Old Apr 19, 2015, 03:10 PM
coriolan is online now
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
Thank robairt, very interesting indeed......surprised too with the Spanish dialog and Portuguese writing. The Para-glider seems to be using a brushless conversion!
@FranciscoB
Were did you find out its cost?
coriolan is online now Find More Posts by coriolan
Old Apr 19, 2015, 03:11 PM
GottaZoom is online now
Find More Posts by GottaZoom
Joined Feb 2014
Originally Posted by GottaZoom View Post
Got my board in yesterday PM (1/21 order and 2/8 shipping notice held in customs for a month) and it does have the horns and screws!
But the cheap board doesn't say F929 /939 on it. Says WL-HXJ12817R on the back
Will need to rig up something to see if it binds to the FS, I guess.
IT BINDS!
Got a couple batteries with NineEagles connectors that almost fit the oem connector. Looks like it would with a slight mod to the battery connectors.
But I cut those off and put pico connectors on the batts plus changed over the brick to pico and all works good. Mode 2 FS T-6 TX works exactly as it should.
Next up I've been planning to build a Nutball airframe (already have a UM Cub) since they are easy to build and fix/replace.
Not sure if I will do a mini power pod or not. I want something easy for a novice to fly indoors - not overly twitchy or aerobatic - so I think a little under-powered will be OK.
Really could use advice on size. I'm thinking somewhere in the 12.5 to 14 (maybe 300 to 350mm) inch range out of single layer DTF (4-5mm Depron equivalent?)
I can scale the 17" plans down but I'm wondering if there are any tweaks that I should make to keep it easy to fly. I was thinking of just using skids for gear, but also hopeful for lightweight ideas there, too. (Zip ties in front?)
PS - +1 on those hanggliders and the ultralight in the videos!
GottaZoom is online now Find More Posts by GottaZoom
Old Apr 19, 2015, 03:22 PM
FranciscoB is offline
Find More Posts by FranciscoB
Portugal, Lisbon
Joined Oct 2006
@robairt, I googled Bastermodel and ended up in a couple of brazilian shopping sites, namely Mercado Libre and Prešo-something.
FranciscoB is offline Find More Posts by FranciscoB
Old Apr 19, 2015, 03:37 PM
robairt is offline
Find More Posts by robairt
Joined May 2005
@coriolan, we might be neighbours, I live in Cambridge, Ontario.
robairt is offline Find More Posts by robairt
Old Apr 19, 2015, 03:44 PM
coriolan's Avatar
Canada
Joined Sep 2006
Sort of, used to live in sunny Vancouver,BC but now in not-so-warm Quebec City!
Old Apr 21, 2015, 08:11 PM
robairt is offline
Joined May 2005
Two more videos of V911 based aircraft for possible inspiration. This time it's a kite-plane or rogallo.
ASA DELTA RC BASTER KITE - BASTERMODEL (1 min 55 sec)
Montagem do basterkite (5 min 36 sec)
Old Apr 22, 2015, 07:13 PM
Mr.Atkins is online now
Find More Posts by Mr.Atkins
Mr.Atkins's Avatar
United States, WV, Charleston
Joined Jan 2014
Anyone given thought to / attempted a micro-gyrocopter using the V911 board?
Mr.Atkins is online now Find More Posts by Mr.Atkins
Old Apr 22, 2015, 10:29 PM
robairt is offline
Joined May 2005
I haven't seen a V911 micro-gyrocopter but this little Plantraco controlled contra-rotating auto-gyro has always intrigued me:
http://www.rcgroups.com/forums/showp...&postcount=783
The post seems to have enough details and photos to build your own.
Here is one of the videos attached to that post for interests sake.
plantraco autogyro test 1 (2 min 54 sec)
Old Apr 23, 2015, 08:15 AM
limmacslim is online now
Find More Posts by limmacslim
limmacslim's Avatar
United Kingdom, London
Joined Jun 2012
Its on my list of things to do! I got a hobbyking G2 & caught the autogyro bug a bit, I have been considering a similar layout to the G2 using a F939 board & geared motor . There are some pretty cool depron designs in the autogyro forum to draw inspiration from.
I still have a couple of projects to get through first, I made a box fuselage type 1.2m extra that decided to shut down mid air, it slowly nosed down & plummeted to a fiery death . I am currently rebuilding it...
Next I wanted to make a little floater v911 3ch decathlon using the same methods (sanded box type fuselage with hot wire cut XPS wing).
limmacslim is online now Find More Posts by limmacslim
Old Apr 29, 2015, 01:05 AM
robairt is offline
Joined May 2005
Could someone offer advice or insight on the following helicopter product:
http://www.banggood.com/FX051-2_4G-4...-p-971498.html.
It seems to have receiver board with separate servos and the price appears attractive.
Wanted WTB: micro 1 cell brushless power system for um parkzone plane (ar6400 brick) ddrummer508 Aircraft - Electric - Power Systems (FS/W) 1 May 16, 2012 09:55 PM
Sold Moving sale! Clearing out some cool RC stuff! Cars, planes, helis- local pickup in OR aaronredbaron Non R/C Items (FS/W) 7 May 16, 2012 06:50 AM
Question Heli motor in a plane? metalfred Power Systems 3 Apr 18, 2012 07:44 PM
Sold Pattern plane,Trainer planes Cheap!Need to move fast. radman615 Non R/C Items (FS/W) 5 Mar 03, 2012 05:16 PM
For Sale planes planes planes cheap milfiebre Aircraft - Electric - Airplanes (FS/W) 12 Dec 04, 2011 08:23 AM
