Old Mar 31, 2014, 08:28 AM
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
exchanging/adding caps, to make better/cooler esc..
Hi, theres been some info that the YEP esc:s could run into trouble:
http://www.rcgroups.com/forums/showt...964112&page=12
Read from #178
I will add caps to my yep esc:s, will also put some pictures here when doing it..
sebbe is offline Find More Posts by sebbe
Old Mar 31, 2014, 08:46 AM
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
OK, first remove the shrink... Ive found spots marked A and B in picture where I think would be perfect to solder the new caps to.
I will fill in later when I get some caps...
Old Mar 31, 2014, 08:49 AM
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
I think it will be ok like this?
Old Mar 31, 2014, 09:08 AM
Grow old disgracefully!
dickw's Avatar
Luton, UK
Joined May 2006
Originally Posted by sebbe View Post
So what caps? Ive read that Panasonic ones are among the best, does anyone have som link to these, what series and so.................
I have used the Panasonic FR series with success. I got them here and there is a data sheet link on that page:-
http://uk.rs-online.com/web/p/alumin...itors/7083932/
Dick
dickw is offline Find More Posts by dickw
Old Mar 31, 2014, 10:16 AM
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Thanks Dick,,, But Ive found th FM pana. here in Sweden..
Old Mar 31, 2014, 10:32 AM
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
OK , did order this Caps:
Panasonic Fm series
470 uF 35VDC
560 uF 50VDC
680 uF 50VDC
820 uF 50VDC
will have them in few days
Old Apr 08, 2014, 09:07 AM
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
OK, its time.... the new caps arrived, remove the shrink, add solder to new wires......
Old Apr 08, 2014, 09:24 AM
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Last photos before some test...
Old Apr 08, 2014, 09:30 AM
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
First TEST...... :
OK, I did have to go down to basement to do some first test, forgot my camera as I went down, but the first test is only to see if it on the right side or not...
Test was with Mega 16/40/1, small prop (think it was 4.7x4.7?) 5s lipos(not the best)
* 10 second run with stock= stock caps a bit hot
* 10 second run modded one= stock caps much much cooler, the panasonic caps where as cool as ice
I know this isnt a scientific test, but at least it shows the original caps runs much cooler..
Will this help to keep the esc alive? dont know, is the mod in right direction? I think so..
Will test more later.. From waht I could feel with my lips the side of esc where the fets in middle are the stock esc seems hotter...
The amp draw is around 130-140 amps, as I have done this before...
edit: Also did run some partial throttle before going full 10 seconds, same on both.., I also have a powerfull fan blowing on motor to keep it on good side
Sebbe..
Discussion Help me make a better decision! Tractuspk Mini Multirotors 4 Dec 12, 2013 12:17 AM
Mini-HowTo CPO Quick Tip :: Pimp Your Helping Hands (Make Them Better) cpo Beginner Training Area (Aircraft-Electric) 0 Nov 27, 2013 10:22 AM
Sold [CLOSED] - Jive ESC Data Logger - jLog2 Making your ESC that much better!! Wynn1427 Aircraft - Electric - Power Systems (FS/W) 5 Apr 04, 2012 11:24 AM
Esc Graupner Power Moss-how Could I Make It Works Cooler? CESARNOGUEIRA Power Systems 1 Sep 24, 2001 01:15 PM
