Old Feb 20, 2014, 07:22 AM
The_RattleSnake's Avatar
Joined Jul 2007
Quad tilt Rotor FORWARD swept wings project
Starting off my most out there design so far.
As the title suggests, its a Quad tilt rotor forward sweep wing. Balsa and carbon contrsuction design.
I will be adding pics as I progress.
The_RattleSnake is offline Find More Posts by The_RattleSnake
Old Feb 21, 2014, 05:12 PM
Australia, NSW, Sydney
Joined Sep 2012
I like it
jolyboy is offline Find More Posts by jolyboy
Old Feb 22, 2014, 06:39 AM
Joined Nov 2008
Nice to see someone trying something a bit different. Looking forward to seeing this come together. Our Ruskie friends have done some forward swept wing projects in the past but never anything vtol as far as Im aware.
Perhaps having a forward centre of lift would assist transition?
yamax87 is offline Find More Posts by yamax87
Old Feb 23, 2014, 03:44 PM
Joined Jul 2007
Yea, I want something different alright, and I read that forward sweep performs well although I have no experiance with it.
The cg calculator says it should be right where the leading edge meets in the middle.
Old Feb 24, 2014, 01:29 AM
Joined Jul 2007
Location of the carbon fibre rods.
Old Feb 25, 2014, 02:00 AM
Joined Jul 2007
Sheeted the bottom edge, carbon rods epoxyd in place
Old Feb 27, 2014, 03:41 AM
Joined Jul 2007
Front top sheet and leading edge glued on.
Old Mar 02, 2014, 01:05 AM
Joined Jul 2007
Front edge shaped and holes made to run all of the wires.
Old Mar 02, 2014, 04:52 PM
RCvertt's Avatar
Joined Aug 2007
Looks like a fun build.
Any idea what motors and such you will be using?
RCvertt is offline Find More Posts by RCvertt
Old Mar 04, 2014, 08:25 AM
Joined Jul 2007
I've got 4 Ntm 2826 1200kv to use, and 4 30 amp affro esc's.
Finished the sheeting and started on the controll surfaces.
Old Mar 05, 2014, 04:20 AM
Joined Jul 2007
First version of the rotor tilt mechanism.
Old Mar 05, 2014, 12:31 PM
RCvertt's Avatar
Joined Aug 2007
Sounds like good motors. Nice to see someone using direct drive on the tilt mech.
Old Mar 05, 2014, 04:02 PM
Ran D. St. Clair's Avatar
United States, CA, Sunnyvale
Joined Dec 2006
Is there a vertical stabalizer surface somewhere in the tail on this design? If not, it will diverge in yaw when in forward flight.
Ran D. St. Clair is offline Find More Posts by Ran D. St. Clair
Old Mar 06, 2014, 03:48 PM
Joined Jul 2007
Give me some credit , yes there will be a vertical stabalizer which will form
part of the landing gear.
Started on the fuselage.
Old Mar 07, 2014, 12:11 AM
Joined Sep 2012
Looks beautiful!!
Discussion QTD- Quad Tilt Duino (Arduino- Tilt Rotor) RCvertt VTOLs 100 Jun 28, 2012 12:15 AM
Rave The Golden wing is a 60" forward swept wing for thermal/light air slope. kylekroker Flying Wings 47 Oct 17, 2008 10:37 PM
Build Log Forward Swept Wing with functional canard project BlueFielder Foamies (Scratchbuilt) 12 Jan 04, 2008 12:56 PM
