Old Apr 13, 2015, 06:33 PM
screamin' eagle is online now
Find More Posts by screamin' eagle
Confirmed Chronic
screamin' eagle's Avatar
Pacific Palisades, CA
Joined Jul 2004
Get the Lead IN!
I built a nice DS foamie plank last year, a Canuck Lumberjack. I folded the plane originally and then rebuilt it with a few extra spars. The plane weighs in at around 60 oz, not all that heavy for a 60" plane, but I've run out of room for balancing weight and have had to goop it to the outside. There are 15 oz of lead out there, not including about 10 more ounces inside the plane.
All that lead is generating some drag, and I'm looking for creative solutions to getting some more weight inside. Steel rod? Lead shot? Tungsten powder? The plane is already covered in new stuff but I can live with cutting it open if I can do so cleanly and recover the holes.
The leading edge is already almost all lead slugs from about 1" back.
screamin' eagle is online now Find More Posts by screamin' eagle
Old Apr 13, 2015, 06:36 PM
Confirmed Chronic
Joined Jul 2004
Here's a pic of the plane. In front of the ribbon spar is pretty much all balancing weight and battery. I'd be looking to add weight on either side of the rx bay between the ribbon spar and the sub spar. That is still ahead of the CG but not by a lot.
Old Apr 13, 2015, 08:15 PM
Aerogance is offline
Find More Posts by Aerogance
U down with EPP? Ya u know me
Aerogance's Avatar
United States, CA, Ventura County
Joined Sep 2008
Can you take some weight out of the tail?
Otherwise reshape
Lead fishing weights with a hammer and anvil to increase the mass density in the nose more than shot.
Aerogance is offline Find More Posts by Aerogance
Old Apr 13, 2015, 08:23 PM
RIGAMORTIS is offline
Find More Posts by RIGAMORTIS
Death one circuit at a time
RIGAMORTIS's Avatar
United States, CA, Boulevard
Joined Nov 2012
When I need to make areas for weight-I heat up a piece of Rebar, Steel square or round tubing with a torch and melt the EPP to make whatever shape needed.I either put in a Carbon tube filled with lead shot mixed with epoxy or if it is a fuse i just put the Epoxy/shot mix in and then re tape, goop,whatever needs to be done-
RIGAMORTIS is offline Find More Posts by RIGAMORTIS
Old Apr 13, 2015, 08:30 PM
Aerogance's Avatar
Joined Sep 2008
You had me at "rebar"...
Old Apr 13, 2015, 10:20 PM
RIGAMORTIS's Avatar
Joined Nov 2012
It works
Old Apr 14, 2015, 05:42 AM
Jets:) is offline
Find More Posts by Jets:)
Jets:)'s Avatar
New Zealand, Auckland
Joined Aug 2006
Dude,
just put the rebar in and go fly!
Jets:) is offline Find More Posts by Jets:)
Old Apr 17, 2015, 11:28 AM
Confirmed Chronic
Joined Jul 2004
Just to close the loop on this thread, I used solid poured lead plates and went in through the top of the wing. The weights went behind the arced ribbon spar (there is just no room in front of it). I covered the openings with epoxy and microballoons and then a finish coat of spackle to smooth it out. Patched with new stuff.
Because the balance weight was closer to the CG than before, the plane gained a lot of weight. AUW is now 75 oz, at 60" span...should get faster, I hope.
Old Apr 20, 2015, 07:18 PM
RIGAMORTIS's Avatar
Joined Nov 2012
Originally Posted by Jets:) View Post
Dude,
There is actually one in the worx
Old Apr 21, 2015, 11:35 AM
criterium1 is offline
Find More Posts by criterium1
Joined Jul 2011
would that be a JW?
Ryan, my third is about done......
gonna have to make out to boulevard soon!
criterium1 is offline Find More Posts by criterium1
Discussion Power lead for pdb (battery in) Razza Multirotor Power Systems 1 Mar 21, 2015 07:28 PM
Discussion Where to get Linear Actuators, Ballscrews, Lead Screws. notime_3001 Robotics 8 Sep 02, 2014 09:02 PM
Question Will we ever get any different models than all the ones we keep getting in bigger siz cyclops2 Electric Warbirds 69 Nov 25, 2013 10:26 PM
Question What 3D Foamy to get as a lead in trainer for a Balsa Plane Dan the man 3D Foamies 14 Jun 26, 2013 05:27 PM
Discussion Cant get HH gyro to arm with ch5 lead in BowerR64 Radios 3 Aug 17, 2007 10:01 AM
