, or back near the rudder, it doesn't matter. Can I use a low/highpass filter? Is there a simple timer that I can use to keep it off for 30 minutes? I don't want to include another Arduino board, since the transmitter is smaller than a dime.
Any suggestions? I so want to use this idea. Help!
Steve
SBright33 is offline Find More Posts by SBright33
Old Oct 07, 2014, 01:06 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Have you looked at your output harmonics? How are you powering the beacon?
How are you powering the receiver? What receiver are you using? What modulation mode?
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Oct 07, 2014, 03:59 PM
Joined Sep 2014
I don't have a spectrum analyzer, but 5 or 6 x 433.94 is not 2.4. I was powering it thru the 5v servo plug on the Spektrum receiver. Is that a problem? Should I use a separate battery?
I am using this with DX6i
http://www.amazon.com/Spektrum-DSMX-.../dp/B004M166WE
Old Oct 07, 2014, 04:08 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
If your DX6i in DSM2 mode? Do you power up the beacon prior to powering up the transmitter?
Yes, it's a problem to power them from the same battery. A separate battery will help immensely.
Andy
Site Sponsor
Old Oct 07, 2014, 04:16 PM
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
You made it ?
So how do you know the frequency is 433mhz and the power is 10mW ?
With good line of sight maybe, but very much reduced range for a crashed model on the ground in urban or forest areas, maybe as low as 200M or less.
So if the beacon is working, how exactly do you intend to find the model ?
I do think you are assuming you can make something for $1 and it will turn it into some sort of magic very long range locator for finding lost models, unfortunately its really not so simple.
srnet is online now Find More Posts by srnet
Old Oct 07, 2014, 05:31 PM
Joined Sep 2014
Andy you're a Genius! Almost perfect with a small separate battery. I'm using a satellite receiver also. If the Xmitter is near the main receiver, 1 orientation works perfectly, the other about 90% of the distance in Range Check mode. If it's near the satellite, then the opposite is true. Just need a little more distance then I'm golden...
Old Oct 07, 2014, 05:37 PM
Joined Sep 2014
srnet, I measured the input power with my multimeter. I've already tested it at 2 miles, using my Ham HT. It works even in the deepest PA woods. I simply use my rubber antenna driving or walking until I get full quieting in FM mode. Then I remove the antenna and use my finger, walking until the signal is stronger on my signal strength meter. Then I remove my finger and walk until I'm within 10ft of the model. I have tested all this, it's easy. To make it even easier I can use a directional antenna, but this is not needed. I've been doing Fox Hunting in the Ham Radio community since 1978. If all that fails, at close range, I also have a Loc8tor on all models, and a TK102 on my larger models. There's no way I'm going to lose a model in the woods! It really is that simple.
Old Oct 07, 2014, 05:40 PM
Joined Sep 2014
Would anyone like one? I can make more!
Sold Dx6i transmitter and (2)at 600 receivers nh4clo4 Aircraft - General - Radio Equipment (FS/W) 0 Oct 05, 2014 09:53 PM
Sold SPEKTRUM DX6i 2.4GHz DSMX transmitter W/Ar500 receiver almost NEW!! MIKEYOUR Aircraft - General - Radio Equipment (FS/W) 4 May 28, 2012 01:01 PM
Sold SPEKTRUM DX6i 2.4GHz DSMX transmitter W/Ar500 receiver almost NEW!! MIKEYOUR Aircraft - General - Radio Equipment (FS/W) 4 May 23, 2012 07:18 PM
For Sale Spektrum DX6i 6CH Transmitter 2.4GHz MODE 2 Full Range dbrown777 Aircraft - General - Radio Equipment (FS/W) 1 Jun 25, 2010 08:51 PM
Sold SPEKTRUM DX6i DSM2 6 CHANNEL 2.4GHZ TRANSMITTER MODE 2 passerbyeus Aircraft - General - Radio Equipment (FS/W) 2 Aug 17, 2009 10:22 AM
