Old Feb 19, 2012, 12:44 AM
wagondriver42 is offline
Find More Posts by wagondriver42
wagondriver42's Avatar
United States, NY, Rochester
Joined Jul 2011
Question
octura props, whats the dif. between X and M??
Ok this may be a stupid question but what i s the differance between octura X and M props?
wagondriver42 is offline Find More Posts by wagondriver42
Old Feb 19, 2012, 04:14 AM
bill34207 is offline
Find More Posts by bill34207
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
The M series are X's that have been detongued.
bill34207 is offline Find More Posts by bill34207
Latest blog entry: Freewing F-5N Tiger 80 mm EDF
Old Feb 19, 2012, 04:30 AM
osprey21 is offline
Find More Posts by osprey21
osprey21's Avatar
Palma Sola,Fla.
Joined Oct 2006
Just to carry this a bit further:
X4 are low lift general purpose props
M4 is similar to X4 but with the tongues removed to unload the prop
Y are similar to X series but have 10% more pitch
X5 are similar to X4 with medium lift and more pitch
X6 similar to X4 and X5 with medium-high lift
14 are medium-high lift commonly used for hydros
16 are high lift props for riggers and hydro's
17 are the highest lift prop for riggers and hydros
P7 are similar to 17 series but more rake and slightly less lift
19 are high lift for riggers and hydro's
V9 are moderate lift and high pitch suitable for riggers, hydros and SAW racing
20 are moderatley high lift with high pitch suitable for riggers and hydros
21 are high lift for riggers and hydro's
22 are high lift, highest pitch surface drive only good straight line speed
osprey21 is offline Find More Posts by osprey21
Old Feb 19, 2012, 10:50 AM
Joined Jul 2011
Wow info overload lol, thanks guys
Old Feb 19, 2012, 03:54 PM
mozzyrocks is offline
Find More Posts by mozzyrocks
Australia, VIC, Blackburn North
Joined Feb 2011
This is fantastic info as now it opens my prop choice right up!
I had no idea what the differences were.
Thanks Osprey!
I have a question.............
I have the X437/3 prop, if I went the Y537/3 would that pull more water or less?
Is that a clear question? lol
I'm going to run my 4082 1600kv on 6S & was thinking of the smaller prop for more RPM & if I can have more bight from the smaller prop I'm thinking I'll get more speed.
Would that be correct?
mozzyrocks is offline Find More Posts by mozzyrocks
Old Feb 19, 2012, 03:59 PM
rotorkilla is offline
Find More Posts by rotorkilla
rotorkilla's Avatar
Stoke-on-Trent, UK
Joined Nov 2010
A Y537/3 would pull more water as you put it but to be honest i'm yet to try anything other than 1.4 pitch as if you prop it right you shouldn't need to increase the pitch, though detonging on the other hand with a M series prop is well worth it as it allows the motors to unwind more.
JMO
rotorkilla is offline Find More Posts by rotorkilla
Old Feb 19, 2012, 04:09 PM
Joined Feb 2011
Yeah, I understand that correct propping is the key, however, I want to give this a try to see what results come of it.
I just thought I'd ask about the effect the prop would have.
Another Q......
If I used a 2 bladed prop over a 3 bladed, can I use a larger diameter due to less surface area of the prop?
Old Feb 19, 2012, 04:17 PM
rotorkilla's Avatar
Stoke-on-Trent, UK
Joined Nov 2010
You can, if you were going to use a 3 blade prop over a 2 blade then you need to drop a few mm in diameter, for example i was running a X445 on my Pursuit and i now run a X440/3 which is detonged, i then found i got alot better acceleration all round whether exiting corners or standing start though i did have a very slight increase in temps and top speed by a couple of mph.
If going to larger pitch props remember to monitor temps closely as little increase in pitch or diameter can make a huge difference to temps.
The best mods you can do to a prop is too lighten it, balance it and most importantly sharpen it. I can spend many hours doing this to a prop but the difference it makes is outstanding and best of all it's free.
Old Feb 19, 2012, 04:27 PM
Joined Feb 2011
Hehehe, yep, sure is free, but, the only cost is cut fingers!!
Done that too many times!
Old Feb 19, 2012, 04:35 PM
rotorkilla's Avatar
Stoke-on-Trent, UK
Joined Nov 2010
It ain't sharp until you can cut yourself on it
I usually find i tend to do this when tightning the prop back onto the drive shaft as i tend not to have a towel handy and i don't want holes in my jumpers or jackets so i end up hold a blade between a finger and thumb.
Old Feb 26, 2012, 04:00 PM
Kcal is offline
Find More Posts by Kcal
Joined Jul 2008
Ha I do not know if it was lightened much but it sure did cut my flesh just fine, and this was a three bladed prop for a “springer”.
Kcal is offline Find More Posts by Kcal
Old Feb 26, 2012, 04:01 PM
Kcal is offline
Joined Jul 2008
Oops sorry guys hope I don’t have to hand in my FE card now….
Old Feb 26, 2012, 07:12 PM
idocdave01 is offline
Find More Posts by idocdave01
Joined Mar 2010
Does any one know this info about other makes of props, Prather etc.
idocdave01 is offline Find More Posts by idocdave01
Old Oct 14, 2012, 08:06 PM
Kcal is offline
Joined Jul 2008
Is there a way for me to get the actual meat of this thread “stickied”? I notice the FE forum doesn’t really have a way to maintain information a lot of us find useful.
Old Oct 15, 2012, 08:58 AM
highflyerbill is offline
Find More Posts by highflyerbill
Gordonsville,Virginia
Joined Nov 2009
Some good information . www.aircapitolhobbies.com/Prop_Charts.html
www.aquacraftmodels.com
www.offshoreelectrics.com/propeller-chart.php
highflyerbill is offline Find More Posts by highflyerbill
Discussion Whats the dif between an AX SCX10 TR and an SCX10? spacephrawg Off-road Cars 31 Aug 19, 2010 12:02 AM
Discussion Whats the dif between the XC-01 and the CC01? spacephrawg Rock Crawlers 1 Mar 02, 2010 10:21 AM
Discussion is there much difference between an octura y 535 and an x 535 propeller ? mortonj69 Dock Talk 7 Nov 22, 2009 02:55 PM
Discussion whats the dif between the AR6100 and the 6000? kushal_22 Electric Plane Talk 3 Apr 24, 2007 02:45 PM
Question Whats the performance dif between APC E & APC SF? dst Power Systems 10 Jan 04, 2006 10:29 PM
