Old Dec 17, 2015, 04:08 PM
BillBlair is offline
Find More Posts by BillBlair
Foam Wrecker
BillBlair's Avatar
37°10'36.54"N, 116° 2'46.08"W
Joined Jun 2002
The 250 grams or less flight weight foamie kit thread
The threshold requiring R/C pilot registration in the U.S. is the outdoor, remotely controlled operation of anything that flies that is over 250 grams in mass.
Please add 250g and below flight weight OUTDOOR fixed wing foamie aircraft to this thread if you know of others not included in the list found immediately below. Aircraft must be available in the U.S. or via very cheap shipping from elsewhere, such as China.
Confirm your chosen aircraft's actual flight weight before ordering it because some weight claims may not be correct.:
E-Flite Ultra Micro Radian
http://www.rcgroups.com/forums/showthread.php?t=2089760
Parkjet 2 High Speed Wing EPO 550mm (KIT)
Flying Weight: 210g
http://www.rcgroups.com/forums/showthread.php?t=1959049
http://www.hobbyking.com/hobbyking/s...50mm_KIT_.html
XK A600 4CH Brushless "DHC-2" Scale RTF Plane
http://www.rcgroups.com/forums/showthread.php?t=2397705
FMS Easy Trainer 800mm
http://www.rcgroups.com/forums/showthread.php?t=1678190
FMS V-Tail Glider 800mm
http://www.rcgroups.com/forums/showthread.php?t=2212706
http://www.rcgroups.com/forums/showthread.php?t=2071324
HobbyKing Bonsai EPP Wing 600mm (ARF)
Flying Weight: 100g-140g
http://www.rcgroups.com/forums/showthread.php?t=1512697
NitroPlane RC 4 Channel Mini Pop Wing EPP Kit and ARF Versions
Flying Weight:100-140g
http://www.nitroplanes.com/02a-020-m...pp-aa-kit.html
http://www.nitroplanes.com/02a-020-m...pp-aa-arf.html
Firstar 200 Motor Glider EPO 758mm
Flying Weight: 200g
http://www.rcgroups.com/forums/showthread.php?t=2147052
http://www.rcgroups.com/forums/showthread.php?t=2194509
http://www.rcgroups.com/forums/showthread.php?t=2184013
HobbyKing Mini Sonic Flying Wing EPO 588mm
Flying Weight: 100-130g
http://www.rcgroups.com/forums/showthread.php?t=2048987
HobbyKing Ridge Ryder Slope Wing EPO 913mm
Weight: 175g (w/o battery)
http://www.rcgroups.com/forums/showthread.php?t=2329646
Mini Skywalker 840mm
Flying Weight: 250g
http://www.rcgroups.com/forums/showthread.php?t=1339473
Mini Swift EPO Glider
Flying Weight: 120g (from user comment)
http://www.rcgroups.com/forums/showthread.php?t=1245786
Dolphin Micro Sport EPO
Flying Weight: 175g
http://www.rcgroups.com/forums/showthread.php?t=1424026
HobbyKing Nutball Fun Flyer EPP
Flying Weight: 95~100g
http://www.hobbyking.com/hobbyking/s...60mm_PNF_.html
WLtoys F959 Sky King 3-Channel Airplane RTF (not a kit)
http://www.rcgroups.com/forums/showthread.php?t=2274270
Most of the kits offered by Twisted Hobbys:
http://www.twistedhobbys.com/Airplan...-Span_c184.htm
*** 26" Scythe mini/micro EPP suitcase wing ***
http://www.rcgroups.com/forums/showthread.php?t=1204561
Insanely Fast MiniPopWing Brand new (BNF)
http://www.rcgroups.com/forums/showthread.php?t=1703771
Flyzone Eraze EP Flying Wing (RTF)
http://www.rcgroups.com/forums/showthread.php?t=1816986
Electrifly Flylite Slow Flyer EP ARF 35" Review
http://www.rcgroups.com/forums/showthread.php?t=1159043
Hacker-Model Xtra Vector Wolf 800mm EPP ARF 31.5"
http://www3.towerhobbies.com/cgi-bin...&I=LXFNPA&P=ML
Hacker-Model Quark EVO ARF Blue 32.1"
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXFNNZ
StevensAero Adrenaline Rush, Mini Pylon Club Racer
http://www.stevensaero.com/StevensAe...lub-Racer.html
http://www.rcgroups.com/forums/showthread.php?t=380270
ModelAero Mini Polaris Seaplane
http://modelaero.com/Merchant5/merch...tegory_Code=AM
http://www.rcgroups.com/forums/showthread.php?t=922465 (some posts deal with the mini version)
ModelAero Polaris Micro Seaplane
http://www.rcgroups.com/forums/showthread.php?t=922465 (some posts deal with the micro version)
Weekender by Hitec Zipper P2GO Review
http://www.rcgroups.com/forums/showthread.php?t=2018147
http://www3.towerhobbies.com/cgi-bin...&I=LXDSDX&P=ML
Hitec P2GO Weekender eHawkeye RR 22"
http://www3.towerhobbies.com/cgi-bin...&I=LXDSDY&P=ML
UMX™ Radian® BNF by E-flite
http://www.rcgroups.com/forums/showthread.php?t=2091205
Close, but just over 250g:
X-1 Mini Flying Wing EPO 600mm
Flying Weight: 270g (with 1300mAh 3s lipo)
http://www.rcgroups.com/forums/showthread.php?t=2311276
Wing Wing Z-84 EPO 845mm
Flying Weight: 300g (with 1300mAh 2s lipo)
http://www.rcgroups.com/forums/showthread.php?t=1701769
Combat & Slope Soaring Wing (EPP Foam / CF tube) Kit
Flying Weight: 300g (with 1500mAh 2s lipo)
BillBlair is offline Find More Posts by BillBlair
Old Dec 26, 2015, 10:11 AM
Foam Wrecker
BillBlair's Avatar
Joined Jun 2002
Added links.
Old Dec 28, 2015, 07:49 PM
agentorange90 is offline
Find More Posts by agentorange90
Joined Dec 2014
I'm thinking about building the Mini skywalker. I'm not concerned about the FAA ruling but I want to stay under 250g because I fly at some smaller fields.
agentorange90 is offline Find More Posts by agentorange90
Old Dec 28, 2015, 08:06 PM
BHOFM is offline
Find More Posts by BHOFM
Kimbers Keeper.
United States, AR
Joined Nov 2014
Greatplanes Flylite
Hacker Xtra Vector
Greatplanes Foamie Yak.
Hacker Quark EVO
BHOFM is offline Find More Posts by BHOFM
Old Dec 28, 2015, 09:07 PM
S.Davy is online now
Find More Posts by S.Davy
Save a tree fly a foamy
United States, CA, Marshall
Joined Apr 2005
Model Aero mini Polaris:
And Polaris micro:
Edit
Also Hitec Weekender Zipper:
And eHawkeye:
GWS Micro Slow stick:
http://www3.towerhobbies.com/cgi-bin...&I=LXDCFA&P=ML
S.Davy is online now Find More Posts by S.Davy
Old Dec 29, 2015, 02:43 PM
Vince53 is offline
Find More Posts by Vince53
Potage, MI
Joined Dec 2003
Many kits from Stevens Aero but my favorite "Adrenaline Rush":
It' been around for 10 years!
http://www.rcgroups.com/forums/showt...=380270&pp=100
Vince53 is offline Find More Posts by Vince53
Old Dec 29, 2015, 07:27 PM
Foam Wrecker
BillBlair's Avatar
Joined Jun 2002
Thanks for all of the suggested additions. They have been added to the master list.
Old Jan 01, 2016, 05:44 AM
KristofferR is offline
Find More Posts by KristofferR
United States, CA, Redondo Beach
Joined May 2015
I suggest the Magnum Reloaded. Easy to build below 250g.
http://www.miniprop.com/flugmodelle/...-reloaded-2014
EDIT: it's available from WMParkflyers in the US.
http://www.wmparkflyers.com/acro-mag...low-p-231.html
Needs just a puddle to to fly from, although adding the floats might push weight over the limit
Magnum Reloaded Miniprop on floats, schwimmerbausatz! (1 min 33 sec)
KristofferR is offline Find More Posts by KristofferR
Old Jan 01, 2016, 01:04 PM
turbojoe is offline
Find More Posts by turbojoe
M0unt@in M0del$ minion
turbojoe's Avatar
United States, AZ, Mesa
Joined Jul 2002
I'm surprised I don't see Mountain Models listed here. Brian has many extreme lightweight kits on his site. My Tom-E-Boy 150 weighs 128 grams minus battery and she was built with absolutely no weight saving practices and I'm not using the expensive "brick" systems in this particular bird. Flies fantastic on dirt cheap servos and RX!
Joe
turbojoe is offline Find More Posts by turbojoe
Old Jan 01, 2016, 01:56 PM
Foam Wrecker
BillBlair's Avatar
Joined Jun 2002
Joe
Well, this is a foamie thread because that's what most people want these days and those are balsa and MonoKote.
However, there might be a minor resurgence in the latter type since I believe you can get more wingspan for a given mass with, for instance, a flying wing using that technique than with foam. I'd personally love to see a 250g all up flight weight flying wing kit using laser cut balsa ribs, a lightweight carbon fiber tube spar, covered with MonoKote.
Old Jan 01, 2016, 02:14 PM
brokendiff is offline
Find More Posts by brokendiff
United States, PA, Ephrata
Joined Mar 2015
Surprised I do not see all the umx planes! Or Horizon Hobby's Sport Cub s.
brokendiff is offline Find More Posts by brokendiff
Old Jan 01, 2016, 03:12 PM
silverxxx is offline
Find More Posts by silverxxx
Australia, SA, Adelaide
Joined Mar 2014
The hobbyking bonsai is about 175g with 16g motor
The Hacker "Strega mini 550" is 110g with 10g motor and 300ma 2s
the other aircraft of the 550 series are similar weight.
silverxxx is offline Find More Posts by silverxxx
Old Jan 01, 2016, 03:18 PM
turbojoe is offline
turbojoe's Avatar
Joined Jul 2002
Oops! Didn't pay attention. I saw the thread off to the side on the main page and didn't consider it was foamie. Sorry 'bought dat.
Going with brokendiff's post though I have been migrating to the smaller UMX planes since the new FAA B.S. started. I have the T-28, the Pitts and the Habu EDF with the Carbon Cub on the way. These UMX planes fly 10 times bigger than they are. Rock stable and a ton of fun in the air. You can fly them just about anywhere. I will have access to a gym soon and may start some indoor flying. Can't believe I'm actually flying anything foam after being a balsa snob for so many years.
Joe
Old Jan 02, 2016, 10:33 AM
Foam Wrecker
BillBlair's Avatar
Joined Jun 2002
Thanks. I don't how I missed the HK Bonsai in my search of HK's site. On the others, since this 250 gram thing is exclusive to the US, I prefer US-available aircraft or ones from elsewhere with cheap or free shipping, like from China. From what I've seen of shipping rates mentioned here from Australia and the EU, they are expensive.
Old Jan 04, 2016, 12:26 AM
Joined Apr 2005
http://www.motionrc.com/fms-easy-tra...specifications
http://www.motionrc.com/fms-v-tail-g...specifications
Sold Any kit listed below you like...Let's discuss fair and reasonable price, not EBay Plasmajoe Aircraft - Fuel - Airplanes (FS/W) 4 Jun 23, 2015 06:33 PM
Sold Castle 34-24-750kv (250g) vienquach Aircraft - Electric - Power Systems (FS/W) 0 Sep 03, 2011 11:03 AM
Discussion suitable motor for 250g balsa plane dejfson Beginner Training Area (Aircraft-Electric) 10 Mar 29, 2011 03:28 PM
FS: 3 Formosa Kit 3GWS C-47 kits 1 GWS ME 109 all below retail 2dogrc Aircraft - Electric - Airplanes (FS/W) 0 May 18, 2005 06:20 PM
Yippee! Police Boat or Yacht kits NIB $35.....Below cost! Turbosun Boats (FS/W) 11 May 12, 2003 11:20 AM
