Old Oct 20, 2014, 06:34 PM
Noob making progress
Australia, NSW, Mt Colah
Joined Oct 2012
Originally Posted by crosstrim View Post
Sounds like it might be a good idea to reinforce this area before any flights. Got pictures?
Unfortunately, no.
There is a hard plastic insert in the foam stab. It is this insert which fits over the 2 tubes on the fitting which inserts from under the fuse tail. The plastic bit the v-stab fits in then has the 2 'rods which fit inside the tubes, and secure with the screws from underneath.
The stab insert is a snug fit on the tube fittings, but it doesn't help if the insert is solid, but the foam can move around on the insert.
I'll have a look this evening, but with the tailfeathers assembled, I don't think you will be able to see much. If any value to be added, I'll take a pic.
regards
AlastairL is offline Find More Posts by AlastairL
Old Oct 20, 2014, 08:46 PM
"Rocket Scientist"
crosstrim's Avatar
United States, AZ, Mesa
Joined Feb 2008
Originally Posted by AlastairL View Post
<snip> There is a hard plastic insert in the foam stab. <snip> regards
So the slop occurred where I outlined in blue, only on the opposite side? I might just wick some cyano in there as a safeguard.
Thanks.
crosstrim is online now Find More Posts by crosstrim
Latest blog entry: Mounting the Motor (part two)
Old Oct 21, 2014, 05:45 AM
Italy, Lazio, Rome
Joined Apr 2014
Originally Posted by anewton View Post
Thanks for asking Cristain, here are some closer photos.
Wings Gorilla-glued together and reinforced with Scotch Tough transparent duct tape.
Thanks anewton, you're very kind. That's exactly what i needed.
cristian74 is offline Find More Posts by cristian74
Old Oct 21, 2014, 05:17 PM
United States, ID, Burley
Joined Mar 2012
Thanks.
Got tired of that thing moving and used some CA glue on it. Cant remove it but it dont move anymore
fastfwd is offline Find More Posts by fastfwd
Old Oct 21, 2014, 06:45 PM
Joined Oct 2012
Thanks.
Hi CT,
No, there was no slop between the holes and the locator thru' the fuse.
The entire plastic insert was moving in the foam stab. Along the red interface.
regards
Old Oct 21, 2014, 08:02 PM
"Rocket Scientist"
crosstrim's Avatar
Joined Feb 2008
(UN) Stabilizer
Hi CT, No, there was no slop between the holes and the locator thru' the fuse. The entire plastic insert was moving in the foam stab. Along the red interface. regards
Thanks guys.
Old Oct 22, 2014, 01:44 AM
Voyager
NSASarge's Avatar
United States, NC, Reidsville
Joined Sep 2014
Gathering the bits now ...
OK guys and gals ... After reading hundreds of pages of posts, I have finally purchased the following for my P2K ... (still in the box) ...
PRODUCT ID: NTM2836-1200
Model: NTM Prop Drive Series 2836 1200kv / 530W
Kv: 1200rpm/v
Poles: 6
Motor Wind: 12T
Max current: 36A
Max Power: 295W @ 11.1V (3S) / 530W @ 15V (4S)
Weight: 85g
ESC: 30~40A
Cell count: 3s~4s Lipoly
Bolt holes: 16mm & 19mm
Bolt thread: M3
Connection: 3.5mm Bullet-connector
Prop Test Data:
10x5 - 11.1V / 195W / 17.6A/ 1.02kg thrust
10x5 - 14.8V / 430W / 29A / 1.5kg thrust
11x7 - 11.1V / 295W / 26.5A / 1.12kg thrust
11x7 - 14.8V / 530W / 36A / 1.48kg thrust
HK 40A BlueSeries SBEC 4A
Same as “Mystery” Series
PRODUCT ID: Tz40A
Cont. Current: 40A
Burst Current: 60A
Battery: 2-6 Cell Lipo / 5-18 Cell Ni-XX
SBEC: 5.5V/ 4A Output
Weight: 30g
44mm Alloy Folding Prop Spinner w/3.17mm/4mm & 5mm adapters
9.5x5 Carbon Fiber Folding Prop Blades
And of course ... 6 x HTX 900 servos.
I will be using the HK NanoTech 2200ma 3s flight batteries. I think, from what I have thus far gleaned from this great gathering of minds, that the ESC, with a SBEC of 4A, I have chosen will handle the 6 servos. ALSO Looks like my motor of choice will run fairly cool with the 9.5x5 prop and pull the P2K fairly well.
Any comments would be greatly appreciated. Thanks in advance!
NSASarge is offline Find More Posts by NSASarge
Old Oct 22, 2014, 01:49 AM
Voyager
NSASarge's Avatar
Joined Sep 2014
Buddy Locator ... ???
Does any one know if there is a function on this site that will help you locate others in your area??? Would be nice to find another flyer locally. I visited a local flying club field and they were not to receptive to someone with a glider. Most of them were flying LARGE piston jobs and pattern ships. They were quite pricey to join also. $55 for AMA membership and $150 per year.
Old Oct 22, 2014, 02:33 AM
RC Airplane (Recently Crashed)
mutha's Avatar
Australia, VIC, Melbourne
Joined Jan 2011
On the main site click places. Find sites you use from site find users near you
mutha is online now Find More Posts by mutha
Old Today, 03:24 PM
MaydayMayday's Avatar
United States, CA, Fremont
Joined Jul 2011
Thanks.
I had a lot of slop, for me it came from the Fuselage holes were a little too large, I ran a bead of CA around the edge a couple of times still it was slightly larger then #11'd it till the poles fit snug
Obviously may not be the same for everybody though.
MaydayMayday is offline Find More Posts by MaydayMayday
For Sale HK Phoenix 2000 glider blk822 Aircraft - Electric - Airplanes (FS/W) 4 Aug 23, 2011 07:21 PM
Discussion Still having electric problems with my hobbyking Phoenix 2000, Crashvideo kyrkbymannen Electric Sailplanes 3 Jul 09, 2011 07:34 PM
Discussion Ohhh noo, 2nd flight on the HobbyKing Phoenix 2000 KillerCut Electric Sailplanes 14 Jun 06, 2011 09:57 AM
Discussion hobby king Phoenix 2000 EPO Composite R/C Glider doomracing Electric Sailplanes 3 May 31, 2011 10:09 PM
