Old Oct 20, 2014, 08:05 AM
nevenelestate's Avatar
United States, MD, Charles County
Joined Feb 2014
Originally Posted by jh1985 View Post
Motor upgrade !!!!
Im not sure if anybody did this yet. I just put the motor from the sport cub s in my p40 and mustang.
This motor? http://www.horizonhobby.com/motor-wi...cub-lp-hbz7134
nevenelestate is offline Find More Posts by nevenelestate
Old Oct 20, 2014, 09:22 AM
COPENHAGEN DENMARK
Joined Aug 2007
No you need the motor from the Hobbyzone Sports Cub S. The one, in the picture, weight more than the hole Mustang.
John
johnkielsen is online now Find More Posts by johnkielsen
Old Oct 20, 2014, 09:31 AM
Joined Feb 2014
John
It's the same as the stock motor?
Old Oct 20, 2014, 02:55 PM
COPENHAGEN DENMARK
Joined Aug 2007
It is longer 23mm, the stock is 20mm. But there is some faster ones look here
www.micro-motor-warehouse.com You have to solder a bit.
John
Old Oct 20, 2014, 07:37 PM
United States, NC, Winterville
Joined Jul 2014
So the sport cub s motor is just a drop in replacement?
Jmel is offline Find More Posts by Jmel
Old Oct 20, 2014, 07:51 PM
Joined Jul 2014
yes and with the 4 blade it wakes them up nicely. I had my p40 just about hovering.
jh1985 is offline Find More Posts by jh1985
Old Oct 20, 2014, 08:06 PM
Joined Jul 2014
Cool. Ordered one from rc planet just now. Ought to be fun.
Old Oct 20, 2014, 10:27 PM
Joined Jul 2014
its the easiest way to speed them up ive found. Dont take your motor mount out just hold it tight and twist the motor to break the glue. slide it out and slide the new one in with a dab of glue and your good to go. Let me know what you think. I ordered 3 from my lhs next one is the corsair.
oh had to mount my battery slightly more rear for cg.
Old Oct 21, 2014, 09:14 AM
Still Flying
OldRCNut's Avatar
United States, WI, Fond du Lac
Joined Mar 2013
Motor Changes
John
Guy's,
The 8.5 x 23mm motor is the same one used in the MSRX and AS3Xtra. Several of us have been repowering the micros from the stock 20mm long motor with this motor. If you search my old posts you will find rpm data but no thrust data as I have no way to take it. It is a nice boost in power when matched with the Eflite 150 mah 45C batts.
John is correct the Micro Motor Warehouse -15 motor is another good choice. While it is only 20mm long it is a big jump in power. I have one in my Spit. The problem is that is that the extra power comes at a price and the 150 mah 45C batts will only give about a 2.5 minute flight before LVC. I have recently been flying with the Miniaviation 220 mah 45C batts but can't quite get a 4 minute flight. However it is cooling down now in Wisconsin and they may be fine in the summer.
In all cases I stick with a 9T pinion. With the Micro Motor -15 motors come with a neat nylon 9T pinion that works great.
OldRCNut is offline Find More Posts by OldRCNut
Old Oct 21, 2014, 12:07 PM
Joined Jul 2014
My motor mount is loose from a recent crash. I was about to reglue it in when I saw the post about the cub motor. So now I'll just put the new motor in when I fix the mount. I should be able to try it out by Saturday (if RC planet ships today).
EDIT: Probably won't have it by weekend, but still looking forward to it...
Sold Parkzone P-51D Mustang RTF MIKEYOUR Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Apr 29, 2013 10:38 AM
For Sale NIB Align P-51D Mustang RC4RS Aircraft - Electric - Airplanes (FS/W) 3 Apr 14, 2013 08:47 PM
Sold GWS P-51D mustang moore5201 Aircraft - Electric - Airplanes (FS/W) 0 Apr 02, 2013 07:42 PM
New Product Hanger 9 P-51D Mustang 40 ARF Mikemynameis Electric Warbirds 2 Apr 02, 2013 01:08 PM
Sold Parkzone P-51D Mustang Bind n Fly With Extras! Torx Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 5 Oct 14, 2010 11:07 AM
