Old Oct 27, 2015, 05:07 PM
Fly Boy3 is offline
Find More Posts by Fly Boy3
United Kingdom, Wales
Joined Jul 2009
Depron/balsa
Been looking at the foam (Depron) models in the foamy section. I am a seasoned balsa and ply ic man testing the water of electrics. Building light has always been the way to go, but I was wondering if I built a balsa model to keep it in the same wing loading parameters, I would have to increase the wing area. Is it possible to do the maths that would give me the wing area for a similar wing loading ie working backwards using wing loading equazion.Cheers ps or would I have to use the TLR method LoL
Fly Boy3 is offline Find More Posts by Fly Boy3
Old Oct 27, 2015, 06:51 PM
BHOFM is offline
Find More Posts by BHOFM
Kimbers Keeper.
United States, AR
Joined Nov 2014
What model. s. do you have in mind?
Nutball type, O-Fungle
40incho fungle (5 min 40 sec)
BHOFM is offline Find More Posts by BHOFM
Old Oct 27, 2015, 07:24 PM
Rhea is offline
Find More Posts by Rhea
Registered with FAA since 2016
Rhea's Avatar
United States, MN, Eden Prairie
Joined Oct 2008
No need to change the wing area.
Rhea is offline Find More Posts by Rhea
Old Oct 27, 2015, 07:46 PM
Boogie_ is offline
Find More Posts by Boogie_
killed another thread
Boogie_'s Avatar
Lake Charles, Louisiana
Joined Jun 2009
Ditto
Boogie_ is offline Find More Posts by Boogie_
Old Oct 27, 2015, 09:07 PM
Bare is online now
Find More Posts by Bare
Canada
Joined Nov 2000
Foam is Light, Cheap and Easy. Disposable too.
Assemble, Fly, Crash .. Build another and another
Not Rokit Science
Bare is online now Find More Posts by Bare
Old Oct 28, 2015, 09:07 AM
Fly Boy3 is offline
Joined Jul 2009
I agree with all you say regarding foam, but i like balsa. That O Fungle is the bizz. where do I get all the details please. Cheers got to build it
Old Oct 28, 2015, 09:16 AM
BHOFM is offline
Kimbers Keeper.
United States, AR
Joined Nov 2014
I am the O-Fungle builder, designer, keeper of the hole.
I will get the plans together for you.
32O Fungle (1 min 20 sec)
Old Oct 29, 2015, 10:36 AM
Fly Boy3 is offline
Joined Jul 2009
O fungle
Cheers B, how do I locate the thread on the builds etc. Thanks ps I do like the new big one too LoL
Old Oct 29, 2015, 11:05 AM
BHOFM is offline
Kimbers Keeper.
United States, AR
Joined Nov 2014
http://www.rcgroups.com/forums/showthread.php?t=2519245
I have the plans done and will get them scanned today and post them
later in the day. Going flying as well, so you will just have to wait a bit!
The 32" build thread is trashed, Imageshack lost several pages of my picture, all
the one for that thread. It is basically the same without ailerons.
Old Oct 29, 2015, 06:05 PM
BHOFM is offline
Kimbers Keeper.
United States, AR
Joined Nov 2014
For the 20", just do the math to get the size you want. all proportions. remain
the same.
Old Oct 30, 2015, 11:28 AM
Fly Boy3 is offline
Joined Jul 2009
Cheers B. thanks a lot for your plans and info. After I get my wood may have some questions to ask Would that be ok ? Cheers
Old Oct 30, 2015, 12:57 PM
BHOFM is offline
Kimbers Keeper.
United States, AR
Joined Nov 2014
Anything I can do to help, just let me know.
Old Nov 04, 2015, 02:24 AM
solentlife is online now
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
I've gone both ways .... built a 'wood' model in foam ... example Pilot QB10 ... and built foam model in wood or partial wood.
Any changes ? Only those to modify to electric use in way of hatches etc.
Formers are moved maybe to allow different set-up ... slab foam sides instead of stringered wood ...
Strip wood instead of foam sheet ...
Foam sheet in fact is a great repair tool on wood models. Allows easy fix of crushed ribs .. formers ... doubling up and securing shape.
My Extra 300 fuel powered job .. wing section crushed was put back without even removing factory covering. Foam sections of ribs were cut ... pushed onto a BBQ sticks pointed end ... glue applied and then carefully inserted into wing and put in place.
No weight repairs ... easy to shape and do.
Fuselage rebuilt, wing done .. cowl to finish ... but basically all back to flight ..
Nigel
solentlife is online now Find More Posts by solentlife
Old Nov 13, 2015, 07:22 AM
basicguy is offline
Find More Posts by basicguy
Dream it...Build it...Fly it!
basicguy's Avatar
United States, MO, Macon County
Joined Dec 2014
I have found that some of my strongest and lightest planes are a composite of balsa and foam. Each has advantages that complement each other.
basicguy is offline Find More Posts by basicguy
Discussion Another Lancaster, balsa and Depron, 98" span. eflightray Foamies (Scratchbuilt) 23 Sep 25, 2014 03:27 PM
Balsa vs. Depron weight... Mighty Dingus Foamies (Kits) 14 Nov 15, 2003 01:57 AM
Best and lightest adhesive for "Depron" to balsa? JonB Foamies (Kits) 1 Feb 10, 2002 09:28 PM
