Old Aug 02, 2005, 04:03 PM
Build'em and Crash'em
Ken Lapointe's Avatar
Narragansett, RI
Joined Oct 2000
Build Log
Jet Hangar Hobbies (JHH) F-86 Sabre Build
I have just started a conversion of the Jet Hanger Hobbies (JHH) F-86 Sabre. I plan on powering it with a HW-750 fan and an HP 370/30/A2 S Motor on a 10S Lipoly Pack using the Jeti 90 ESC.
Some pics of the fuselage next to my EJF (aka: HOB or PFS) F-86 which is powered by a Midi Fan. The JHH Sabre is just a tad bit larger.
Also a pic of the Midi fan next to the HW-750 fan. The 750 fan sure looks much larger.
I won't bore folks with the typical parts of the build like sheeting foam wings or sanding balsa tail feathers.
- Ken
Ken Lapointe is online now Find More Posts by Ken Lapointe
Old Aug 02, 2005, 04:05 PM
Narragansett, RI
Joined Oct 2000
Some information links for F-86 builders
As part of the build I did some research on paint schemes for the Sabre. Here are a number of URLS for various paint schemes.
3 pages at BVM Jets
http://www.bvmjets.com/JetKits/F86_60/paint_schemes.htm
Some great photos, 5 pages of F-86 Sabre and Canadair CL-13 at
http://www.airliners.net/search/phot...nct_entry=true
Nice model of the Boeing Chase Plane Sabre in red and white at
http://www.ipmsstockholm.org/magazin...sson_sabre.htm
Some civilian schemes at for Flight Systems Inc at
http://f-86.tripod.com/fsi.html
and
http://www.heebie.net/4images/detail...1020f66d187edd
Some good Sabre info and stuff at Duncans Sabre Page
http://f-86.tripod.com/index.html
Some Pics of the Boeing Chase plane schemes at
http://www.clubhyper.com/reference/sabre5jh_1.htm
Some walk around photos at
http://cybermodeler.com/aircraft/f-86/f-86.shtml
and
http://s96920072.onlinehome.us/AWA1/...2/walk146b.htm
Orange and white Sabre Scheme at Promark
http://www.pro-mark.com/bvmf86.htm
Some Sabres at China Lake
http://www.chinalakealumni.org/1992.htm
A few Sabres at Cloud 9 Photography
http://www.cloud9photography.us/sub-ej-001.html
Some Schemes and Decals at Aircraft Resource Center
http://www.aircraftresourcecenter.co.../F-86/F-86.htm
Some Canadair CL-13s Aviation museum (note itís a slow link)
http://www.aviation.technomuses.ca/c...&submit=Search
And of course a Goggle Image search using Sabre F-86 will yield lots more
So far I am leaning towards the Airspray Scheme as seen at
http://www.airspray.com/target_div.htm
And
http://www.clubhyper.com/reference/s...rsprayrp_1.htm
Its sharp and not the same old silver F-86. Who knows I may change my mind when it comes to actually painting it.
- Ken
Old Aug 02, 2005, 05:31 PM
smug in granny panties
monkamarm2000's Avatar
NorCal Silicon Valley
Joined Aug 2002
cool, another awesome big build!
Barry
monkamarm2000 is offline Find More Posts by monkamarm2000
Old Aug 02, 2005, 06:51 PM
shut up & fly
hoser's Avatar
United States, FL, Miami
Joined May 2001
VERY exciting!
get that 750 balanced right and it will be almost silent except for the cool suction sound
hoser is offline Find More Posts by hoser
Old Aug 02, 2005, 07:18 PM
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Nice project Ken, headed for larger planes myself and watching these threads closely.
Eric B.
AirX is offline Find More Posts by AirX
Old Aug 02, 2005, 07:22 PM
2014 EDF JET JAM We be Jamming
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Nice one!
Kevin Cox is offline Find More Posts by Kevin Cox
Old Aug 02, 2005, 08:31 PM
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Good Luck with the build.
Bob
bruff is online now Find More Posts by bruff
Old Aug 02, 2005, 08:55 PM
Ellington, Connecticut, United States
Joined Apr 2001
I like the blue one on the BVM page.
Jim
JimF is offline Find More Posts by JimF
Old Aug 03, 2005, 12:16 AM
Windup the watts brigade
TGoodwin's Avatar
Las Vegas, NV
Joined Dec 2000
This should be sweet!
I have a JHH F86 fuse stored in my shop that I picked up at a garage sale a few years back. Also have a JHH Mirage III kit and a Byron F16 kit that could make some nice large EDF's out of.
TGoodwin is offline Find More Posts by TGoodwin
Old Aug 03, 2005, 05:07 AM
It's like an addiction!
Downwind3Zero's Avatar
NY, Rochester
Joined Oct 2003
Ken, where did you order the HW-750 from? I'm looking for a 120mm fan, either Turbofan 4000 (prefereably) or HW-750, any ideas?
Chris
Downwind3Zero is offline Find More Posts by Downwind3Zero
Old Aug 03, 2005, 10:22 AM
Narragansett, RI
Joined Oct 2000
Chris,
I got this from someone on the e-zone. I heard they stoped making the 750 a while back. Not sure if anyone has any for sale. I also heard that they T4000 was still a work in progress.
- Ken
Old Aug 03, 2005, 11:55 AM
NY, Rochester
Joined Oct 2003
Correct Ken! The TF4000 hasn't been able to live up to quality standards, allthough the fan itself (if you get one from a good batch) is fine. They are backordered until 2006 so I guess that's not an option?! Only chance is if someone is willing to part with it The HW750 must have considerable balancing problems and pulls far more Amps than the TF4000.
Have fun with your Sabre Ken - nice looking!
Chris
Old Aug 03, 2005, 01:38 PM
Gordon's Avatar
Braunton, North Devon, England
Joined Aug 2000
Originally Posted by Downwind3Zero
The TF4000 hasn't been able to live up to quality standards <SNIP> The HW750 must have considerable balancing problems
Hmmm. I wonder if part of the problem lies with the motor shafts not being man enough to stop whirling, vibration, etc? The distance between the bearings will be quite large on a motor long enough to have the weight and surface area to absorb and dissipate the waste heat and the shaft could possibly flex if whirling set in. I realise that the armature will provide some support to the shaft. A 5" rotor might well need a shaft as thick as that of an OS.91, unless the rotor is as light as Schuebeler makes his 90mm carbon rotors.
Perhaps special EDF motors are needed.
Just thinking aloud. My thoughts might be just rubbish
Gordon
Gordon is offline Find More Posts by Gordon
Old Aug 03, 2005, 02:20 PM
dapple63
A moderator felt this post violated the following rule: Offensive content (Offsite link). It is temporarily hidden while dapple63 edits it.
Old Aug 03, 2005, 02:48 PM
k_sonn's Avatar
Bellevue, WA
Joined Feb 2004
Ken,
Nice!! I would love to build mine at the same time but I have to build and scale out a Top Flite Bonanza for a customer this fall/winter. I will follow your progress.
Later,
Kirk
k_sonn is offline Find More Posts by k_sonn
FS: Jet Hangar Hobbies F-86 DF Jet ARF Inconel_601 Aircraft - Fuel - Airplanes (FS/W) 2 Apr 28, 2005 12:29 PM
Wattage F-86 Sabre jet-what's the lowdown? tnsfrk Parkflyers 2 Aug 27, 2002 01:54 AM
Wattage F-86 Sabre Jet...finally!!! tnsfrk Electric Ducted Fan Jet Talk 2 Jun 29, 2002 06:09 PM
Wattage F-86 Sabre jet...finally!! tnsfrk Foamies (Kits) 0 May 14, 2002 10:02 PM
F-86 Sabre jet video! pohlmeyr Electric Ducted Fan Jet Talk 17 Jan 13, 2002 09:35 AM
