Old Aug 24, 2015, 07:11 AM
CN I Dawg is offline
Find More Posts by CN I Dawg
Crash=start of next project
CN I Dawg's Avatar
Joined Nov 2010
Originally Posted by RC Man View Post
If you really want more range you will need a 900+ on both ends. The 900+ is noticeably better than old 900. Also use the stock antenna. The antennas look short but I have done tests and they have better performance than 3DR antenna. I recommend 30db on the ground station and 26db for the air side.
6db more is double the range so going from 20 to 26db will double the transmitter range. Also the 900+ has a more sensitive longer range receiver so if you have 900+ on both ends you will get way more than double the range of a stock 3DR radio.
Power is only a part of the range equation. Antennas and noise floor are equally, if not more important. I operate at 26dBm on the RFD900+ and 20dBm on the 3DR radio (air). I have yet to exceed the range of this set up at 6 miles. At 6 miles I'm still getting 80% good data packets. IMO, key is using the RFD flex dipole antennas. They are light and work excellently. If you are flying a quad, the vertical one should still work. Just put it on an popsicle stick.
As a general note, most of us are more interested in the downlink fade margin.
CN I Dawg is offline Find More Posts by CN I Dawg
Old Aug 24, 2015, 09:00 AM
kiosk is online now
Find More Posts by kiosk
Joined Sep 2008
i just put on this antenna on the GCS RFD today and all I have to say is WOW....my range nearly doubled!!
http://www.amazon.com/gp/product/B0002NRKEE
kiosk is online now Find More Posts by kiosk
Old Aug 24, 2015, 10:20 AM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
Strange that they donít give the db gain? Not a very professional ad.
I see it has the wrong connector for Hobby use. Did you use an adapter or solder on a SMA connector.
RC Man is offline Find More Posts by RC Man
Old Aug 24, 2015, 01:52 PM
kiosk is online now
Joined Sep 2008
i bought an adapter for it, i think its 8.5dbi said on the manual
Old Aug 25, 2015, 07:40 AM
CN I Dawg's Avatar
Joined Nov 2010
That's heavy but a Yagi will certainly get you range. I was referring to this one. http://store.rfdesign.com.au/rfdflex...a-300mm-rpsma/
And for a ground station Yagi, this is a much better choice http://store.rfdesign.com.au/antenna-900mhz-6dbi-yagi/
Discussion Range of 2.4GHz RF Modem? GuerillaFilm FPV Talk 1 Apr 18, 2013 06:06 PM
Discussion 12ch Radio relay for wireless long range UHF ground station i3dm FPV Talk 0 Mar 22, 2012 03:20 AM
Sold Short Range - Long Range ! 2x Lawmate receivers, 1x 1000mw VTX & 1x 50mw VRX crashtested FPV Equipment (FS/W) 7 Mar 11, 2012 05:32 PM
Discussion Radio Frequency for Long Range? AeroWRX FPV Talk 3 Feb 13, 2012 10:36 PM
