Old Mar 16, 2014, 11:38 AM
Joined Mar 2014
EMAX Multirotor 4in1 ESC- confused.com
Hi - anyone any experience of one of these?. Manual in chinglish and makes no sense.
I've got one strapped to a Q450 with KK2.0 and emax xa2212/980 motors.
all setup well. arms fine. But for the life in me i cant figure out how to throttle calibrate the ESC (do i do it once, or all 4 individually) or even ensure they're all aligned properly. For example, how do i know signal wire 3 be in the 3rd KK2.0 motor input?
There's a 6 wire output from the EMAX, first 3 include BEC, then individual signal wire (i guess - cos no schematic) for i assume motors 1,2,3,4
any help - would be appreciated.
Cheers
flanshaw guy is offline Find More Posts by flanshaw guy
Old Mar 17, 2014, 07:25 AM
dberend's Avatar
Joined Jan 2013
I just set a quad up with one of these. I had to calibrate each individually by plugging directly in to the receiver throttle channel.
dberend is offline Find More Posts by dberend
Old Mar 17, 2014, 07:27 AM
dberend's Avatar
Joined Jan 2013
And the connection with bec is motor 4 then 3,2,1
Old Mar 17, 2014, 08:41 AM
Joined Mar 2014
Great - thanks for prompt response, will try this when i get home tonight.
Once working how'd u get on with it - any good ?
So
1. Plug each output from 4in1 into throttle reciever channel, one at a time
2. Reverse my connections from 4in1 into KK2
J
Old Mar 17, 2014, 10:06 AM
dberend's Avatar
Joined Jan 2013
I haven't flown with it much. I wanted to figure out how to turn off low voltage cutoff first. It seemed to work pretty well though. It looks much nicer than having four separate escs also.
Old Mar 20, 2014, 03:12 PM
Joined Mar 2014
All working. Tips for others.
1. if using with KK2. the EMAX needs to be mounted upside down (ie red plate facing downwards) so the output S4 goes to motor input 1 on kk2, S3 to 2, S2 to 3, S1 to input 1.
To calibarate, can do indivudally. Each EMAX output (s1,S2,S3,S4) to go one at a time into throtlle channel of your reciever (bypass the KK2) . Put transmitter at full, turn on power and connect battery to emax, wait 2-3 secs for beep, move throttle to bottom position asap, wait 2-3 for beep and throttle back up. For S2,S3,S4 which DO NOT have +/- power, you'll have to put S1 into another channel except throttle and repeat above - a little confusing as you'll get two ESC beeping, but follow above and works.
Anyone wants to me to run through with them, just inbox me.
Happy flying ...
Old Mar 21, 2014, 09:23 AM
rimshotcopter's Avatar
Joined Aug 2009
I really like the neatness. I am sold, will order two, one as a back up.
rimshotcopter is offline Find More Posts by rimshotcopter
Old Mar 31, 2014, 09:02 AM
smuench's Avatar
United States, VA, Glen Allen
Joined Aug 2012
I ordered one of these today found it in US at Amazon $49.95 free 2-day shipping
http://www.amazon.com/Multiroter-Qua...A1GOBU5M8OAUJ0
I like the combined neatness, centralized weight distribution, and the SimonK firmware, I'll update when I get it tested
smuench is offline Find More Posts by smuench
Old Mar 31, 2014, 11:07 AM
Joined Aug 2009
I made a purchase of one today also, hope to have it in hand soon.
Old Apr 13, 2014, 05:38 PM
ReVolt- Proprietary Insanity
geostomp's Avatar
United States, MI, Wixom
Joined Sep 2007
Get them shipped from the US here: http://basexrc.com/index.php?main_pa...roducts_id=224
geostomp is offline Find More Posts by geostomp
Old Apr 19, 2014, 09:07 PM
Joined Apr 2014
esc reset
followed the instruction to direct connect to thr ch. and wait for the beeps.did not get anything on motor #4 .all props running at different speeds.help...........
diverman2 is offline Find More Posts by diverman2
Old Apr 19, 2014, 09:17 PM
Joined Aug 2009
Throttle range Calibration maybe?
Old May 08, 2014, 11:18 AM
Joined Aug 2009
These EMAX QUATTRO 25A x4 in 1 Brushless Speed Controller ARE JUNK, I would not recommend them at all. Within 30 Seconds of Initial testing without props, one of the four ESC burnt. Please save your money and get some standard ESCs.
Old May 08, 2014, 12:26 PM
geostomp's Avatar
Joined Sep 2007
Man that stinks, probably literally. Maybe you got a bad one. I know mine has worked flawlessly running Emax 35mm pancake motors on 4S.
Good thing you can get a single board to replace the burnt one from Emax.
Old May 08, 2014, 12:48 PM
Joined Aug 2009
Would you have a link for Emax?
New Product EMAX XA2212 motor for multirotors EMAX Yin Yan Multirotor Power Systems 10 Sep 24, 2014 04:56 PM
New Product EMAX MT motors and CF props for multirotors EMAX Yin Yan Multirotor Power Systems 3 Mar 29, 2014 09:38 PM
New Product Skywalker Quattro 4in1 Multirotor ESC bobepine Multirotor Electronics 45 Mar 02, 2014 10:59 AM
Sold TMotors MT2208-1100KV, Tiger Props, 4in1 Flashed ESC BLHeli Firmware, Brand NEW! sg1anubis Aircraft - Electric - Multirotor (FS/W) 0 Nov 25, 2013 10:39 PM
