Old Mar 12, 2014, 06:15 AM
gsantos_pt's Avatar
Portugal
Joined Feb 2011
Build Log
Tricopter Multiwii Wood Frame CNC - Build and Improvements
Hello!
Welcome to my Tricopter Project
This is a custom project designed by me. At the beginning this was mainly for doing some agressive flips but I made some modifications to make this work as a FPV machine too.
Made with 2mm plywood and aluminium tubes, the result it's a very light and powerful machine. I designed all plywood parts on a CAD software and cutted them in a big CNC Milling Machine.
This was the Template that I made for the Milling Machine:
Then after programming the Machine it is ready to start the cut:
Video of the Milling Maching cutting my Tricopter:
CNC Milling Machine cutting Tricopter Parts (1 min 28 sec)
The result wasn't good enough (too much errors) so some handwork was need for get the Tricopter parts out of the plywood plate:
After all issues fixed the plates finally fit in place:
The yaw motor needs to be modified to fits in place:
Simple yaw system build with landing gear parts from a rc airplane and a carbon rod for the axis. Strong and smooth:
Cable ties are strong enough for would all yaw system in place and a very light option:
Now it's time to mount a digital cheap servo for make this work:
Z axis done!!
More two motors mounted on plywood:
After hold the motors in the aluminum tubes with cable ties next step it's soldering the speed controllers and mount hold them too to the tubes:
After some work on this you could have some troubles as this:
Tons and tons of soldering and everything it's connected. I didn't use a power distribution board for save some space and weight (hope so) and looks a clean:
This was doesn't look so clean but it works:
All ready for prevent a fire and an explosion and yellow connector in place
Now it looks a Tricopter! Almost ready to fly or crash
The Multiwii Crius SE 2.5 looks to work too and have a very powerful blue led that is brighter than the sun and dazzles me:
The Crius it's a very small board that is a must for a small tricopter or even smaller projects as 250mm Quadcopter. The receiver has about the same area:
Almost need some propellers and it should be ready for the first crash
Ok now it's ready for crash or fly. I really prefer the second option but sometimes...
Here is mainly parts links used in this build
Motors: http://www.hobbyking.com/hobbyking/s...354&aff=157138
Propeller:http://www.hobbyking.com/hobbyking/s...334&aff=157138
Speed Controllers: http://www.hobbyking.com/hobbyking/s...460&aff=157138
Servo: http://www.hobbyking.com/hobbyking/s...342&aff=157138
Flight Controller: http://www.rctimer.com/product_761.html
Battery: http://www.hobbyking.com/hobbyking/s...937&aff=157138
Yaw system: http://www.hobbyking.com/hobbyking/s...432&aff=157138
Yaw servo: http://www.hobbyking.com/hobbyking/s...342&aff=157138
Spacers: http://www.hobbyking.com/hobbyking/s...dProduct=29541
Hook and loop: http://www.hobbyking.com/hobbyking/s...801&aff=157138
Prop adapter: http://www.hobbyking.com/hobbyking/s...579&aff=157138
Aluminum Tube Red: http://www.hobbyking.com/hobbyking/s...650&aff=157138
Aluminum Tube Silver: http://www.hobbyking.com/hobbyking/s...649&aff=157138
Now it's time for some videos. After many hours of PID tunning it's enough stable for do some aerial footage on auto level mode. I think the problem are these speed controllers and I already ordered some HK Blue Series 30A and will test them soon. The only way to get some decent footage it's on acro mode but it requires more skill to make it steady and level in the air. For aerobatics it a quite impressive machine
This are my PID's that now are the best. They look weird as you can see. Flying these with the default PID's it's a good challenge
screencast
First time trying some flips:
Multiwii Tricopter Flip Test #1 (1 min 47 sec)
And second with some adjustments. Crash at the end when I switched from ACRO to STABLE because RC Rate was very high and the Tricopter wasn't level
Multiwii Tricopter Flip Test #2 (1 min 44 sec)
After some practicing it's better now and no more crashes yet
Tricopter Multiwii - Hovering and Flips (3 min 24 sec)
Next step will be mount all fpv hardware on this and see if it works well. I will use a boscam 5.8Ghz 200mw system.
Visit also my Damper Vibration Thread for Mobius Camera:
http://www.rcgroups.com/forums/showthread.php?t=2121382
Stay tunned, more stuff coming soon
gsantos_pt is offline Find More Posts by gsantos_pt
Old Mar 18, 2014, 05:04 AM
gsantos_pt's Avatar
Portugal
Joined Feb 2011
Hello!
I made this video on last sunday with a mobius mounted on my hat. This was the result:
Multiwii Tricopter Acro Mode (3 min 41 sec)
Cheers
Old Apr 07, 2014, 02:54 PM
gsantos_pt's Avatar
Portugal
Joined Feb 2011
Just another video with Mobius on the Multiwii Tricopter:
Multiwii Tricopter Epic Flight (2 min 35 sec)
For Sale custom wood frame Quadcopter, turnigy 30a, propdrive 28/26,multiwii fcb multitalented1 Aircraft - Electric - Multirotor (FS/W) 2 Aug 06, 2013 01:54 PM
New Product cnc aluminum tricopter frames mindstalker Multirotor Talk 13 Jul 19, 2013 10:55 AM
Build Log Tricopter or any multi DIY all wood frame, cheap and durable Nek Multirotor Talk 56 May 04, 2012 01:19 AM
Sold CNC Tricopter Frame Xnaron Aircraft - Electric - Multirotor (FS/W) 5 Apr 28, 2011 05:10 PM
